there was one occassion where it seemed like once it started I turned off the ignition but the engine kept running!! That happened only once and never again. that seems like a ignition key switch problem but are the other times a starter problem or something?? had plugs, wires replaced at 120K. battery is new and charging properly
-mike
I recall that it happened more in warm weather.
The dealer said both the clutch and slave cylinder needed to be replaced. And wiped out 600 subie bucks! :mad:
Jim
-mike
So... I tried to put in a 20v fuse in the FWD switch under the hood, and nothing happens. There is no FWD light on the instrument panel, and the same thing happens on sharp turns. What should I do? Is there something I missed in attempting to switch to front wheel drive? Should I worry about the seperate branded tires or just live with it? If I leave it will it mess up my transmission and rear differential?
HELP!
Also, I have a cylinder 4 misfire. Any thoughts on that?
-mike
When I first bought the car, I had rotor warp(f and r)in about 5K. Dealer fixed (Turned) under warranty. This happened several times again, being fixed under warranty up until about 35K.
At one point, the (then) service mgr took me aside and said the rotors were defective, SOA knows, but little was being done. He then replaced the rears gratis.
But I still continued to have probs w/ fronts, until after a couple of posts here, a great gal from SOA NJ contacted me and put me in touch w/ West Coast rep (young guy, can't remember his name) who test drove car and agreed rotors were warped and offered to replace gratis if I picked up labor. I agreed, then asked tech at dealer about the P/N and he suggested that the new suffix meant a new type of rotor.
Well, these worked great, until I replaced the stock pads with a "hard" compound at indie shop, which scored the rotors and made 'em squeal. So back to dealer; he tells me rotors n/g, replaced them and pads. Took old ones home, miked 'em, 'n lo n' beholed, still good to grind. Stash for later use. BUT, new rotors developed warp; so back to dealer, he turns and replaces pads again. Now after about 6K, rotors warped again. :confuse:
Whiskey TangoFox, I say... WTF???
I'm thinking somewhere there was an old style pair of rotors that made it to my car...
1) Take the rotors you have at home, go over them with a piece of sand paper to clear them up.
2) Get a set of good ceramic pads such as Akebono Pro Act pads
3) Put the Akebonos on with the rotors you have off the car
This should be good for now, then take the other rotors that are on the car off and sandpaper them and stash for later.
Rotors on these cars usually last 50-70k miles, pads about 20-35k depending on driving style.
-mike
If either pair is new enough, buy 2 new ones to match and be done with it. It was a mistake to replace only 2 tires, no doubt. The AWD is full-time so it is constantly wrestling with the tires trying to engage when it shouldn't.
Change them ASAP.
Misfire - do you have a code? At 112k miles, it could be any of several wear and tear items. Start with the spark plug and don't forget the wires, too. The fuel filter, PCV valve, air filter, next. Finally, if you still get a Check-Engine Light, swap out the ignition coil. Sounds hard but it's very easy, and it's only $80 for the OE part. There's only one, too.
You're close enough to 120k miles that I would just do the 120k mile service early, and that involves changing all the things I mentioned anyway.
Cheers. :shades:
Right now I'm pretty upset that after all the talk by the auto dealer I got this from about how his technicians wouldn't have overlooked anything in getting this car ready for sale the car can't even run safely on the tires it came with. And I'm suspecting that they just slapped on some cheap autolite spark plugs, too, instead of NGKs. The code was 0304 (I forget the first two letters, but it was a cylinder 4 misfire...) I also heard it could be a problem with cylinder 2 manifesting itself in a misfire of 4, but I'll save those unusual scenarios for after the swapping of the new spark plugs and wires..
Seriously, I see them under my hood to this day. Not sure why they love Subaru wires, do they baste them in au jus at the factory? :confuse:
I'll stick with my recommendation to change the wires, plugs, and then maybe the ignition coil if the light stays on.
I would think there would be a factory procedure somewhere for testing the coil pack before just dropping $80.
Plugs and wires are great maintenance tasks and it may be due for them anyway, but now you are talking about $30 for plugs, $40-50 for wires, and $80 for the coil pack. Thats $160.
I realize when doing backyard stuff, some of the money that would've been spent diagnosing the issue is spent on replacing probable suspects, but its still good to test what is testable, IMHO.
But in a previous post, I believe it was you that mentioned something about "mountain rotors"; what are they? Aftermarket?
BTW, Mike, where does one look for P/N's on rotors?
Grazi
-mike
-mike
Thats totally cool I can appreciate that. In my mind, preventative maintenance is different then repair, and I don't like spending money on repair parts unless I know its going to fix my problem. $160 is pretty easy and cheap, but if you are out that cash and you still have the issue, it starts to not look like such a bargain.
It also comes down to how sure someone is that its the problem. On the Honda, I dropped $60 on the main relay when it wouldn't start after sitting in the sun because I was 85% sure it was the problem, so if this is a similar case, then its very valid.
If you have the service records, find out if the timing belt was replaced, fuel filter, fluids, etc. It might be a good time just to give it a good flush to set the ticker back to zero.
I was going to look at buying a replacement '96 yesterday (green, just like my old one!), but was too slow in contacting the seller.
-mike
Plugs are a pain on the Forester, as there is no clearance on the heads. Same with wires.
Once I'm in there, I'm changing them, no question.
To remove them, gap the plugs, wash my hands, clean the plugs, then reinstall would take a lot of extra time.
I may waste more $ and parts but you're wasting a lot more time and human energy.
I guess those are the trade-offs, and neither strategy is perfect. :sick:
I would probably check the wires before doing anything at all with the plugs.
I've removed some pretty worn spark plugs after 30k miles of duty.
I have had bad plugs on my '69 pickup before. Changing them was like buying a new truck! It was all my fault though - just was not using it much and lost track of how long they had been in there!
Check out the driving experience threads if you want balanced commentary. Even then, people seek out forums like these to complain.
TY:)
Is this normal? Unfortunately, I did not check the oil level right after the oil change.
Chaki
-mike
If you don't see anything strange, it's normal.
The problem was that the driver's side floorwell was getting soaked with water whenever it rained. The ceiling was always dry.
The dealer found that the sunroof drainage tube (on the driver's side) had become disconnected. Rainwater was bypassing the drainage tube and flowing into the floorwell. Once exposed, it was very easy to simply reconnect the drainage tube, but it was a lot of labor to get to it. For one thing, they had to remove the dashboard. Total cost of the repair was $305. Ouch!
They said that over time, the tube can work its way loose. Unfortunately, there are no maintenance bulletins (to my knowledge) that warn about this -- probably because it happens mainly in older cars that are out of warranty.
When I first called the dealer about this several months ago, they said there were no maintenance notes or bulletins that addressed this problem. I'm going to report this to them, with the hopes that they record it as a maintenance issue, and so that maybe they can look into redesigning it.
I realize I'm being ridiculously optimistic that they'll care, but I have nothing to lose.
-- Peter
1. We are usually driving on the highways, over 60 MPH for an extended period of time.
2. When we start to slow down for an exit or traffic the temperature gauge slowly increases until eventually reaching the top.
3. The heat coming into the car does not work, only cold air comes in, even though the engine temperature guage says "Hot" and we had been driving for hours.
4. After sitting and waiting for the engine to cool, usually waiting over 15 minutes, the car returns to working correctly: we have heat and the engine temps are normal.
5. There is plenty of coolant.
Any help or advice is appreciated. Even a pointer of where we should start when replacing parts. Thank you!
Someone on here had a bad waterpump recently on a 96 legacy/outback with similar symptoms.
-mike
Check for a head gasket problem first, then if no symptoms are found, go for the water pump.
