Diesel information for the new owner
I just purchased a 1991 Ford F-250 7.3 liter diesel. This is my first diesel truck or car that I have ever owned, so some sound advice is needed.
Changing the oil every 3,000 miles with a quality oil made for diesel engines, favorite brands and grades/weights?
I heard the I should fill my truck with fuel where the big rigs fill up, because then those fuel stations have better turn over and less water in the fuel, True or False?
Advice on coolant changes, routine maintenance? Should I take it to the local Ford dealer and bend over? Or find a good independent mechanic and make a friend?
My rig: 1991 3/4 ton with over rider springs, with only a bumper pull (never had a frame mounted hitch, but it will soon), 5 speed manual, 7.3L diesel, XLT Lariat, AC (not pushing any cold air), body is straight and very clean, 133,000 miles, all for $5700.
I removed the oil filler cap while the motor was running and saw "no blow-by" smoke. I heard that that meant it was well maintained with frequent oil changes, True/false?
Thanks for any and all advice, Hugh
If the fuel station advertises "premium diesel," the API has established guidelines that the consumer must realize at least one of three actual, not perceived benefits, mileage/power, lubricity, emissions reduction. This is what I use, but you can never know what you're getting, so don't worry much. I try and buy all my fuel from the same place. I also won't buy from a dealer doing oil changes, since some have been known to mix motor oil with diesel. Just my $0.02
Since your truck is 10 years old, I would run some biocide to dissolve sludge, slime, bacteria growth in the fuel tank, drive it, and change the fuel filter some time after. There's a petcock or lever to drain off water from the fuel/water separator on or near the fuel filter. Do this. Should be explained in the manual.
I would definitely change the coolant, since that's often overlooked. Check for any special "bleed" procedures.
True on the test for blow-by. Sounds like a good price.
Use 15W-40 oil, I like Delo 400, Rotella, or Valvoline Blue. Use Ford's FL-784 oil filter, if I remember right, got em at Walmart.
Keep fresh air filters in the thing, and try to drive it someplace once a week for a long trip to get it hot.
Oh ya, injector pumps go out every now and then, and check your glow plugs every fall. You can get Motorcraft glow plugs at AutoZone off the shelf.
