One of the maintenance items I didn't see listed there was changing the brake fluid, which is listed as a 36 mo/ 36k service in my manual. This helps the master cylinder and prevents corrosion in the calipers.
I am also not a fan of the $99 fuel system service, as it seems to be no better than the $5-10 ones you can pick up from any auto parts store. I also think the mark up going from standard plugs to platinum is excessive, since there are only 4.
I sincerely appreciate the advice. What do you think considering that:
1) the checkup was done by a Subaru authorized dealer/garage - they are typically much more expensive - I would use an independent garage and have found a few good ones that handle Subarus in the same area. The cost at an independent nearby will probably be at least 1/3 less.
2) the leaks are not significant - they should be addressed soon, but the car drives very well - and the leaks are probably common for a car that old - remember that it's a 2000 model year.
3) one of the most important things, cylinder compression, tested excellent
4) cosmetically the car is in in excellent shape inside and out - one tiny dent in the bumper
5) I can buy the car at $1600-2100 below book ($1600 if you consider the car in good condition, $2100 if excellent), the garage thought it was in pretty good condition.
6) agree with you on the fuel treatment - would do myself
7) I need a car ready by the time I'm local around June 15, so I've got to find one now, get it inspected and do the repairs/maintenance before I'm there (by having the seller bring the car in to the garage of my choice as part of the purchase).
Note that I'm not challenging your advice, I really appreciate it, just giving you more data points so you can help me make a good judgement call.
More information is always good when you are making decisions or giving advice. I guess my main concern is that model's prone to head gasket issues, and coupled with the oil leaking, has me concerned about the longevity of that motor.
While the compression test provides a vote of confidence, I would be more interested in the results of a cylinder leak-down test than a straight compression test (it can get at head gasket issues). If the gaskets are leaking internally, then that gets into the oil (which should be noticeable as the oil is milky in color), that can also mean inadequate lubrication and damaged internal bearings.
Motor replacement (rebuilding, buying a rebuilt motor etc) is about $5k (but would include repairing all of the other maladies listed as well).
I also noticed you mentioned bluebook, but there are different pricing schemes there. Are you talking about wholesale bluebook, private party pricing, or retail pricing? I have found some of their pricing to be optimistic as well. You might want to check the edmunds pricing, blue book pricing, and NADA prices to get a range. Pricing also varies regionally. The pacific northwest, the bay area in CA, and certain areas in the midwest or anomalies for pricing.
I think its smart to do what you are doing and researching the vehicle's needs and pricing, its much better to go in knowing what the risks are, even if the risks are worth it.
I really appreciate the advice.
How does the shop do a cylinder leak-down test? Would this have been done while they were doing the cylinder compression test? How much does it cost/how long does it take? Would the technician who worked on the car likely know the condition? I spoke with his boss, not with him. I can try to catch the tech tomorrow.
I checked blue book pricing for the Bay Area for a car of this mileage and year.
LIST (any used car just bought should get the following, unless you know they were done within the last 3-6 months):
- Coolant drain/fill
- Add Subaru coolant conditioner
- ATF (Automatic Trans Fluid)/Trans drain/fill
- Fuel filter
- Replace timing belt if over 90,000 miles
- Front +Rear Differential fluid drain/fill (though often don’t need anything)
- Replace Spark Plugs (every 30K in non-turbo Subaru engines, unless it has platinums and is under 100k)
- Replace Spark Plug Wires (if applicable)
- Brake Fluid Flush and Change
- Brake Pads inspection and replacement if necessary
- Brake pad rotors if needed (fine if look good and not felt)
- Fuel system flush – could be done with $4-5 bottle of fuel system cleaner
- Power steering fluid drain/fill if fluid is discolored (reconsider price/purchase if power steering fluid looks bad)
- Replace Tires if necessary – for Subaru Outback AWD, make sure all tires matched for tread, tread depth and size
Notes:
- The Owner's Manuel should have a list off all of the required maintenance and when it should be done. Follow the listed services and you should have a good vehicle that lasts many miles
- If there are good maintenance records, much of that may be up to date. I would say that the three most commonly skipped items are coolant, transmission fluid, and fuel filter. If the vehicle has >90k miles, I would also have the timing belt replaced, if it has not been already.
- The timing belt. If there is no documented proof that the timing belt has been changed, consider it original. Average mileage for any FY 2000 car is 100,000 miles; so, the timing belt is due. When the timing belt slips, expensive harm will occur to the engine.
- Replacing coolant and make sure you get a hold of Subaru coolant conditioner whoever performs it. Timing belt is due. Tires are very important that they are matched in wear/size/make/model. Plugs are every 30k in Subaru non-turbo engines.
- Power steering & fuel system flush both are "wallet" flushes, don't bother.
- Oil change - That's the *first* thing, unless the previous owner has a receipt from a fairly recent one I would assume it's been let slide in anticipation of selling. Brake pads can be inspected and only need replaced if they are worn out. Rotors should be fine if there is no problem seen or felt. Differentials probably don't need anything. Fuel system should be left alone. Power steering fluid should be left alone unless it looks bad, and then you might want to reconsider the whole purchase, or at least the price.
Does this sound right? The brakes make a loud sound when you press on the brake pedal.
What if the seller has receipts?
Even so.
For instance, I bought an 8 year old Miata, and got receipts for the 30k service, including a gear oil change.
I changed the gear oil in the gearbox, and that was indeed OK.
But when I went to change the fluid in the rear differential - oops. They missed that.
The stuff looked like melted chocolate.
So even with the receipt for the 30k service indicating all fluids were changed, they had not changed the rear diff oil.
At least inspect things like that.
If the head gaskets are leaking on a 2.5 motor, it's going to have to come out.
Given your list, I wouldn't pay more than $1,000 for that car, because I'll bet you you'll be in it at least another $5,000 before you're done. And for that amount, you can just go buy a nice late 90s Subaru Outback all ready to roll.
It is an interference design but no Edmunds member who owns a Subaru ever reported a belt breaking here that I know of.
Tire size is very important on a Subaru.
the mechanics at Askim's have a running gag. One asks out loud "When was the last time you checked your oil level?" and the other two chime in with a loud "I DON"T KNOW"......the 2.5 will burn some oil.
But a 3.0 manual shift car would be very tempting.
I really don't like the 3.0 auto trans I have to say. The erratic shifting takes all the juice out of that engine. You have to shift it manually to get the benefit of the .5 liter, IMO.
Indeed, I think the manual calls for an inspection at that mileage.
If you open it up, may as well change it.
I am not sure what you mean by erratic shifting. I am very pleased with mine, but I don't expect it to be a sports car. Pleased, if I ignore the fact that I am on my second transmission at 36K miles, that is.
I'd have bought a 3.0 if one had been available with all the reconditioning the 2.5 had.
If you hear it all the time, check the intake to make sure the intake silencer snorkel thingy has not detached.
It actually had a name - the Phase I hum.
The thing about turning the rotors when you replace the pads is in line with conventional wisdom. The new pads need a new surface to seat properly and bed the pad into the rotor. In real life, I have done pads without rotors with no ill effects, but its not recommended SOP.
I picked up a 2008 Legacy 2.5i Special Edition at a great price at the end of January. Great car, and I'm scheduled for my first service this Thursday. I've got a couple of things I want them to look at (in addition to the recommended oil and filter).
1. My headlights are slightly out of alignment. I've never had a vehicle with lights as bright as these, and since they are so bright, it's quite noticeable that they are out of alignment, albeit by just a fraction.
2. I have an annoying squeak coming from either the driver's seat or the center console (it's really hard to pinpoint exactly where). I think it may be the seat since I can hear it after any movement (turns, starts, etc). It does sound like it's coming from the console though (maybe rubbing?) so that's why I can't be sure. Note that I'm an average-sized guy :-)
Just wondering if anyone else has had these issues (couldn't find any reference on this forum)? I'm sure they'll be able to fix the headlights (unless maybe the adjustment is so minimal that they can't), but it's the squeak that's really bugging me.
Dave
It's really meant for when the vehicle is being towed, or for when you get a flat tire.
Inspection is actually every 30k miles. Takes less than 5 min by removing one side of the timing belt cover.
-mike
Only meant for low-speed, short distances. Also it may not save you milage, you still have to drag around the rear diffy and turn the gears and drive shafts, so this will just put more strain on the front driveline.
-mike
I have a 2005 SOL with about 83,000 miles, purchased in Nov. of 04. I think this seems to be a bit odd for only a almost 4 yr old car even with 83,000 miles. My check engine lite came on took it to the dealer and was told for $6300 I would need to replace my Cat. I had them reset the code, it came back on after about 400 miles, then off about 40, then on again about 2, this is very disturbing. Is there anything I can do without shelling out for the new cat? Maybe if I used a premium gas for a while or have something else checked to rule out that the cat is not bad, I can't believe that it would fail so soon. I feel like I purchased a lemon due to other problems prior with the air conditioner and 2 batteries. Please give some alternative solutions or let me know this is not as odd as I believe. Thanks Kat
CARFAX is good but it can miss accident damage, so I'd certainly have the car on a lift and checked out. I've seen cars with as many as 3 major accidents, with no CARFAX records showing whatsoever. One BMW had the whole side caved in (friend's car) but the CARFAX on the car is clean. But with one owner, car is probably just fine.
Also keep in mind that on Subarus if tires are worn you must replace all 4 of them. So if you have two worn tires and two good ones, you are still in for 4.
Visiting Host
Please help!
