I ordered a new modulator from the Cadiallac dealer, it cost $90. It is very easy to change (except for having to stand on your head under the steering column). All you have to do is locate the gray box (sorry I don't have a picture of it to post but there is a previous blog on this site that tells you exactly how to do it and posts a pictur), take it out and plug in the new one.
My car has worked perfect since the replacement.
Visiting Host
I have some of the indicator lights on my a/c heat control panel out and I want to put in new bulbs. I saw an article a short while ago on how to change them but I lost the message.
Do you have any information that would help.
Right now, with the car parked and key out, the wheel is NOT locked (turns freely).
we replaced the throttle body, pedal level sensor and still does the same thing.
can anyone help?
The main thing to fix here would be the cracked head gaskets which costs to repair about $800 up to $1000 or more depending on where you take your car too.
There's a government program which gives you money if your car no longer can pass smog. If it fails, fill out some paper work at the Pick-N-Pull offices, and bam! They could end up giving you up to a $1000 to junk it. The same amount it costs to repair one of the most troublesome cars ever.
It's obvious as to why it was only sold from 1997 up to 2001, and never to be seen again.
Last week it had the code P0411 air intake
The mechanic is stumped and thinks it may be the computer going out and throwing random codes.
Ever since having the timing belt changed my car has had problems and has thrown many codes, but it has had many problems, and is not running correctly (seems sluggish).
Please help. Any ideas?
The timing belt instl. is tricky, got to have correct cams marks lined with notches on top of sheet metal guard when the crank timing notch is in TDC firing position after the belt is installed. If it's not as per those specs. it will not run correctly and the valves can be bent if timing is off a lot. It's a bear to correct but whoever installed the belt is responsible if there was an error on any of the work done. SSKL Dave
That is what I was thinking. Unfortunately, the GM dealer that installed it is no longer in business. They were a real nightmare (wrong tools, lack of integrity, took forever - they had my car for over one month).
Is there a way to check to see if the timing is off without taking the whole thing apart again?
If the cam is out of time the computer would pick it up immediatly and might shut off fuel/firing on cyls. affected. So the combination of codes need to be analyzed which are only clues to the problem. Manifold and crankcase pressures would be affected which are a sign of valve malfunction which also is picked up by the computer.
Therefore a $90 analysis at any good shop is necessary before altering anything. If a cam timing problem is evident then you would be assured that the repair needed would be the right one.
After the GM dealer went out of business, we had no GM dealer/service here on the island. A new GM dealer opened a couple of weeks ago. We tried to take my car there, but they said that they didn't want to work on it anyone other than a GM dealer had worked on the car.
No engine lights or codes. Can anyone shed some light? I'm not a mechanic and far from it but, it seems to me it is not a good thing. Car runs fine in every other way.
Your thoughts?
My 2001 Catera has the code below. Can you help?
Thanks. tt1mich@ ya h o o.com
PO411 DTC is "AIR System No Flow Detected". If you give me an email address I'll scan the troubleshooting instructions from the '98 Catera Service Manual and send them to you.
Thanks in advance
odessaodessy@yahoo.com
I need my little luxury car. :shades:
I have had the car since 2006, and had no problems until here lately. Just had the valve cover gaskets replaced, and the radiator, which I consider to be normal maintenance. Also, this winter the ABS and Traction control lights came on, and when it does the Speedometer does not work. I've been told that is usually a clog in the lines and those lights are triggered by air and that debris gets into the hoses around and about the brakes.
The Neutral S. Switch is a security device, please read about it. With the NSS the car start only in Parking (P) and Neutral (N).
Good luck!
