Brake Lights Stay On
I have an '87 Camry. The brake lights stay on all the time, even after the engine is turned-off. The brake light switch has been replaced. The light sensor in the trunk has been checked out as being OK. Fuses and bulbs are good. Is it a ground problem? If so where is a logical place to start? Any ideas on what the problem is?
Thanks in advance.
Thanks in advance.
Is the brake switch adjusted correctly? Try pushing the brake switch in and see if the light goes out. Remove the fuses for the brake switch, if any, and see if you have a light. If you have a light in either of these cases, you either have some kind of ground feed back, or it is not the brake light but a tail light lit. Some bulbs have multiple circuits. Step on the brakes to see if more light comes on. If it does, your problem is in the running lights circuit. Unless you did some kind of repair, my guess is a faulty switch. Do you have DLRs?
Keep us informed on your progress.
Do like I did with a slipping switch in retainer. I used a narrow octogon nut on the other side. The switch should be plastic so you can cross thread it if you need to. Make sure you adjust to the proper length of switch. You don't want the pedal pounding the hell out of the switch. I never had a problem since then.
