Cadillac Catera Maintenance & Repair
18911131429
    stephaniecmmstephaniecmm Member Posts: 5
    I brought a 97 Catera Jan.2008, fairly new to me. I've had to change the coil pack once I got the car and now I had a timing belt replaced but it still wont start. Any suggestions ??? (The timing belt I was told is set right).
    gngurugnguru Member Posts: 108
    Well, obviously either the switch for the ALC (automatic level control) system has malfunctioned or you have some sort of problem with the ALC system, and most likely it is the later. There are several components involved in the system and about the only way to get it properly diagnosed would be to take it to a Cadillac dealer and let them hook it up to a diagnostics machine to determine the problem. You could watch the car after you start it to see if it actually does level and if not, most likely (and hopefully) you will have a leak in one of the air lines and the air compressor is not bad. Good luck.
    According to the owners manual, I quote " The leveling light comes on steady when the rear load level in your vehicle changes. Do not drive your vehicle when this light is on. The rear of your vehicle is too low and part of the body or the rear axle may be damaged when driving over bumpy roads. When the light goes out, leveling is complete. If the light comes on flashing, there may be a problem with the leveling system. You should reduce your vehicle speed and have your vehicle serviced soon"
    Unquote. In my experience with the light, my trunk was full of items and I had to adjust things around, to even it out. The light went off. The light also comes on when I first start my car for about a minute, but after it goes right off, I always wait till it goes off completely, and about a minute or less it does go off. I hope this helps. Wouldn't help to try rearranging your trunk contents.
    Was the car able to start up and run when you bought it or have you been trying to get it running after you bought it? If it was running when you bought it, why did you have the timing belt replaced?
    ld3303ld3303 Member Posts: 3
    Im Lester...i just purchased a 2000 catera.The radio will not work when the car is turned on,but will work with it off.What did you do to fix your problem with the radio?Please help me im desperate to hear this fabulous bose system when im rolling....
    Whatts up with this site....lol.No one has been for 3 days....i sure need some input on the radio problems im having....radio plays with car turned off,but goes dead with car running....
    bradcadbradcad Member Posts: 9
    I own a 2000 Catera also... it's a great sound system, when it's working. I've had several on and off problems with the radio. Every once in a while the radio just turns off... no warning... nothing... I suspect a breaker or similiar is the problem since it often resets itself after a while and comes back on... very frustrating. I have had it checked by the dealership... while it was in for repair of yet something else... but since it's an intermittent deal, they say they can't find the problem. Sorry to not be more help... but I can sure relate to the frustration... good luck.(bradcad2000)
    caterajunkcaterajunk Member Posts: 30
    Had to get rid of my 2000 but if i were you I would have the computor reset. I had to do this three times once with my catera but it evenually worked. Good luck soor I don't have more advice.
    weaz08weaz08 Member Posts: 5
    I recently purchased a 1997 Catera with only 84000 miles on it but I have had some problems with it already. I have had the ignition coil replaced $750 and now the check engine light is on again and the shop check it out and it is giving a code for some type of emission problem possibly the EGR valve. Has anyone had this problem? Can you shed some light on my situation before I drop another $750 that I can't afford.
    Cadi Owner
    Did they happen to tell you the DTC code? If they did, tell me what it is and I'll tell you what the problem is??
    Thanks for your response. I will call the shop to get the code because they did not write it on the invoice it just says that the code is "emissions system flowing backwards"
    That's a tough one. The DTC code would be a big help in pinpointing the problem. However, if in fact the EGR valve is stuck open or closed or not functioning correctly, your car should be experiencing a rough idle and/or kind of "bucking" during acceleration and possibly "knocking" to some extent. Just some thoughts but anyway, holler back when you get the code.
    A pulley broke which caused the timing belt to "jump" I have now found that I need a new head gasket, which in all of this is another problem. Im getting it fixed now, so hopefully I'll be up and driving again soon
    Good Luck Stephanie, I had a 2000 put timing belt, electrical parts then engine went out I got rid of the car and bought a 2002 cash van with 78000 miles I'm less stressful and NO CARNOTE Oh i bought sensors
    Thanks#525 and #526 for your input.i will try them both and let you know whatts up!!
    dclaibornedclaiborne Member Posts: 4
    votage is reading low battery light comes on, replaced battery alternator tesys strong light still comes on new battery dies should replace alternator
    It actually drives pretty good except for now the cooling fans are not kicking on and it gets hot. I need to check that out too. I called the shop this morning and the manager is not in today but I talked to one of the mechanics and he thinks it was P411 but I would have to call tomorrow when the manager is in so he can pull it form the data base. Is P411 a good code for emissions?
    DTC PO411 is "AIR System No Flow Detected" so yes, it definitely has to do with emissions. The diagnostics to repair the problem are very extensive and involve many steps, 32 to be exact. Of course you would hope that it wouldn't take all 32 actions to solve the problem. If you are working with a Cadillac garage, they would have the diagnostics sheets. If you're working with an independent mechanic and he doesn't have the sheets, I will be more than happy to scan them and send them to your email address. Unless you have an extensive mechanical background and garage I really don't think this is something you would want to try to fix yourself but that is up to you. As for the cooling fans not coming on, there are 17 diagnostic steps to troubleshoot that and I would put that problem at a higher priority than the check engine light being on. Hope this helps and let me know what you think. Thanks
    I actually pulled it out of the Cadillac shop and have it at home. I have a mechanic that is a friend of the family taking a look at it. If you can send me the diagnostic steps to try and fix both problems that would be very much appreciated. I just couldn't leave it at the shop it was at because they were going to charge me $95hr just to try and find the problem and he said it could take 2-3hrs. You can send it to the email address here or to ptownweaz@yahoo.com.
    thank you very much,
    eli
    bev6bev6 Member Posts: 1
    Please help....my son was working on his Cadillac Catera and a big gust of wind came up and slammed down the hood. Now he can't get it open. It appears that the latch is not holding it down, so is there other latches that we don't know about.
    He is really frustrated with this car, as he ran into something and poked a hole in the radiator, and now the battery is dead, so he can't even push it, as the steering wheel is locked and when he had the hood open to jump the car, it slammed down and now its STUCK!! We even tried to jack it open with my husbands jack and it started to bend the hood. PLEASE HELP US!!
    Of course, as with all cars there is a double "safety" latch on a Catera. I know for a fact that the safety latch on a Catera is very hard to locate and many people have trouble getting the hood open. However, if your son has worked on the car before, I would think he would know how to open the hood correctly. If the safety latch is holding it down it will move up and down about an inch or so before catching. I'm kind of in a hurry right now but if in fact it is not the safety latch holding the hood down, I will get back to you afterwhile with info on how to get it open. In the meantime, DO NOT try to use a jack to get it open. It won't work...............
    Okay. I need more info. Is the hood stuck and locked down in the completely closed position or is it being held down by the safety latch (in other words, can you move it up & down about an inch or so or not)?? Let me know.
    bbbmysticbbbmystic Member Posts: 5
    I have a 1997 Catera. Recently, the A/C will only blow cold air when it's not hot enough to use it. Also, once the engine has been running for awhile or sitting in the hot sun, it only blows hot air. The cooling fan does not seem to be kicking on to cool the refrigerant but it does kick on enough to ensure the engine is not overheating. The system does not have any leaks and is fully charged. Could this be a relay or bad fan or something else entirely??? How could I check it?
    jcurtismallowjcurtismallow Member Posts: 1
    I purchased an 01 Catera a few months ago, the front end recently started shaking pretty bad that would come and go. I was told that it the tires had worn prematurely. I had one mechanic tell me it was a design defect and that new tires and front end alignment would be a very temporary fix. It doesn't sound like Cadillac acknowledges the problem. What to do?? Please Help!!
    heckofamanheckofaman Member Posts: 6
    Remember that any rotating mass can cause a shake, so there is another strong possibility...a broken engine mount, which any good mechanic can check easily by starting the engine.
    I don't believe that there is any 'design flaw' with the front end...my Catera has well over 100,000 miles with no tire issues. I have Continentals and rotate every 10,000 miles or so. It is also possible that one of your tires has a broken belt...even some new tires can break a belt which will make it impossible to balance.
    I have to agree with heckofaman. That mechanic should be fired for even saying something like that if it were in fact true but it isn't. There were not any Catera so called front end defects ever. I would suspect that you have a tire out of balance or out of round. Alignment is not likely to cause front end shake but it could be a factor causing a tire to wear unevenly and eventually shake. If I were you I would get two new front tires and possibly the alignment if you want but you have to get four wheel alignment which can run anywhere from $60 to $100+... When they balance your tires, they will be able to tell you if you possibly have a warped rim which also could cause shaking. A bad motor mount would maybe cause a little shaking on acceleration but is not likely to cause the steering wheel or front end of the car to shake while just cruising along. Good luck.
    adoschadosch Member Posts: 3
    I have a 2000 Catera had the same problem....we did an alignment..it didn't help...took it all over to find out how to fix the shaking....put on two new tires, its been running like a dream....
    cannondalemtbcannondalemtb Member Posts: 2
    Alright... our Cadi Catera is acting really weird. It isn't throwing a single code either.
    Here's the story:
    So about a month ago the car started to missfire a little, but then stopped. It then did it once and a blue moon, but never threw a code and wasn't that big of a deal.
    Well my mother was driving the car, stopped at an intersection, and it just died on her. The car would crank and crank and crank but wouldn't turn over. So she had a towed to a local shop. There were no codes so they decided to look at it in the morning. Morning came, the car started right up. So my mother picked it up and everything was fine.
    So then I am driving it for about 20 minutes later that week with no problems. Then I begin to deccelerate coming down an off ramp and the car dies. Same deal. Crank and won't turn. So I push it into a parking lot and try to figure out what it could possibly be. So after about an hour of sitting and my final try, the car starts. SO I begin to drive it home on the highway and everything is fine until I begin to deccelerate to a red light. Same thing again. Then my father goes back later to get the car and it starts right up. He drives it home and it dies when he deccelerates. We go back the next morning and drive it straight to the shop.
    The local shop (who we trust very much) took another look and had no idea. He recommended that we take it to the Cadi dealer because he had no idea what it could be.
    Now before we bring it to the stealership, any ideas what this could be? It seems to only happen when slowing down and when the car is warm. Then starts back up once it cools down.
    Without even giving it a second thought, the first thing I would do is to replace the "Crankshaft Position (CKP)" sensor. That, in all likely hood will solve your problem. If your "trusted local mechanic" is not familiar with replacing the CKP sensor, give me an email address and I will send you the instructions with pics. Not a difficult thing to do at all. I believe he can get the sensor at most auto parts suppliers. Let me know and good luck.
    Well I haven't talked to the mechanic yet. Only my mother has. I am going to go down there tomorrow to pick it up and bring it back home to check a few things. I know he has mentioned the CKP sensor before, but I don't think he replaced it since he is not charging us again. I think I will give it a try.
    email is cannondalemtb (at) hot mail (dot) com
    Why would the CKP go whacky only when its warmed up and decelerating?
    A bad CKP definitely goes whacky when it gets warm. The deceleration part, I don't know. Maybe it just happen to be at the right temperature to malfunction while the car was decelerating a couple of times. Anyway, here is a link to another forum that will give you some insight to CKP problems and how to replace it with pics. I have the service manuals and will be happy to e the instructions to you if you still want them but like "sirmqc" says, the instructions and pics aren't always that clear. After you click on the following link, click on the second link down where it says "Sticky: 98 Catera Crankshaft Position Sensor........." and that will take you to "sirmqc"s comments and a bunch of useful info. Let me know that you can get to the link okay and whether or not you still want service manual info. Here's the link:
    http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum
    speedkraftspeedkraft Member Posts: 4
    Hello gang, new to the group. Have a 97 Catera that will not shift, only gets 1 and rev. When it trys to shift to 2nd...nothing!! When I use the "snow" button it stills has nothing until I turn it off, then it grabs 1st. Trans doesn't slip in 1st or rev. Really appears to be electronics? Saw many trans issues here, but none with my problem. On a good note, had a 97 before that was a GREAT car. Believe it or not, 143,000 trouble free miles!! Didn't know how good I had it. Sold the car and wished I didn't! Just picked up another (bought it with this trans problem) and hoping for the best. I was a BMW tech for years in the late 80's, have owned many German cars, all were good. I do have a strange feeling about these cars....you have to drive them HARD, everyday. Thats what they like, thats what they were built for. WE (Americans) are to easy on them. Sounds strange I know, but it's what I saw at the dealership level for years. The one with the most problems were the ones that drove easy or not often (lots of lady drivers, sorry) No prove, just a thought... and my opinion!! Any help with the above trans problem would be great, if anyone has had the same thing happen. Thinking about that circuit board in the trans thing.... There are some good ones out there..... :confuse:
    Ben
    dmmjr64dmmjr64 Member Posts: 2
    I just bought a 99 catera for my son. I was told by the person that I purchased it from that it needed a new oil cooler. But the dealer told me it had a transmission cooler leak. So I put in a new trans cooler in myself. Now I notice water in the oil. It's also blowing white/blue looking smoke out the exhaust. I'm thinking it still needs a oil cooler, but not sure about the smoke. Maybe a head gasket?
    I also have water coming off the front of the motor but not sure where. I have already replaced the control valve. Any help with these problems would be helpful. thanks
    diva36diva36 Member Posts: 4
    I need to know if anyone has had this problem and if so what was the solution...I wasn't able to put the car in Drive this morning, It starts up fine but refuses to shift into drive it is stuck in park...HELP PLEASE!
    I would check the "Brake To Shift" switch to see if it is operating properly. To do this, get into your car, turn on the ignition but don't start the car. Tap the brake pedal and listen for a clicking sound coming from the gearshift and observe whether or not the "brake to shift" light on the dash panel goes out each time you tap the brake pedal. If you don't hear the clicking and/or the light doesn't go out when you tap the brake, the switch is not woking and needs to be replaced or bypassed. It is located above the brake pedal under the dash. Good luck.
    Thanks I will try that when I get home from work....
    acurryacurry Member Posts: 27
    if you replace the brake stop light switch also replace the cruise control switch also it is right next to it or youll have to replace that switch very soon it happened to me and you will have to same exact problem with the shifter
    ewilleyewilley Member Posts: 1
    I have a 99 catera with 90k miles :sick: and here is the list of probs I need help with (it's a long list cause it's a piece of crap car-but it was free)
    1. Car won't start: for the past couple of months, after I have driven the car (usually >10 miles) and go back to start it again it will not start. I sounds like it is trying to turn over, but won't engage. Will keep trying to start it, and if the battery hold out long enough, it will usually start again after it has sat for about 20 minutes. It will then go a couple of days with no problem and then out of the blue won't start again. We thought that it was a starter issue-had it checked and it's okay. HELP!
    2. Transmission light: While driving, the tranny light will come on and it seems like firts and second gears don't work, and you are starting in third. Starting from a complete stop, the car will go supper slow until about 30 mph and then is fine, until you start from a stop. If you turn the car off and then back on-the light goes away and runs great. The light has now started to come on after I start it and let it idle for a minute or two. Again, turn off the car and then back on-light goes off and no problem. HELP!
    3. Check engine light: the engine light will come on, always with the same code P0411 and will stay on for a few days, then go off by itself. the guys at autozone all tell me that it is electrical?
    4. Coolant leak: the stupid coolant light keeps coming on every couple of weeks, and we add more coolant, knowing that there has to be a leak somewhere-but never had any driveway drips-until two weeks ago. Now the stupid thing is dripping coolant from the left front end, kinda where the battery is. HELP
    5. Burning oil?? Had gasket replaced 1 1/2 years ago cause the car was burning oil and smoking. For the last 9 months it smells like its burning oil, and will occasionally still smoke. Another gasket???
    Please Help. Also if there are any good mechanics in Utah I would love to know who they are. I hate dealerships.
    blk00caterablk00catera Member Posts: 10
    1. Sounds like possibly the Crankshaft Posistion Sensor. When my Catera needed this, it would run fine for a while, then the engine would quit. It wouldn't start for 10-20mins. Then out of the blue it would start up and run fine. It is quite a common problem with Cateras. I'm not sure if that is what you described but I would definatley check in to it if it has not been replaced.
    2. I recall someone else having the same problem in a previous post. Try searching the forum.
    3. See post #482 by gnguru. PO411 DTC is "AIR System No Flow Detected". He may be able to help you by send the troubleshooting codes.
    4. My Catera had a leaky Heater Control Valve. Puffs of steam would occasionally come from the hood and fog the window. It would leak from around the front driver side. I believe this is also a common problem with Cateras. After this was replaced, the sensor on my jug went bad.
    5. My valve cover gasket had to be replaced. It caused the oil to leak on to the the manifold and create a burnt oil smell and ocassionally smoke would come from the hood while parked. The coil packs are known to go bad if this goes on for too long. Sounds like you have already had this gasket replaced. Hopefully this is not related to problem #4.
    I'm sorry I wasnt much help. Searching this forum for some of the stuff I mentioned may help to shed some light on the problems.
    I want to say that "blk00catera" is RIGHT ON with his comments, especially problem #1 (need to get the car running before you can solve any of the other problems - LOL).... The only thing I would add is that the Heater Control Valve is between the engine and firewall and generally the water leaks out more toward the rear of the engine. It is a $90-$100 part and I'm pretty sure only available thru a Cadillac dealer and relatively easy to change out and was definitely a problem with most Cateras. If your water leak is for sure toward the front of the engine, I would just watch it closely to determine where it is leaking. Could just be a bad hose or hose clamp.... Good luck.
    calicagocalicago Member Posts: 53
    MY WIFE OWNS A 1999 SPORT SO FAR HAD NEW HEAD GASKETS NEW TIRES. NOW THE HEATED SEATS ON THE PASSENGER SIDE WILL COOK YOU AND THE SEAT ON THE DRIVESIDE DON'T WORK AT ALL GAS MILEAGE HAS GOT BAD AND THE TRANS WINES AND IT FEEL LIKE IT WONT GO INTO OVERDRIVE DO ANYONE HAVE THE TUNE UP SPECS ON THIS MODEL TYPE OF PLUGS, GAP IDEL RPMS AND HOW TO FIX THE SEATS IT'S LIKE THAT PESTKEY MERKUR SCORPIO ALL OVER AGAIN AND YES I OWN ONE IN MY GARAGE WITH ELECTRICAL PROBLEMS HHHHHHEEEEEELLLLLLPPPP :cry:
    chrissstiechrissstie Member Posts: 5
    I have a 97 Catera and it has been running fine. I have had no major problems besides haveing to change a brake light switch, up until now. Now I can not get it to start. It will turn over, but will not fire up. I was thinking it might be the fuel pump, but before I go and drop $500 plus I would like to try and change out the CKP sensor. Only thing is I have no clue where it is, can you help me? chrissstie@yahoo.com
    Can you not open the link on Post #549???
    ok i replaced the crankshaft position sensor, and i am still having the same problem.....what is something else i can look at>?
    mazeusamazeusa Member Posts: 5
    Hello Everyone, I am new here but so glad that I found the group and I wish to share my problem with you and ask for your help...
    I had my 1999 Catera for about 8 months now and during that time I loaded it with 10,000 Miles, now it is at 91,000.... All of this list of problems I have, started from the time when I bought the car and since that time I was trying to just live with them somehow. I love the car although the last problem in my list started to be annoying, anyway here are the problems:
    1. The car feels like a tank, it is very heavy although the exhaust blows water which I was told it is very good sign about the engine, still the car accelerates slowly and it feels heavy.
    2. The car jumps when it shefts from 2nd to 3rd even while I am slowing down... this often happen when it is running 20-30 mph. although if I am trying to accelerate it shefts normal, but if I am trying to slow down or mentain speed at that range it does that wierd jump.
    3. This one is my biggest problem... The first time this happend I had put about 2,000 miles on the car and it just started to increase and happen more often now, I will be driving at any speed and the transmission slips. When I slow down a little or left my foot of the gas it eventualy shefts and drive normal for another 20-60 miles then it happens again. Few months ago I had my mechanic flush and replace the transmission oil, the car then ran ok for a while then the problem came back but now with another one. Just as before it sometimes slips and sometimes it will be running ok and the transmission light comes on and stays on until I completely stop, turn the engine off and back on then it runs ok.
    I finally took the car to a transmission specialest. but his response was 'change the engine mounts' He did let me see the engine moves up when he plays with the accelerator and the sheft. But does this make any sense in relation to what I described?
    joejetjoejet Member Posts: 6
    Yesterday the Leveling light stated blinking on the dashboard of our 97 Catera. I was told that the system might have a leak in it. Can someone tell me where I can find the pump for the system. I can hear the pump go on and off when we stop at a stop sign. It's pretty loud but I can't get it to do it when I'm under the car looking for it. Also, are there air lines that may be leaking? If so, are they easy to access.
    Any information that anyone can provide on our problem will be greatly appreciated.
    Joe
    merckxmerckx Member Posts: 565
    This morning, my 2001 Catera has developed a new problem. The amber low coolant light came on the instrument panel. the Cadillac dealer told my wife(I'm at work)the coolant level is fine. He thinks it's a bad sensor in the coolant run-off tank. I was planning on buying my wife a new car this month.
    i was considering keeping the Catera as a weekend hobby car-It's worth vvery little on the used car marketeven though it's got only 50,000 miles on it.
    The dealer wants $300 to replace the tank and sensor. I'm wondering how hard is it to replace-anyone know.
    For today,I didn't get it fixed....but I can't imagine trying to sell it with a lit warning light.
    replace the tank yourself i just did mine about a month ago its very simple just remove the hoses and take to clip off and the sensor is on the bottom it takes no more than ten minutes and i only paid 80dollars for the tank from the dealer. trust me its that easy
    bht529bht529 Member Posts: 1
    I put in the wrong coolant in my 99 Catera. I want to flush it out myself and put the correct one in. I drove for about a week and now it is smoking. I did not know I needed to put a specific type in it. Is that o.k. to do or should I just take it to a shop and lwt them do it. I am strapped for cash and I am thinking of reading the instructions and doing it myself. Please send some advice
