Subaru Legacy/Outback Wagons Maintenance & Repair
Subaru Legacy/Outback problems and solutions. Thanks for your participation.
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
Revka
always when it is cold and mainly in the Winter.
The symtoms are when starting the car the engine
shakes as if only firing on half the cylinders. If
I turn off the car and restart, it usually restarts ok. Sometimes I have to crank longer then
usual to start. I advised the dealer about the problem. They stated nothing is showing on the computer as a problem. Yesterday I had to restart three times to get the engine to smooth out.
Don
Revka
-juice
I did hear rumors of Grand version of the line but I dont know what became of it. A Grand OB would have been cool. 6'' wider and 12-16'' longer would have made it perfect.
One of the more odd things is that there is no Subaru minivan. Just about the biggest complaint is what juice just reflected. Need bigger vehicles. My opnion: I dont want or need an SUV, I want an AWD minivan. My only options currently are the Town and Country AWD and the Venture/Montana with Versatrak. There is the Astro AWD but if I'm going to get 15mpg.....it better have 400hp. My family has had horrible luck with DC transmissions so the TC is out. The Montana looks kinda funny to me so thats out. The Venture is actually pretty nice but when compared to the Toyota or Honda it just seems really unrefined (engine and chassis). The other draw of the Venture is that we will have maxed out our GM dollars at $3500 by then easily. Probably cant even use that much toward it.
Still, Subaru should listen. The OB is fine for us now with just 2 people and a dog (sometimes 2 totalling about 200lbs) but its just too small for much more than that.
I drove a Rendezvous, and it was OK. It really deserves a better engine, IMO. Verstrak is FWD until you get slip, so no full-time AWD.
Did you guys see the new Subaru concept at Tokyo? It was discussed in the Future Models thread.
-juice
Paul
-juice
Paul
-juice
Still, Opel or no, it's a 3-row Subaru. Whether it gets out of Japan or not is a different story. We may see a real Subaru 3-row though if that WX-01 "Emotional Multi-Wagon" concept gets produced...ever. Who knows.
-juice
What a car!!! bought the OB anyway......
Hi All,
I've been reading this site for quite sometime and have found it very enlightening, thanks for your posts.
After 4 years of research and waiting, I bought a '01 Outback Wagon H4/5sp in July. After 6 months of use, I have recently started having problems with the steel frame in the driver seat pan. As some have noted, the seats are rather deep and now every time I swing my left leg over to get out of the car, the steel frame cuts into my hamstring. It's to the point now actually where I have trouble walking and have actually consulted a doctor.
I suppose it has taken these 6 months for the foam (?) padding surrounding the steel frame to break down enough for the frame to become so pronounced or I would have noticed it sooner.
Has anyone else experienced this? Any ideas on how to fix/replace this seat?
I have tried lowering it as much as possible, but the car is high enough off the ground that even at its lowest, my leg rests on the seat edge while touching the ground. I've taken to various acrobatic tricks to evacuate the car now. Incidentally, it does have the electric motion controls, which I would be fine without.
Thanks and regards,
Sean
And btw, don't worry about cross-posting. I often encourage people to post in more than one discussion, especially when they're experiencing a problem. Not only will it help in getting you more feedback, but it will also make it easier for others on down the line... to find your information. Good luck in finding a solution, and please keep us posted. Thanks.
Revka
rsholland: I would have thought so, too, but the replacement interval for the timing belt is not mentioned in the manual.
n8wvi: Not sure which engine it is (the manual is in the car right now) but yes, it's an interference engine. It's a timing belt, not a chain.
onfoot: Well, you had some other problem there, ours started with the accident and the piece of metal stuck in the cylinder.
Seems the big mistake here was on the part of the collision guy who sent the car to Subaru for the valve job without re-assembling the car so Subaru couldn't test the engine. He suggested it to save Subaru work (it appears). Of course, maybe they wouldn't have found the problem either...that car ran fine for quite a while before dying.
Also,is the 60000 miles maintanance price $700 correct?why it is so expensive..?anything that has to be done at this time without spending so much money.???Thanks..Yes.I got a answer.Thank you but,still with the same doubt.If I can replace the windshield,is anything wrong with that?leaks,no original part,etc??
60k miles is a major service. They ought to replace just about every single serviceable part on the car. I can think of a bunch of stuff: oil and filter, fuel filter, air filter, spark plugs, plug wires, PCV valve, tranny oil, differential oil, 02 sensors, alignment, tire rotation and balance, etc.
-juice
It happens in 1st and 2nd and is most evident when I'm in need of high acceleration, but it only does it once, and then goes.
On another board, someone suggested it was a plug misfiring.
Any ideas/experience around this?
You could check the throttle cable and remove any excess slack from it (but leave some or it'll idle high).
The only other thing I'd try is to change brands of gas, to see if that has any effect.
-juice
Jon
I'm finding it very hard to drive smoothly in lower gears. Lots of shuddering going into first and second at what you'd normally think would be the correct rpm. I've got to rev higher than usual to make sure not to stall when entering intersections going into first from a dead stop and then from first to second.
Also the horrible burning smell in stop and go traffic. Anybody else here getting that?
The dealer says we're driving it incorrectly and that's whats causing the burning or stalling. He says with a hydraulic clutch you can't move forward slowly easing the clutch in and out in stop and go. That you have to let it all the way out to avoid burning the clutch plate which of course you can't do because it will stall if you're moving slowly, which is of course what you'd be doing in stop and go. So what are you supposed to do hit the guy in front? I want to say that I can drive a manual and have never had a clutch wear out before at least 110k on other makes of vehicle. Has anyone with this problem figured out how to drive through it?
Jim
I put synthetic in my Miata, and the shifting in cold weather got a bit easier.
-juice
* spark plug wires (most likely culprit)
* spark plugs
* fuel filter, fuel supply
* air filter
* water in gas tank (use dry gas, keep tank full)
* fuel injection (get a throttle body servicing)
I bet one of those will solve it. Our 626 was hesitating big time, and the throttle body service fixed that. On Miata.net they say spark plug wires are often the fix for a loss in power.
-juice
Since then, it's been to my local mechanic twice and dealer once, neither of which could get the temp to rise again. I've had radiator cap replaced (only holding 9lbs pressure v. 16), air bled from coolant lines, thermostat replaced, and two head gasket tests which were both normal. Less than 24hrs after picking up from dealer the temp shot up again, coolant level was low, that great smell was back. When I called dealer, they said to check oil & did it look like caramel? It doesn't - regular old oil, which incidentally they also changed. Now the dealer is telling me they'll keep it overnight to run pressure tests all night, but I should replace the engine, which is roughly $2300 incl labor (used engine). I think they don't have a clue, but figure why not start over....
I know nothing about cars save where to put the key, gas, and washer fluid. Does anyone have suggestions on what I should be checked next? My local mechanic suggested possible cracked head, but the dealer said they couldn't do just that, had to do the whole engine. Though its amusing to have my son ask "Mommy did your car blow up today?", I'd really rather have a solution. Any help would be appreciated - Thanks!
You would think that after designing cars for over 100 years that automotive engineers could make a battery area that didn't rot out. Put the battery in a plastic box for crying out loud!
Check the water level, remove some with a dropper or turkey baster if you must, just don't touch it with your hands.
I would replace the tray, it should be cheap, and if not try an aftermarket one from Pep Boys, Trak Auto, or NAPA.
nic99: I'd let your mechanic have another look, I guess. Ask him to check if the fan is working, i.e. nothing is blocking it.
-juice
All complaints to the dealers have been met with a dismissive "don't drive it like that" comment. I find this particularly annoying as I have diven all kinds of manual transmission cars on 3 continents for over 30 years and have NEVER experienced these sort of problems before.
I also contacted the Subaru tech support people and have quite a file with them. They did send their District Service Operations Manager (Mike Pelkey) out to look at the vehicle. Subaru's position on this is that they will replace the clutch if it fails completely (at no additional cost) but they will not admit that there is a general problem which warrants a recall. They tell me that each problem is delt with individually (the old divide and rule trick) .
So although I do like Subies, I had an Impreza for 4 years before purchasing the Forester, I don't think I will be buying another. I strongly believe that Subaru do have a marginal clutch problem on both the Forester and Legacy since they use many of the same transmission components. Implying that people do not know how to drive is not going to win them repeat business.
Has anyone come up with a solution to this -- seat position, extending the seat track, etc.?
I'd love to get a Subaru Outback LL Bean but I may be forced to a VW Passat wagon for the increased front passenger leg room.
Eric
Nowak: it can be done.
Eric: was it you that was going to try to take pix when you also do the passenger side?
-juice
Eric
-juice
-- Joe
brake noise. The brakes seem to be very sensitive to moisture. The second month I had the outback I went on vacation and left the vehicle in an outside parking lot at the airport for a little over two weeks during Winter months. When I started out to return home I thought the wheels were going to come off the first few miles. I ended up having to have the rotors turned at about 5,000 miles. I checked on the brake shim that was mentioned on the board. The subaru rep told me that the shim is no more than a pull tab from a pop can. I decided to pass on this at this time since it did not sound to high tech to me.
I have a question on the automatic H6 LL bean outback wagon. Mine seems to have transmission slap when it shifts. If I get onto the gas it seems to be smoother when it shifts but does not help the gas milage. This seems to occur mostly when going up a hill or incline.
Any thoughts on this? Maybe that the way they are.
This is my first subaru.
Don
I have 16K miles on my LLBean. Love the car, especially in the snow!
I had my rotors resurfaced at 10K - they were acting up when I braked off the parkway at 75 mph = warped. Only non-routine service so far.
I have also noticed a slight "slap" here and there (maybe 5-10 times in total). Only happens when the car is under light load (like when shifting from 2nd to 3rd going slow on a flat road). Don't think much of it, though. And my last car was the reference point for all mid-priced transmissions - a Camry - can't get much smoother than that for the price.
Ralph
I traded in a Nissan Patherfinder for the LLbean and I find that it meets my needs. I very rarely go off the beaten track where I would need the low 4 wheel dr. The gas mileage is a lot better and the ride and handling are superior.
What kind of tires are you using on your LL bean.
I have the stock all season Firestone Wilderness on mine. It seems to do well in the snow.
Last month I leased a 2002 A4 quattro. I did buy snow tires and steel rims and wheel covers for it.
I got the Dunlop graspic DS1 package from tire rack. They seem to be doing a good job. My wife drives it more than I do, but she has no complaints so far. The tire certainly has an agressive tread pattern with a large footprint.
Check the ATF fluid level anyway, just to be safe.
I would use a little throttle when you let up on the clutch. I also try to creep in 1st gear in bumper to bumper traffic, though.
-juice
Clunk when shiftikng to Park is probably a Park Interlock of some sort. Are you making sure you have your foot on the brake when shifting too or from Park.
Vibration when turning may be binding rubbers on sway bars. I suffered noises on turning when my Outback was new. Dealer removed and lubricated rubbers.
Cheers
Graham
I have a '97 Legacy Outback with 102K miles. Been a real good car, though my mileage has always been between 18-24.
About two years ago one of my fog lights went and a year latter the other one went. The dealer said since they broke because of being hit by road stones they were not covered under the warranty. There was a small hole in one light and the other one was cracked.
The dealer said it would cost $321 to replace. So for the last year I have been driving without the fog lights. Is there a cheaper replacement and how difficult are these to replace?
Happy motoring!
Ralph, I know what you are saying about Japanese cars. I have had three Maximas, one camry, and one pathfinder. I have been happy with these vehicles, but Iam always looking for something new. I did a lot of research on the A4. I see no down sides to it. As I stated before I traded in a 99 Passat 2.8 for the A4. I wanted to go to the next level. So far we are happy with the decision. Don
gave them a good reconmendation, so I went with them. I had been using Michelin Artic Alpin the last two years. They were very good, but were 15" and would not fit on my new A4.
Don
Lithium grease is sold in spray cans. You can spray the rubber bushings that hold the front and rear sway bar in place to quiet them. Or let a dealer do it. They are easy to see if you remove the wheels (i.e. during a tire rotation is a good chance to do this).
fog lights? I would go aftermarket. No way are they worth that much cash. For $500 you can get true HID driving lights.
-juice
