I replaced the throttle position sensor, since the stuttering stops if I :sick: begin accelerating. I assumed there was a "dead-spot" in the old throttle sensor. I assume that once the engine warms up there is something else that is causing the problem. I'd welcome any suggestions on what might cause these symptoms. The truck is old, but only has 109k on it. Still lots of life left in it if I can fix the "stutter".
:confuse:
Took it for 1 mile drive to test again and the 3 warning lights came on again. I popped the hood to see if there was anything visible and sure enough the battery was bulging along the sides and acid was oozing out through the caps as fast as it could.
Any ideas? I towed trailer for the first time in the truck's life recently and I am worried that something bad happened to the electrical system.
Saw your post and I have a similar problem that started tonight on a '97 XE 4x4. I have the check engine light, battery light and brake light lit up on the dash. If I rev the engine above 2000 rpm, the brake light and battery light go out. Have you found the problem with yours? I just looked under the hood and saw nothing obvious and will troubleshoot more tomorrow. Any insight would be helpful.
Mileage is 10.5 to 12.8 miles/ US gal.
Dealer continues to be helpful so far, but downtime and week plus wait for service are souring ownership experience.
Previous truck was Duramax, had less problems than this in entire life of vehicle.
BEWARE BEFORE YOU BUY!!!!!
Any suggestions for alternate companies or products or is everybody happy replacing with the same?
Not sure you have the ignition problem on your 2005 Frontier. I have Frontier for almost one year and put 12,500 miles on this truck. Last week, I filled 89 gas (well, I usually fill 87 gas), after that, the strange thing happened, the frontier truck need the second ignition to start, which the first ignition is failed. By the way, I live in Dallas, Tx; we had very high temperature wheather here. Could hot whether affect ignition?
I just got a 1986 4cyl 4x4 Nissan Truck with the same problem as you mentioned. It "stutter" when it starts from standing still mostly in first gear, and sometimes after shifting to 2nd gear and applying gas. And the truck could jerk significantly. At times when coasting on the 5th gear, the engine could occasionaly loss of power for a quarter second resulting in some unsmoothness or jerking a bit. Otherwise, it's a solid truck with 130,000 miles on it.
I would replace the throttle position sensor as you mentioned. What's more to do??? Thank you the post.
mark
Can you help?
I have a 2001 Nissan Frontier XE manual transmission pickup.
Its been a pretty reliable truck so far.
Earlier today while driving in San Francisco with its hilly streets, i accidentally accellerated the gas before i had the gear fully into gear. I think i was going from 5th to 4th or 3rd. Speed was @ 35mph.?
Now suddenly whenever i brake, even lightely, my truck is sqealing.
Its usually a thin, long scratchy squealing sound. But it does it mostly when braking. There is sometimes a very faint squeal when driving (not braking) but barely - its pretty much just when i brake.
About 75% of the time i brake now today, since the gear shifting mishap - the gear very loudly made a metallic griding sound for @ 3/4 of a second as i accidently accellarated before the gear was fully shifted into place - the truck make a type of sqealing sound.
I hope i havent totally messed up my clutch or transmission or something else very expensive?
Also, about an hour before the gear mishap, while going @ 60mph on slight downhill street, the brakes shimmied when i applied them like they were hesitant to grip fully. I was told by a mechanic once that brakes just do that on occasion as they are warming up or something? But now with the squealing - Im wondering what has happened to my truck.
Do i just suddenly need to replace the brakes as it has been probably close to 9 months since theyve been replaced, and i drive everyday, alot. Well, maybe on an average 35 miles a day every day.
Any suggestion, ideas of what might be causing the sudden thin long scratchy squealing sound?
I had a similar problem on my 1988 Mazda 323. In my case, the problem was with the fuel pressure regulator in the fuel injection system.
The pressure regulator had failed and the excess fuel pressure from the pump was not been diverted back to the tank. When I measured the fuel pressure, I read 70psi while about 35-40psi was the normal. So this increased fuel pressure caused excessive fuel to be injected every time the computer pulsed the fuel injectors. The computer was probably seeing the mixture being too rich and was thus shortening the pulse to the injectors but apparently with a 70psi fuel pressure even a short pulse was already delivering too much fuel. The computer would sometimes give me an error code for bad oxugen sensor. Do you get any error codes (engine check light)?
In my case when I replaced the fuel pressure regulator everything was fine and my mileage went back up to 37mpg (it had fallen to 22mpg).
So I suggest you measure your fuel pressure to see if it is within spec. If I can remember well I bought a fuel pressure meter for just under $40 a couple of years ago.
I have started to hear a "clatter" sound when starting to drive, especially when in 2nd gear. Kinda sounds like a thin chain clattering against metal.
I've noticed no jerking, hesitation, or power loss when driving, just the noise. Was thinking it might be the clutch or transmission, but not sure.
Anyone have any ideas?
The problem arose shortly after I noticed frost on the inside of the windshield and defrosted it, but did not wipe all the water off and some drained down into the dashboard. I then noticed the windsheild wipers were much slower, this went on for a week or about 50 - 75 miles of driving (mostly at daylight) then one day when the truck needed a jump start, realized the alternator must be failing. But like I said earlier, when I pulled it and took it in to be tested, it tested fine and when reinstalled it measured while running a slow but steadily diminishing 12v at the battery posts.
Continuity test show the cables coming off the big terminal on the alternator as good and the ground cable coming off the alternator as good.
Could it be something under the dash? But what?
When I'm shifting into gears, there seems to be a knock or a "groan" when I'm releasing the clutch. Seems to do it going into every gear. I want to make sure nothing is loose. The clutch doesn't slip when it's fully engaged? Anyone else with this strange noise? I just bought the truck, and I'm trying to make sure everything is good to go.
Brian
I recently purchased a 2000 Nissan Frontier 4 x 4 that has P275 / 75 / R16 tires on it. The tires are brand new, so the previous owner didn't have them on the truck for long. I don't know if they had that size on before the current set, lets hope not. I was wondering what the short or long term side effects or damage this could cause? The truck only makes a "grinding" sound when the wheel is turned all the way in the left or right direction while going over a bump. I'm thinking that the radius arm is getting pulled on. I'm taking it easy on the truck until I can get the correct size on the truck. Anyone ever had this situation?
Brian
