It has been a few years since I did my '02, but IIRC, in addition to the large floor panel, there was a smaller 'wing' that slid partially under the passengers side 'wall'. Down in that valley, coming off the wheelwell region was a wiring harness. I remember that my connector and a length of wire was wrapped back on itself and taped (?), making it a bit hard to see or feel.
Steve
Hello. I also have a 2005 OBXT. I purchased & installed a HiddenHitch receiver (because it is the least conspicuous) and a JCWhitney trailer light converter speced for Subaru. The converter is necessary to convert Euro separate brake&turn to US combined brake&turn. The Subaru wiring connector is buried inside the rear left plastic panel (even the dealer didn't know where it was); you might have to root around to find it. The Subaru connector also supplies 12VDC for converters such as the JCWhitney; you want this so that your trailer lights do not load the car lighting circuit. This 12VDC supply has a separate fuse, but I cannot remember if the fuse was installed or if I had to install one. ALl went together nicely; the JCWhitney converter was "plug-n-play".
Does anyone know where the front drain tubes exit the chassis? I'm hoping for a simple fix by back-blowing them with compressed air, if I can find them!
Thanks for your help.
Jon
Awesome, gotta love these forums.
-juice
RK
Odd that yours was buried quite so deep, but glad to hear that you found it!
Steve
PD
1. My owner's manual says I should have a 16.9 gal tank. The gauge goes to E, I fill it up...and I get only about 10 gallons in. Is the manual wrong?
2. My mileage, regardless of the size of the tank, is awful. In city, I'm getting about 11mpg.
How wrong are these two numbers? Can anyone help?
Thanks in advance!
Dave Becker
10 gallons sounds a bit low even considering that there is some reserve after your fuel indicator hits "E". The low fuel light comes on with 2.5 gallons left. So assuming you run it down to the light, you should still be able to fill about 14 gallons. That's been my experience with my 2005 Legacy GT wagon which also has a 16.9 gallon tank.
How do you decide when the tank is full? Do you let the pump click off on it's own? I've seen faulty pumps that triggered off prematurely. Do you always pump gas at the same station and pump?
As for the gas milage, 11mpg sounds a bit on the low side, even for city driving. Is your Legacy AT or MT? How short are your city driving miles? Also, how do you calculate your mpg? Do you warm up your car before driving?
Ken
Auto tranny, only a few miles, so it doesn't have a chance to wamr up much, but regardless...180 miles on 3/4 a tank seems very low.
Dave Becker
Cheers
:shades:
-juice
The gas gauge is rather non-linear. If I run mine down to close to the E, until about 10 miles after the light goes on, I can put about 14 gals in. That is about 320 miles of mixed driving, for about 23 mpg. 2002 Outback, H4 auto.
Steve
Do you know when the 2007 models arrive at the dealers ,
and what changes will there be on the new models ?
Thanks, Rudi
07 models should be here soon, we'll get an Sat. Radio option and an aux input, and probably memory seats. Little stuff.
-juice
1) Sometimes the front brake calipers stick and can cause the front brakes to drag. Rapid pad wear will occur and can cause poorer gas mileage. You can remove the tire and make sure that the brake disk turns freely.
2) Proper tire inflation is important. Under-inflated tires can dramatically affect mileage.
3) A cooling system thermostat that is stuck open will lead to more inefficient engine operation, and can affect gas mileage.
4) Tire design is a factor. When we change to snow tires during the winter for our 3 Subarus, the gas mileage goes down from 3-4 mpg for each of them.
5) A lead-footed driving style can cause poorer gas mileage as well, particularly in city driving. City driving that is characterized by a lot of traffic jams with engines idling and no movement will cause poorer gas mileage. An idling engine uses more gas than most people realize.
Does anybody have any experience with this product and would you recommend it or not?
Chris
should I wait for the 2007 model. As you mentioned before,
there will be no important changes, and the price will be
higher.
Thanks, Rudi
Or pre-pay your maintenance if you prefer. You can get more value (substance) for your money IMO.
Pics: try Photo Bucket or ImageStation. Heck, try Edmunds' own CarSpace, put your photos up there, and then link to them. If you're having trouble, get the photos up there and I can help you link to the pics.
$29,250 for a Bean sedan? Your profile says NJ, so you're not far from fitzmall.com or Van Bortel, and could maybe do a tad better. Fitz has them from just over $27k to just under $29k. The sedans cost a bit less, so you'd be on the low end of that.
Consider taking the train down to Union Station in DC, then the Subway to White Flint. I believe Fitz will even pick you up there. You'd save almost $2 grand, easily worth the trip.
I live very close by, so if you feel nervous about it I'll meet you there. My family has bought 4 cars from that specific dealer and I trust them.
-juice
If you don't mind me asking, which dealership? I've dealt with Flemington Subaru and they have matched the best offer out there. They are very close to Fitz as well.
Mark
The car is a four, which is another reason I'm mystified and concerned. As to stevenm's points:
1. I haven't heard a ting from the brakes. I'm not the car's primary driver, but the times I do drive it (at least three times a week, no stereo on, and windows down when it's nice) I haven't heard anything.
2 and 4. Tires are inflated properly. I also know about snows-I have them for my Accord, and I know how that will drop it. These are "Summer" tires.
3. I don't know anything about the thermostat being open, but at no point have any gauges lit up and it does not run excessively hot or cold, even when cruising on the highway.
4. My fiance drives like a slug, which is actually her nickname. Leadfooting isn't an issue that I've seen, and I don't get on it much at all. I live in a "city", but I use quotes because a city of 15,000 people in Northwest PA isn't NYC by any means, so there's no traffic, etc. The lieage is far worse, though, when not driving on a lengthy trip.
Thanks again to all for replies past and future.
Dave Becker
1) It might be worth having the CPU scanned with an OBD-II scanner to see if it will yield any clues. I'm assuming that your "check engine" light isn't coming on.
2) The clue that your thermostat may be sticking in the open position is if it takes an unusually long time for your engine to warm up.
3) A dirty or plugged-up air cleaner will hurt your mileage.
4) It might be worth pulling your spark plugs to see if your engine is operating properly. Any that are black with carbon or oil indicates your engine may not be operating properly or has internal mechanical problems.
5) Check the color of your exhaust tail pipe. It should be a light or dark grey color. If it is black with carbon, it indicates your engine is not operating properly.
6) A check of all your fuel lines and gas tank for leaks would be a good idea; I'm not sure about your model, but most Subarus I'm familiar with have the fuel pump in the gas tank so all the fuel lines are under pressure. I'm assuming that you are not smelling gas when it is parked.
No hassle from the saleman , free oil change.
Paid $ 28,500 .
Thanks for info.
Best regards, Rudi
Remember, when you calculate your gas mileage, it's got to be from fillup to fillup... and divide your miles by the number of gallons you put in, not the size of the tank.
I got this error when driving on ice uphill when all 4 wheels were turning but all were slipping. After talking to the dealer I found out the Er-55 (orSS), means a problem with the speed sensor at the wheels. Basically the computer has decided that the wheels are spinning at different rates in a way that shouldn't be, so the computer thinks a speed sensor is bad and deactivates the ABS system and the cruse control, both of these systems depend on the speed sensors and if I recall correctly throw on the check engine light. If the computer sees all is OK with the speed sensor for 24 hours it will go back to 'normal mode' and everything will work again.
With the tires double check that all 4 were replaced with all 4 brign the same size. Tire sizes use a system of something like 225/70/15 - it doesn't matter what the numbers are, just that all 4 are the same number and they are all equally worn.
Sidenote, I find this car a bit annoying to drive highway w/o cruse control, so much so that I bought a OBD-2 scanner and carry it in the car so I can clear this trouble and regain my cruse control if this were to re-occur (most of my driving is long distances on the highway).
-juice
Two weeks ago I changed to 5w-30 Mobil 1 oil, and that, combined with the seasonal changeover to 'summer' fuel in this area netted me an almost 24mpg tank (349 miles on 14.6 gal - fuel light on for about 20 miles).
My mileage dropped of a bit when I was having oxygen sensor problems last year. This is something that can be monitored using a diagnostic scope (shop), or one of the PC based OBD diagnostic tools.
Steve
Steve
I am assuming that this is not an unusual problem so I would appreciate any suggestions.
YMMV
I'd change the spark plug wires next. If those are original they are long gone (the ones on my Miata only last 30k miles before the engine starts to sputter).
If that fails, what where the codes? If it was a cylinder misfire, again pointing to the spark, I'd change the ignition coil, about $80 from on-line Subaru wholesalers.
-juice
Anyone know what the mileage Subaru recommends replacement of the timing belt for a 98 outback/2.5 liter? Just got a used one without the service records. Called two dealers-one told methat the TB is scheduled for 60K replacement, while the other told me that because it's kevlar, it's replacement is scheduled 105 K miles.
Thanks for any help.
Thanks for your response but, after reading it, I have concluded that you don't seem to have much knowledge of these engines.
After I posted, I did my homework. 2.2 Liter engine requires a new belt at 60K. The 2.5 liter requires at 105K. Why the difference? One of the dealers that I talked with was correct. It's all in the material the belts are made of and the belt that the 2.5L engine uses is made of Kevelar so that's why it doesn't require change out untill 105K.
The link below also confirms this.
http://www.cars101.com/subaru/subaru_maintenance.html#90-99maintenance
Lastly, DOHC or SOHC???? No such thing as a SOHC in a 2.5 liter in 98 or any other 2.5L suby engine that I know of.
Bob
so why do CA cars need timing belts changed at 105K and others sooner?????? I'm sure they don't make them of different materials in different markets! even in 96 when there were only 2.2s, CA cars needed belts changed at 105K and all other 49 states at 60K. there may well have been a change of material in the belt at some point but it had nothing to do with why they extended the interval. its pretty much an arbitrary thing but in CAs case, its mandated to be above a certain mileage to meet their weird emissions rules - what timing belt changes have to do with emissions, I have no clue! But just like they have "3K" oil change intervals in the US and several times that for the same engine in the rest of the world, its all rather arbitrary and dependent on what the local market expect with a little pinch of local regulations added!
this topic about the difference in intervals for belt change has actually been discussed in the past on this forum.
even Cars101 (a great site but hardly the holy bible) show 2.5 SOHC engines exist in outbacks from 98 MY. the 2.5 was initially all DOHC, then sometime about 2000MY they all went to SOHC and has been that way since for naturally aspirated engines and all 2.5s today are SOHC except the 2.5 turbo . this has also been discussed in numerous threads previously.
1. A/F SENSOR (IT'S A 02 SENSOR IN A WAY ) THIS IS FOUND
IN THE EXHAUST JUST IN FRONT OF CONVERTER IT WILL RETAIL
FOR ABUT 130.00
THIS SENSOR PLAY A HUGE ROLE IN AIR / FUEL RATIO (IE A/F SENSOR ) IN 2000 SUBARU DROPPED THE AIR FLOW
METER AND WENT WITH A/F SENSOR "IT'S BETTER" NOT A CHANCE THESE BOSCH SENSORS ARE JUNK !!! WHAT'S YOUR FUEL MI LIKE YOU SHOULD GET A LEST 20 MPG IF NOT THE A/F SENSOR IS DONE
YOU SHOULD FIND OUT WHAT CODE IS IN COMPUTER I WOULD PUT MONEY ON A A/F RELATED CODE LIKE A P0127
ALSO A KNOCK SENSOR COULD CAUSE THIS BUT YOUR CAR SOUNDS A BIT EXTREAM FOR THIS
HAVE SOME ONE SCAN YOUR COMPUTER .
I WOULD REC TAKING IT TO SUBARU IT WILL BE COST LESS IN THE LONG RUN .
IF THERE IS A BLACK GOOP TAR LIKE STUFF ON VALVE STEM
THIS COULD BE CAUSING A VALE TO BE STICKING/DELAYED CLOSING UNDER RPM ONLY
ALSO SOME THINGS TO CHECK DID YOU NOTICE YOUR PROBLEM AFTER ANY ENGINE WORK WAS DONE CAM SEALS CRANK SEAL TIMING BELT i HAVE SEAN A EXHAUST CAM OFF ONE TOOTH CAUSE THIS PROBLEM I KNOW YOU SAID YOU PUT A 100 PARTS ON THE CAR BUT DID ANY ONE CHECK THE COIL DUMP SOME WATER ON IT WHEN IT IS RUNNING THE COIL AND IF IT LOOKS LIKE A THUNDER STORM
YOU HIT PAY DIRT GOOD LUCK !
But, lets be fair to cptplt. If you have information that can be substantiated that a SOHC 2.5 liter exists, Im always willing to learn something new.
cptplt,
Your comments on CA emissions/timing belts/oil changes have made my head spin. I just couldn't understand what it all meant with regard to 60 replacment of the 2.2 liter vs. 105 K for the 2.5 liter. You may be right and the 3 Subaru service departments that I talked to (spoke with the third yesterday) are all wrong about the 2.5 liter belts being made of a different material than the belt being used in the 2.2 liter engine. But, the 2.5 liter engine belt is replaced every 105K.
