:lemon:
:lemon:
Programmer
1572273
$340
control unit
1572638
Looks like there may be two variations or it's applicable to CJ2 and U40 options both
$950
Ouch.
I'd sure diagnose and sure find a friendly recyling yard.
These both seem different than the ones I dealth with on my 98 LeSabre which is vacuum oriented. These may be the electrical type control valves.
My garage is saying the part number I need is 16234403 with the CJ2 & U40 option. It looks like the unit you referenced with CJ2 & U40, but the part number is different. Do you think it cross-references?
Thanks for your in-sight.
Sean
I have a 1999 Aurora. I have recently noticed a slight exhaust smell in the car when I'm stationary. As soon as I drive, it goes away immediately.
Would anyone have any hints as to what this could be or has anyone also experieced this and what was the remedy?
It doesn't sound like there is any type of exhaust leak under the car (no rough or rumbling noises).
Thanks in advance....
Sean
is the link to the regular (not java) parts finder on rockauto.com
It's the last item on the page and it shows that same part number along with the other one. Don't know why two different parts numbers?
Now I have a starting point!
Sean
--Robert
I am a recent victim of the amazing 100km chrysler intrepid 2.7L engine blow up program from chrysler so I am looking at a 2001 aurora 3.5L in mint condition. Any good reason why I should not buy one of these?
When I replaced my radiator, I didn't tighten the top fitting enough (didn't want to strip any threads). I got a slight leak that was cured with another 1/8 turn or so of the fitting.
Les
i have a 95 aurora.. with about 140k
had the car about 3-4 years and just now the past few months starting have some problems.. the latest would be that the engine coolant light came on.. it was a little low so i filled it.. then it got worse, the last day i drove it , it had to be filled twice to get me home.
it doesnt seem to be getting real hot the temp hovers at about 220 .just above or below..
my brother couldnt find any where that it was leaking on the ground etc. I did smell like burning coolant that day..
havnt driven it since. but my dad looked at it and mentioned the water pump?? any info would be greatly apreciated!
Les
The higher engine RPMs bothers me in your description. Could there be a torque converter problem?
http://www.howardm.net/dred98/underhood.php
overheating, bubbling/gurgling behind the firewall, smell of coolant, replaced crossover pipe....$$$$. I had a mechanic try a head gasket sealer treatment to no avail. Now I'm trying to figure out my next step. Did you have any luck?
I'm not so sure that replacing the head gaskets will even resolve the issue at this point. I, too, owe $$ on it.
My wallet jumps everytime I even talk about it!
Any help would be greatly appreciated.
Does it over heat in 3rd gear on the grades where the engine rpms are higher and the coolant pumped faster?
You have probably checked for exhaust gases in the coolant which can be a common cause of overheating symptoms in some cars.
anita
Please let me know if you find out what the problem is! The exact same thing has happened to me. Never had a stalling problem at red lights with car in Drive until I had the 100K tune-up done and it seems to be getting worse. Initially after the tune-up it started to stall intermittently when I would pull up to a red light with the car in Drive; now it does it in Neutral sometimes as well and almost every time in Drive. Problem does not come up until the car is warmed up.
www.gmpartdirect.com
Hate to sell it for parts; anyone experience something like this that didn't require another new tranny?
Also, have a problem with the sensor for the variable speed fan for the AC, the fan doesn't come on at any temp, but heat/cooling seeps in thru the vents when turned on.
Help! I love this car and don't want to part with it, but if someone can give it a good home . . . all depends on the tranny.
Just curious do these have a ground connector next to parking brake left driver's foot in wall in front of door and a connector next to the driver's seat in sill between seat and door and same on the right side. Sometimes grounds can cause funny things. Moisture can cause problems with these from feet in rain and winter.
Is there a fuse for the mirrow and compass?
Sister had a problem with her Trailblazer - tranny was slipping/shifting funny. Took it in, and noticed the lights were flickering. Bad alternator = toasted battery, screwed up the PCM and TCM. I don't know if they replaced or just reset/re-flashed, but everything was fine once the cause of the problem (electrical) was addressed.
Just a thought. I've got a loaded black '98 Autobahn with almost all options (no gold package, though I have the emblems, and no engine block heater), hovering just under 100k miles (99,358 this morning). I would hate to part with it as well...
--Robert
Service station got it to go in reverse for a short period of time after trying a new battery, but it gave out when put into drive.
Had this car detailed once a year, all other electronics I never had a problem with; had a few minor fender benders so its been repainted twice and looks brand new and still turns heads - no nicks in the bumpers, etc. - people still ask me if its a new Lexus, etc. Other than the tranny the car is in exceptional condition but I have to hesitate about putting $4000 into it for another tranny. Any ideas?
Was your first replacement a new-in-box GM unit? Come with any kind of warranty?
I wouldn't spend $4k for trannies when you can find what you need here:
http://www.car-part.com
--Robert
Thinking of having it towed to dealer I bought it from for analysis B4 I give up on it - not that I don't trust my mechanic (rare these days to find one - he's cared lovingly for this car for 8 years now - oil change every 3,000 miles, etc.) but I figure the dealer might have better diagnostic equipment.
Just don't want to get ripped off by the dealer so I'm making it clear that if the diagnosis is a new tranny, I'm junking it, just to see what he says . . .
Transmison , new computer, water pump, EGR, FPR, grounds..the list is endless... great car.....
As of today it limped into my garage 100% undriveable;
back from the dealer with a new computer installed its stuck in 2nd gear, no TEMP gauge, no outside temp.
The car slowly died while driving on the freeway doing 70mph.
1. Simulated turning the key on and off and on.
2. Then starting flashing all the dash lights and slipping out of gear thus revving the engine.
4. Blowing smoke and stumbling and stalling.
5. Then to suddenly it ran fine as nothing happened while on the way to a parking lot.
They traced it to the computer loosing power setting various DTC's (loss of power/reset/keep alive/idle position reset etc. ) It was even loosing power setting DTS's while sitting in the garage for days. The computer is replaced and its 99% not drivable. Stuck in 2nd gear with no gauages (except speedometer)It was in better shape going to the dealer!
They say there is a shorted or pinched wire somewhere as nothing is communitaing with anything at a cost of $85.00/hour to find. We too much as I can tear stuff apart myself and fix but where do I start. I'm familiar with the pinched wire in the fuel injector sys.( stumbling & smoke )
Anyone familiar with this shorting/pinched wire problem? Maybe you might have an idea where to start looking for the loose/bad connection?
Any help would be great as its sitting in my garage, I'd hate to part out this car with so much $$$ into it. I think we all know the feeling.
Any ideas greatly appreciated!
at 60k stalls at trafic lights,hard start,surging,take car to pep boys,replaced fpr $287.00 dollars,80k brakes all around $150.00 and a couple of beers my brother.110k sqeaky left front wheel,replace front wheel bearings one side $500.00 dealer.at 130k car will not go past 2nd gear,hard to put car in gear via shifter,take to shop $350.00. 145k leaking anti freeze very small leak,leak gets larger(should have taken in earlier)take to shop replace radiator and water pump,$1000.00 dollars. at 165k serpitine belt brakes ,replace $100.00 and a couple of beers brother. at 166k cracked and leaking fuel rail,replaced at shop $795.00.(later replaced at dealer and reimburst at 170k) at 177k while driving on LSD in Chicage car dies out will not start, towed to shop replaced fuel pump $800.00 dollars.
