Engine Misfire
I have a 91 Corolla with 126,000 miles. When I start in the morning white smoke comes out of the tail pipe. I got it checked and the service guy said that it is because one of the cylinder is
cracked and also some valve job needs to be done. and will cost 1000 dollars to fix .
My ride is not smooth particularly when I go up hill . If I do not fix it will it be a problem ?
Will it stall on the highway ?
I am planning to buy a new cat in 2-3 months ?
Thanks for any suggestions.
Precision tune. They ran some diagnostics.
They mentioned about valve jobs, piston rings being rusted.
Yes I get white smelly smoke all the time. When I do a cold start it is more.
The mechanic mentioned that as long as I change oil regularly I should be ok without fixing it.
I want to make sure if others had this kind of problem and it is safe for me to ride the car.
My knowledge of taking care of car is zero.
Corection : It is only during start after some time there is no smoke. Also the engin makes lot
of noise during idling.
