Good luck with it, regardless. I have to remember how many miles you said you have on it, but it seems like it was between 120 and 130K. There is, potentially, quite a bit of life left. This is coming from an owner of a 220K mile '96 (and it could have gone for quite a few more).
The symptom you describe does sound like the coil is cracked (small plastic box mounted on top of the intake manifold). Those are incredibly easy to replace; I think they cost somewhere in the neighborhood of $80. Juice could confirm that, his experience with chipmunks makes him a master of knowledge in this regard... :P
As for the gaskets, that must be another issue. I do not think there are any gaskets involved with the spark delivery.
Hopefully another member can provide you more insight into P0160 specifically.
That wasn't it. After investigating I found a chip munk had chewed up some wires under the hood! Needed new plug wires and a new ignition coil.
Car ran fine for 2 years after that, all with the original 02 sensor.
In some vehicles, OEM uses PWM + (dim plus) and PWM- (dim -) to light up all light bulbs for radio buttons. Note that the dim- wire is isolated from GROUND to isolate dim noise from affecting radio performance.
So with the VR3 connected, did you get the radio buttons lighted at night? Note that if you do not hook the dim+ and dim- to the VR3 radio, it should work but without the back lighting of the radio buttons. Doing so may get you back the Tach/Speedometer lighting. You could have blown the fuses during the process.
jt
All those hoses need and air tight seal, or it will throw a code, some even will disable the engine so it won't run.
I found out by accident, while installing a hitch, I did not connect the hoses properly. I re-connected them and that resolved it.
You might want to get some other quotes for a rebuilt transmission 4k sounds a little high.
The climate control has a mind of its own, that was discussed a lot when the 2005s came out. Go to the 05+ Legacy/Outback thread and ask there.
The wiper blade refills for a 2004 Toyota Corolla are an exact fit for my Outback, and cheaper.
My car is Moss Green with the Tan interior. Living in Canada, with lots of snow and slush, I tried the Subaru rubber mats to try to keep the carpeting cleaner, but found when you parked on a slope, all the melted slush from my boots would drain over the back of the rubber mats and get the carpet dirty anyway so I did a couple of things.
One, I bought a set of black carpeted Outback mats. With the black dash and upper door mouldings they don't look out of place, and are much better at hiding the mess.
Two, I kept catching my foot on the floor mat retaining hook and rather than waiting till I broke it I cut off the "hook" with a hacksaw blade leaving enough of a stub to make sure the mat stays in place.
Thirdly, I bought some vinyl floor runnner ( in the carpet section ) from Canadian Tire and cut a piece approximately 9"x41/2" and used some silicon to hold it in place over the drivers footrest. The little piece of vinyl the factory used didn't do much, and the tan carpeting soon got filthy. This black runner has some light ridges in it that lets water run down, and I left it long enough so that it goes out onto the floor mat.
I don't like rattles so I bought a square of white adhesive back felt from a local craft shop and lined the glove box. I couldn't get 100% coverage because of all the curves/angles, but it certainly helped. Being white it also helps my middle aged, bi-focaled eye sight find what I'm looking for!
I try to do as much of my own servicing as I can, and have been doing so for 35 plus years. I use a set of ramps for oil changes but found that, because of the angle, when you remove the oil filter you get oil down onto the exhaust. To stop this mess I made a shield out of 3" heat duct that I bought at Home Depot. I cut it to approximately 10", and notched the top corners about 11/2" each way to fit around the oil filter housing. The duct isn't snapped together when you buy it, and this allows it to stay in place just through tension.
I have photo's of these modifications but am not sure if they can be posted. I don't mind being e-mailed but I'm not sure if that's allowed?
Perhaps the host can help??
Nigel
http://www.cars101.com/subaru/airfiltration.html
Alland
You can also use the '08 wipers which don't have the little spoiler on it and they should be the same price as any wipers of that length.
-mike
-mike
I only bought 4 of the 8 volumes.
See if you can find it online at 1stsubaruparts.com. They also accept Subaru bucks you earn from a Subaru credit card. The bucks can be used for parts, service, or towards a new car.
Jim
Has anyone seen this in the '08 Outback? I am considering an Outback XT Limited, and would not appreciate like turbo stutter, etc. in a nearly $34 K automobile.
The only stutter complaints I've heard were from the clutches on late 90s models.
The WRXs and Legacy GTs and Forester XTs I've driven were all very smooth, in fact I'd argue the turbos are a bit smoother than the normally aspirated engines.
-mike
Billb8
thanks so much.....
-W.
I own an '06 Legacy SE with the 2.5 engine. Lately, the engine has been making a lot of noise for the first couple of minutes/miles when driven after sitting idle for a long time (like overnite). When I say a lot of noise, I mean a LOT of noise. So much so that people turn to stare at it as it passes down the street. I don't know if the colder weather may have something to do with this but I don't remember having this problem last winter.
Does anyone know if this is normal or is ist something I should be concerned about?
Also note the alarm hints mentioned above.
I'm a bit surprised it's not also throwing a check-engine light. No light?
Subaru has long said not an issue and won't change pistons. I think I just hit a good day when I brought it in and Subaru happened to be curious on if it really was OK. If I recall somebody else on Edmunds also had piston replaced that same week as I did.
If the lower rad hose is cold it means that coolant isn't flowing into the engine. I'd say the thremostat but you said you checked that already.
If it were an air bubble it would manifest itself as a cold upper rad hose, not a lower one.
-mike
-Wes-
Anyhow, the steering issue makes me think worn tie rod ends. Is it a fast side-to-side motion, or does the car just randomly drift back and forth in a casual fashion?
