Question Please help.
Can someone please tell me what the 1/2 in 1/2 ton, and others, 1/4, 3/4, stand for. I've searched the net and can't get anything. Does it mean it has a payload of 1/2 ton? but 1/2 ton is 1000lbs not 1500, which is something all the trucks payload are or more, so does it then mean a payload of 1500lb or more? Please Help!! Thanks!!
In the mid 1970's the Big 3 came out with "heavy half" pickups, GVWR of 6200 lbs., to avoid tighter emission requirements on lighter duty trucks. My 1973 GMC C-2500 (GVWR 6400 lbs) was not rated to carry as big a load as a 1975 "Big 10", because the '73 weighed more empty! (Heavier frame, springs, axle, brakes, wheels and tires). My current C-1500 ('91, V-6, 5 speed) will haul (a lot)more than either of my previously mentioned trucks, because it weighs about 3,050 (3,250 with me in it at the gravel pit) empty, and has a GVWR of 6,200. If you used a lighter weight driver, this truck could haul its twin!
Today, I'll stick with GM's, to keep the complexity down to an only mildly intolerable level:
1500 ("1/2 ton") GVWR less than or equal to 6200 Lbs. These trucks are subject to most stringent light truck emissions category, and there fuel economy counts in GM's EPA light truck corporate average fuel economy. They have 5 or 6 lug axles. Load range C tires. 2WD, V-6, 5 speeds payload is about 2,500 lbs. 4x4, extended cab long bed is about 1,500 lbs.
2500 (3/4 ton) GVWR of 8,600 lbs. Only available as an extended cab short bed or standard cab long bed. (I think) Eight lug wheels. Load range E tires. Payload approx 3,000-3,500 lbs. EPA does not rate fuel economy.
1500 HD ("Heavy Duty 1/2 ton") GVWR of 8,600 lbs. Crew Cab Only. A marketing concept, otherwise identical to the 2500. Payload approx 2,800 lbs. EPA does not rate fuel economy.
2500 HD (Heavy Duty 3/4 ton) GVWR 9200 lbs. Eight Lug wheels, Load Range E tires, heavier frame, room for available big block or diesel engines and Allison Transmission. Reg cab long bed 2WD 6.0 5 speed payload exceeds 4,000 lbs. Diesel, Auto, Crew Cab, 4WD long bed payload approx 2,300 lbs.
3500 (1 ton) All 2002 GM 3500's have dual rear wheels and long bed. Springs (particularly rear) are heavier than 2500 HD. Rear axle is rated for heavier loads, however I have not discovered a difference in the axle itself. Max Payload of 2WD, 6.0L, 5 speed exceeds 5,600 lbs. Payload of heaviest version is around 4,000 lbs.
The story at Ford is just as scrambled, with there being both single and dual rear wheel F-350's. I haven't checked into Dodge's nomenclature.
I hope you aren't sorry you asked!
