The grinding noise is not normal and it does indicate a problem as well as the 'ineffective brakes'. Let me assure you that a 05 OB should be able to stop very well, leaving a lot of room between you and the deer on the road.
Do you know what wheel it is comming from? Some ideas is a hanging caliper, brake pad installed 'backwards' (metal to the rotor - yes I have seen it happen), badly scored rotors, misalligned pads and/or caliper.
You spoke of grinding on inclines, and I'm trying to figure what that means: is the noise a squeal like a metal scraping, as the wear indicators on the brake pads? That sounds a bit like fingernails on a chalkboard, BTW, if you can remember from school days. Or a buzz-like vibration in the brake pedal, as when the ABS kicks in? Or a "pulse" in the pedal as from a warped rotor (note that overtightened wheel lugs can cause this). And does it not happen on level roads? Is it dependent on the severity of the stop, or speed, or wheel turn, or what? When did this start? Did you have any work done on the wheels or tires, etc., just before that? Did you do any offroad excursions? More data might help with all the experienced Subie owners in this group.
Brakes are such a fundamental safety component that no manufacturer would dare build weak brakes. In fact, most braking systems are capable of stopping the wheels under literally any circumstance, so stopping power is determined more by tire grip and by effectiveness of the ABS if the car has one. If the brakes on your car can't do that, there is something seriously wrong, and it doesn't matter if the car is a Subaru or a Porsche.
Any decent dealer should have found this in one visit, or at most two, if it is intermittent. Maybe it is time to try another dealer. If so, check with others on this network for recommendations. What part of the country are you in?
Stanton
I purchased a 03 Legacy at 50,303. At 53,800, while traveling, the battery and brake lights stay on. At 55K and cold weather the lights come on at very low speeds,the headlights flicker and the engine revs. Any idea what is going on? :confuse:
today I drive the car, the check engine light was not on. I went on my trip and figured to repeat what I did last time to see if it reoccurs. So I stopped on my driveway on a snowy patch then tryed to get up the steep part from a stop. After some wheel spinning the ABS light came on, the Check Engine and the cruse started to blink.
Also the trip odometer shows a 'Er SS' or 'Er 55' code. What is that suppose to be? The ABS light went out on a restart, the check engine is still on.
Also does the car's OBD2 (computer) hold onto the codes so if the check engine light goes out again the dealer can find out why I get the check engine light?
I replaced the rear pads on my '96 about three months ago (first replacement with about 193K on the car!). That was the first time in my life I had worked on disc brakes, so I read through the appropriate section of my Hayne's manual, got my tools together, and set to work. From the point I jacked up the first side of the car to pull the wheel until it was back on the ground and ready to go, it was 45 minutes. I figured I could knock off a third of that time next time.
Maybe now I am being TOO optimistic!
If a DIY'er, the Haynes manual is cheap and comes in very handy for all sorts of everyday (well, periodic anyway) maintenance. I think I paid about $20 for mine back in August 2000 at a local auto parts store.
Takes up a lot less space than the book, but of course you can't take it outside and drape it over a fender while you are under the hood!
Stanton
A factory manual assumes that you know what you're doing and provides a not very detailed sketch.
Unfortunately, I haven't seen any Haynes manuals for any Subaru's 2000 and newer.
Jim
The factory manual provides good pictures and diagrams, but it is organized a bit randomly. I suspect the guy who sold them actually downloaded the chapters from Subaru's website, and not in any particular order.
Stanton
the 420 code is a p0420 evap code not related to you driveability problem .
your problem comes down to the A/F (air fuel ratio sensor)
in 2000 Subaru removed the air flow meeter and went with the more accurate a/f sensor it is a hybrid o2 sensor located in the exhaust. the o2 sensor reads o2 only not unburned fuel like the a/f sensor dose!
I am sure this will make you car happy ! also it will help with fuel mileage. also stay away from the dry gas don't like it on the new cars !
If you were wondering about no check engine light for this problem it's got to due with programed parameters in to the control unit. you can buy the part from a Subaru dealer for about 130.00 it should be a in stock item
Your car should fly through the snow even with poor tires
It is normal for only one tire to spin it has to due with the gearing in the diff
As for wheels spinning, on my driveway test - on a 05 OB - which set a trouble code BTW, I had all 4 wheels spinning with the car in place, I must say it was quite a beutiful thing.
Thanks in advance,
Bill
I'm somewhat surprised that it performs worse than a FWD car would, but hard to diagnose the exact problem at this point!
1. check all 4 tires sizes must be all the same size
example 205/65/15 not just the 15" but the rest of the size 205 and 65 must all be the same !
2. check tires with a flexible tape measure as Subaru
states no more variance the 1/4 inch I would say no more then a 1/2 inch measure circumference from the center of tire
THIS IS A IN PORTENT STEP in checking the all wheel drive system for binding
THIS MUST ME MADE SURE THAT THE CAR MEETS THE ABOVE REQURMENTS BEFORE TRANS IT SUSPECT
note ALSO IF THE CAR DOSE NOT FALL UNDER THESE GUIDE LINES BEFORE
ANY BINDING THIS MAY HAVE WELL CAUSED THE TRANS TO FAIL
More THEN LIKELY THE TRANS WILL NEED WORK EXPECT TO SPEND $1,200 TO $ 1,700
THIS IS A CLASSIC REAR EXTENSION HOUSING PROBLEM
THE TRANSFER CLUTCH SEALS (HARD TEFLON ) WERE IN TO THE
CASE CAUSING PRESSURE LOSS TO TRANSFER CLUTCH PACK
( THESE ARE THE AWD CLUTCHES ) AND WHEN THEY Don't ENGAGE
THE JOLTING IS FELT. IT TAKES TO MUCH TIME TO ENPLANE
BUT THAT WHAT WILL FIX THE BINDING IF ALL OF THE ABOVE
ARE IN 1-2 ARE KNOW TO BE GOOD
NEW PARTS NEEDED
1 . EXTENSION HOUSING
2 . TRANSFER CLUTCHES + STEELS+ SELECTIVE SPACER/SHIM
3 . TRANSFER GEAR BEARING ( PRESS FIT )
4. REAR VALVE BODY CROSS OVER TUBE
5. VALVE BODY GASKETS (REAR VALVE BODY)
6. AND TRANS FER GASKET
HERE"S YOUR FIX IT WILL WORK ! DONE MORE THEY A FEW
Good LUCK !!
This does not happen when shifting into "REVERSE".
Once engaged, the transmission operates flawlessly.
The problem was that it was slow to engage in drive, sometime up to 30 seconds.
As I said this problem has been resolved now the repair was to the transmission with a rebuild kit.
NOT a replacement rebuilt from Subaru for $4000 cnd + labour
There is a tech bullitin regarding this problem with the Series II 4EAT automatic transmission.
Is it possible the tires will fix the problem or is the damge likely done.
Is it safe to drive if i don't get it fixed prior to leaving for the holidays? Headed to snow country.
Thanks, Bill
GOOD LUCK
I thought that may be the problem, but the lights only came on at speeds over 50 during the summer.
Thank you for your insights.
Depends on what you are protecting yourself from. If you're worried about a potential catastrophe, no matter how small the odds, and it will give you peace of mind, or if you might not have the money to cover an unexpected big bill but you can afford the contract, these might be reasons to do it. There are probably others.
Also, like all insurance, you only have the one car - the averages don't do you any good, only the experience with that car. Roll the dice?
Not definitive, sorry. Tim
I got them for my 92 Legacy, never got my money back on that one, everything went to pot after the ext warranty ended!, I have used more than double what I paid for a 98 Legacy which I still have. The a/c repairs were well over a grand plus various other things. Dealers I have found treat you very well with a SOA ext warranty, I have had work done free which is not covered - from burnt out bulbs in the dash to a timing belt.
I have gotten my money back many times over on a Ford and Chevy with ext warranties!! In fact I would never buy one of those and keep it beyond the factory warranty without one.
Don't buy non manufacturer ones, while you are not tied to a dealer for repair, many of the larger companies have gone belly up in recent years leaving their customers out of luck!
thanks.
I can only guess that the older one is actually the one you have (just to contradict tkanic ). Maybe the dealer added it as an option and used one that was left over from 05? Or maybe Subaru needed to use both in 06 due to supply issues? Just my WAG.
No Prob zman3, but just to clarify my (early) 05 OB came w/ the compass under the mirror and is the type shown in the 05 OB 'flyer' OK not a flyer, but that thing you get at the dealer which shown info on a current model car, the 06 OB shows the compass in the mirror IIRC.
It could very well be manufacturing issues also as you pointed out.
My head gskt. failed last week. I bought a SoA rebuilt engine $6K Cndn. I suspected something wrong a month ago- poor gas mileage - hard starting - black coolant coming out of exhaust.
i asked Subaru dealer to check it out-he found nothing wrong.
Same reply at local NAPA dealer - he replaced the starter.
I'll replace the car soon, but it won't be a Subaru.
Tomr
Me too, and the Cruse Control can be cancled w/o turning it off or stepping on the brake or shifting into N, it helps to read that book
Bill
