Toyota Truck Owners: Problems & Solutions
Cheers,
Ron
I did go to a hitch place and they gave me a 4 wire harness to hook up to the back lights, and then a two wire harness for power and the brake. The trailer uses a 7 pin connector without using the middle pin. The brake wire connection that was suggested by the hitch place was a splice into the wire which comes from the switch located just behind the brake peddle. I guess after looking at the wiring diagram from the toyota manual there may not be a plug-in under the dash. May have to go with the splice.
duane
Dianee
As title states, we have an 86 Toyota 4x4 22RE engine.
Yesterday, as I was driving into the mall parking lot, the truck seemed to start to lose power. (I thought - Oh man! Let me get into a spot! - It did - I love my truck Ok sorry, so I left the truck in the spot and waited for bf to get home from work, he went to the truck and it started, but it wants to die right away.
He also mentioned that when holding clutch, brake and gas (otherwise it dies) at about 2000 rpm he heard an awful clunk in the engine. (It does make this "clunk" sound, and its not pretty...)
So this morning, I got the truck towed home, and I would like to see if I might be able to solve the issue before the BF gets home.
The truck starts fine. Will start now, but the second you try to push the gas, it dies. It doesnt seem gas related to me EXCEPT for the fact that I had purchased gas about 5 mins before it broke down. I purchased the same gas we have bought the truck for over 5 yrs, from the same place, so I dont think it will be tainted gas.
Any help you can offer would be super, I do have some mechanical ability and do understand most parts, so dont be afraid to help me, LOL
Amanda
The warranty extension is offered for a period of 7 years or 90000 miles.
The specific components covered are:
number 1 oxygen sensor, bank 1 (left side exhaust manifold)
number 2 oxygen sensor, bank 2 (right side em)
The diagnostic codes are P0135 and P0155.
Hope this helps!
19001 South Western Ave.
PO Box 2991
Torrance, CA 90509-2991
Just some thoughts.
Toyota told me the engine doesn't have "lifters" in the traditional sense.
Anyway, to make a long story short, they douldn't find anything out of Toyota specs.
The problem is getting worse, and it makes me feel uneasy.
I plan to contact Toyota directly, to see if they have any feeback.
But when I checked with my local dealer, they told me that this does not apply to the 4cyl models. So, maybe it applies to the 6cyl model like yours.
but I just bought a new business so my friend says I'll need a bigger truck but I don't want a bigger truck. So he says a campper will do the trick. But the campper will make the truck look odd. Is there another way? :confuse: Please reply back!
First time, will not crank, then on second try it will.
What was the outcome to your prerunner "ekartanowicz"? Any info is much appreciated!!
Also, yesterday, it did turn over on the first time but it felt like the starter would not stop cranking. The engine was running fine but there was a whinning noise.
I turned the truck off, took the key out, and it was still trying to turn over. The truck began to shake. After about 10 seconds of this, it stopped, I restarted and eveyrthing has been fine since.... :sick:
A couple weeks ago the check engine light came "ON" I was low on gas, so I was thinking maybe the pressure was low and filled the tank. I did some research on the web and read that sometimes a computer needed to be reset...so I pulled the EFI fuse and put it back...BTW what's the EFI?...the check engine light turned "OFF" after I started driving. A week later, I went on a business trip and left my car idle in a parking garage. And today the check engine light came back "ON"
Any ideas?
I turned the o/d button off and it would stay in 3rd, but when I turn it back on, it does shift into 4th, but that's it. Doesn't trans have 5th gear? I think my problems are in the overdrive gears. Has anyone had or is having these similar problems? Please let me know. Thanks.
The high-mount brake light DOES work, so it doesn't appear to be the pedal switch.
This is a 2000 SR5 Double Cab Tundra 2WD V8 with 90k miles. I'm the original owner, I've never had any other problems, there have been absolutely no modifications to the truck, everything is stock. It has never been in an accident, I've never towed a trailer, nothing like this at all. The wiring harnesses at the tail light assembly all look fine.
Any suggestions appreciated. Should I take this to the corner shop?
I currently own one, purchased in January after 3000 miles the transmission needed replacing (vibration at 35 mph). I didn't ask many questions. On my ride home the repaired transmission would not shift properly and often dropping from 4th gear to 1st. I quickly returned to the dealer and after running a diagnostic I was told the computer needed to be reflashed and it seemed to solve any problems.
Now 4000 miles later and another crazy ride of the transmission not shifting out of 1st gear I was told by the dealer I needed a new transmission again. This time the service rep after much questioning stated that Toyota is having quality problems with some internal parts.
All of the work has been done by a Toyota dealer under warranty but I'm thinking this is a bigger problem. Toyota promotes quality and long lasting trucks but I'm having a hard time believing this. :sick:
1badtundra
This is the most disappointing truck I have ever owned. I have owned trucks for over 40 years. It is SUV in truck body.
Tim
I took my truck to the dealership a month after I posted my original message. They claim the belt was stretched and replaced it. Free of charge, I might add.
So far so good. Hope this helps.
I just bought a 2007 prerunner and I have the same noise problem in reverse. Did you ever get a solution?
John11017@yahoo.com
John
