Also could be a broken gas cap if persists after tightening. Wasn't the case with my Catera but with 2004 Saturn Vue had to replace defective gas cap.
Water Displacement formula 40 was engineered for drying rocket fuel and was accidently discovered to have other commercial uses. Good Luck! Dave
Thanks :confuse:
if it does then i would suppect the gear sensor. hope i said something that helps.
Thank for any help you can give me Jak62
Anyone else experiencing the tranny shift problem while these lights are on?
Jason
Dave
I had a service station check fuel injectors which were OK, A mistake to take everything off to take it in to the station for a check. I now have no compression on #4 cyl. Which tells me I've either got a burnt valve, stuck lifter, or stuck valve which would hit the piston being stuck open.
Best to pay the $90+ for analyzation by a pro. These cars are setup so analyzing tells it all. You could check wires and plug yourself first.
Dave
It seems that I saw something before about the ECM shutting off a cyl and also if some other sensor is defective it will gradually affect runability. For instance the crank and cam sensors are known to go bad, especially crank. So you could search for (crank sensor) and it will tell you how to change it. These are Opel engines and most mechanics don't know their quirks. They are a superb car once you iron out the bugs. Some were used as police cars in Germany.
Dave
I would think it's a pressure switch in brake system, older cars had this prob. occasionally and either it would be air in the line causing pressure or the pedal switch under the dash not releasing switch button by being out of adjustment.
But with this highly sophisticated brake system I wouldn't bet on those issues being the answer.
Dave
at any rate, i was just wondering if anyone can help. Maybe it is the main computer, but I would like to know before I buy one. The car starts fine but just doesn't move, as if it is not getting any gas. I don't hear any indication that the engine is getting gas no matter how far I press the gas pedal.
