The keyless entry in my 2002 Toyota Solara 4 cyl. suddenly stopped working. I replaced the battery in both my key fobs, but this didn't fix it.
Took to dealership while away on holiday break; they assumed it was a programming issue; after an hour, they said it was not a programming issue, and would have to look further into problem; I declined, and haven't done anything further.
The owner's manual doesn't go into any detail on diagnosing this kind of problem. Any ideas??
Thanks a bunch.
my 1999 honda accord (4 door) suddenly had the passenger side lowbeam stop working. I replaced the light bulb in there and still the high beam works but no low beam. Does anyone know which wire might be causing this and how I can go about fixing it? I am assuming its an electrical issue- all of the other lights work highbeams interiors etc. I am trying to avoid paying an arm and a leg to have it repaired if its something like a loose wire. Any advice would be greatly appreciated. Thanks!
After a couple of cold mornings confronting a dead battery, I thought that the battery was dead. A check showed that wrong.
Last night I was awakened by lights in my bedroom window. When I went out to check, the headlights on my truck were on, although the switch was off. I had to flick the high beams to shut them off. I also had to get up twice more to shut them off - I missed the fourth time and still had a dead battery .
Not being an electrical genius I thought I'd check and see if I need to be looking for a short in the lighting system, or (more likely) a problem with my head lamp switch.
Any ideas???
If your battery has been drained dead dead dead by headlight on for a long time, you may also need a new battery.
Since you can't return electrical parts usually, you are taking a gamble but without any other visible damage it suggests a lot of electrical resistance in the switch itself.
Another culprit might be the headlight switch relay or its connections. Find this relay and see if it's heating up or has burned wires inside (if you can pry it apart without damaging it).
need a little help. I have a 1994 GMC serria Z71 pickup truck. Just replaced 7 year old battery and now the truck if left unstarted for 3 to 5 days...the battery is dead. So I jump the new battery and the truck charges it up fine.14vdc on dashboard meter and confirmed on hand held multimeter. drive it around few hours shut her off starts up fine 3 hours later. Goe on trip and return (3days) and truck is stone cold dead.
I checked all switches, dome lights, underhood lights and all in off posistion. Any ideas?
thanks again...Sargent
Bring the battery back and have it load-tested.
Also, clean up your cables and check alternator belt tension.
Ignition off. Doors closed. Start pulling fuses and putting the ampmeter across the fuse contacts. When you find the one pulling a 1/2 amp or more, that is the circuit with the short. After that, it's a matter of checking (unplugging and testing current draw) the things on that circuit. There is no easy way to find a short.
Unless something else was done to the truck just before this problem started. Such as that new stero rig that was installed. Or the new trailer light wiring (spoken by someone who generated a dead short in a new trailer connector).
When I turn the key nothing happens, no lights, no radio, nothing works at all.
Any idea what this could be?
Help!
kirstie_h
Roving Host
Host, Future Vehicles & Smart Shopper discussions
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
bad battery cables
Do your headlights work?
Buy or borrow a fresh battery, clean the cables with a wire brush and let's see what happens.
Could somebody please help?
I can't imagine the door locks and fuel gauge being on the same circuit though. Makes no sense.
Also you can check the wiring diagram to see if there might be some other junction where these two circuits (or three circuits) cross paths.
LAST THOUGHT--I just had an idea----these three things you mentioned might all happen if the ignition were briefly interrupted, wouldn't they? Let's say your ignition lock was very sloppy and the key had a lot of play in it.
Anita :confuse:
Right as soon as i turn the key to start the car... i loose all power. I will have the
battery cables checked... thank you for you quick response : )
anita
When traveling down the highway, or any road for that matter, all the sudden my dash board will freak out and the needles on all the gauges including the tack, gas gauge, temp. gauge, and speedometer will start fluctuating rapidly. When this happens the brake light, oil light and temp. light all blink in unison. The car runs perfect, never misses or gives me any problems. The lights dont dim or shut off or anything, the dash just seems to go crazy whenever it wants.
Please help me, im totally clueless
A door opens.
You turn the instrument panel dimmer all the way up to max brightness.
You click the lights individually.
None of these work now.
fuses and umber 17 thru 20 isnot hot. i changed bulbs and fuses, but no lights
I'd check the headlight relay but of course it's easy to check the headlight socket where it plugs into the bulb--see if that has current (obviously not)..and work backwards to the relay, and then backwards to the switch itself.
The seatbelt alarm sounds like a bad ground somewhere. Since it's pretty easy for a driver to tell if his seat belt is on, you might look under the seat and see how the warning light gets its signal. Of course we would never want to disconnect that wire.
when it comes to aotos
If that doesn't work - what should I check next?
Not sure on your car if there is a little switch attached to the stem of the brake pedal that activates the brake lights (under the dash, follow the brake pedal up until you see a little switch with a button). Those get loose, fall off, etc. Just not sure if that's how yours works.
Some brake lights are activated by a hydraulic switch off the master cylinder, which is attached to the firewall, lined up with the steering wheel. But check under the brake pedal inside the car first. It will be obvious how it works....push down on pedal, button is released (extended) and is "on" ; release pedal, button is pushed in and is now "off".
If the blinkers don't work either , consider the turn signal switch in the steering colume.
While driving the truck it will start to sputter, you will then lose your speedometer, then the truck slips itself into neutral. It is still running, but just slips into neutral. Then the overdrive light and ABS lights on the dash begin to flash at 100mph. You simply coast off the side of the road, turn it off, let it sit for about a minute or two and start it back up and you are good to go for another 2 days or so, sometimes less, before it happens again.
I've been told that a wiring harness can do this under the drivers seat if corroded, but both dealerships (very reputable ones) have found nothing. I paid $200 plus labor b/c they thought it might be the alternator overcharging, but happened again after I had the truck for only 3hrs. The only thing I can get from them is that all of the codes read high voltage.
Anyone have a clue? I cannot afford to be without a vehicle for a fifth trip into the dealer for another 1-2 wks.
