Sounds like the throwout or pilot bearing. You need to drop the trans to do them, so might as well change them along with the clutch as well.
-mike
It's illegal for junk yards to sell used catalytic converters.
As for price it should be around $1500 for a new one, installed.
As for warranty, the emissions warranty is 80k IIRC.
I'd personally buy a generic cat and have a muffler shop swap it in for the stocker.
-mike
I have an 05 LGT 5MT Wagon and I regularly track it on the road courses here in the Northeast. Just rolled over 57k miles, no issues so far! Just got back from 2 days at Pocono Raceway, did a few back to back sessions so I was pushing it to it's limit for about an hour straight right up to redline several times a minute!
-mike
-mike
Plug Replacement
Air Filter
Oil Change
Coolant Change
Drive Belts (Alternator and A/C)
If you haven't done the 30k, then I'd get done also:
Trans/Diffy Fluid Changes
Brake Fluid Flush
Fuel Filter Change
As for altitude adjustment, the ECU will compensate for it w/o any external adjustments.
-mike
Wow...that's a lot of moola.....I would think that when I got new brakes, they put in the new brake fluid. Wouldn't you....or is it not a mandatory thing.? What do you think this all might cost ????
It shouldn't cost a whole lot. The shop I own we do a 30k/60k which would encompass all of the above for around $400 or so.
-mike
It is drive belt replace, air filter replace, spark plugs, fuel filter....$383.
We are actually in NJ
-mike
Margot
HI, I looking foward to buying a 2005 Legacy 2.5 XT Limited and I'm wondering can I use 89 midgrade fuel in the turbo?
I know it might cause a drop in performance, I'm really not worried about that, I'm worried if I mite mess up the engine? :sick:
-Thanks
I'm planning to change the rear wiper motor for my 1996 outback -- I have removed the 5 or so pins under the molding, thinking that that's all I need. However, the molding still would not come off! It appears that the molding is one large bottom unit including the plastic "shield" that wraps around the wiper motor from the inside.
Does anyone have any idea on how to remove it?
sorry if you have covered this item b4, but i didn't see it. i need to get at the fuel lines on top of fuel tank on 91 awd legacy wagon as fuel is practically gushing out when car is turned on. no, i am driving it at the moment! i assume i have a corrosion induced break in a line up there as fuel is running down off front of tank. my big question is: is there is an access panel in this model too - like you referred to in 96 legacy sedan. where exactly do i get at it from above. if no access panel, can i cut one? removing tank on this model, esp considering its age and condition, looks just about impossible, and way impractical.
thx
bob
The lower boost engine in the WRX and Forester "recommend" premium fuel, but the higher boost Legacy and Outback turbos require premium, i.e. 91 octane.
You could mix half 89 and half 93, to get 91, but I doubt it's worth the hassle for a few pennies.
I've opened the one in my 94 legacy a bunch of times.
-mike
JDM front clip for the previous generation Impreza STI? EJ2.5T I think. 300hp
Is it worth it? Of course not, but I don't think 3k on a supercharger on a 6 year old relatively inexpensive car is either.
It's in the manual but, 30k intervals check the timing belt. 105k interval change the belt.
-mike
Trade it in for an 05 LGT.
If you must keep it, do suspension, tires, brakes and you'll be faster w/o adding any power. There are no superchargers for the car. The only viable upgrade in terms of power is a motor swap with a WRX either 2.0 or 2.5 Turbo motors. However all the components needed to do a complete swap with labor runs in the $8-10k range.
-mike
This has a list of engines, makes, and models. Not sure on reliability, but it's a start.
I took the battery to Autozone for a complete recharge and test. When I put the battery back in the car it started and ran just fine--I had it on about 30 minutes. However, the electrical system and brake warning light still remain on, even after turning the car off and restarting again.
Is this just a computer quirk or could there be a problem with the alternator or something else? I've had no problems before and the battery is only about 9 months old. I'm planning on getting it checkout out either at a local mechanic close to my office or at the subaru dealer. Any ideas about what might be going on and what I should do. Thanks for any help.
-mike
-mike
Greg
No ones seem to have found this rattling sound that I hear- especially when you are starting to slow down and the car starts to idle again. Funny enough, I was running the other night and I heard the infamous 'Subie" car sound coming up behind me. Then, as it passed, it made the same tiny rattling sound!! With very little mechanical backing, I would guess the heat shield and something in the muffler. Any other thoughts?
I am not about to take it back to the dealer for hundreds more dollars- just curious.
"Funny enough, I was running the other night and I heard the infamous 'Subie" car sound coming up behind me."
What's the infamous "Subie" sound? Is there something that's mechanically prone to failure?
The rattleing is in fact a heat shield you will hear it in the 100-120k mile area and is fairly common on the subies.
-mike
-mike
I suppose as long as your repairs are less per year than a year's worth of car payments, you're good to go.
running?
Visiting Host, Subaru owner as well
A year ago I left the car sitting in my driveway for three weeks. After that while driving the ABS light came on and the gauges fluttered. Then the car suddenly stopped running. I brought it to an independent garage. They told me the alternator was not charging. They replaced the alternator and the battery. After only a few weeks it quit on me. I was out of town and I brought it into a CT. They tested and told me the alternator was not charging. They replaced the alternator. A few weeks later it quit again. I brought it a local CT. After testing they told me the alternator was not charging and replaced it.
Then I brought the car into my local Subaru dealer. They tested and told me the battery was defective. I replaced it but the garage that had sold it they told me it tested fine. After that, I drove for ten months without problems. Last week the problem came back. I was on a trip and I brought the car into another CT. They tested and said that the battery was low and not charging. I replaced the battery and completed my trip under some duress because I was concerned the problem would reoccur. Again the garage told me the battery tested fine. I have noticed that the charge warning light does not always come on when I start the car.
We seem to be doing okay after getting the alternator replaced on Monday.
I'll remember the advice from Mr. Shiftright about avoiding jump starting a completely dead battery--it was obvious that the alternator could not keep up with the power demand when I got the car going again.
Greg
Before I take it somewhere to be charged $100+ for checking codes, does anyone have any opinions as to what might make the check engine light come on, go off, come back on, etc.? Thanks.
I'm going to be purchasing a 3.0R later this year, but the standard tires seem a bit small. I was thinking 18 inch wheels (perhaps 7.5 or 8), with something like a 235 tire.
Any recommendations???
