Honda Civic Si vs. VW GTI
BTW, the Civic Type R has 200hp, right? The 220hp car is the Honda Integra Type R, no?
Mike
Well, I don't have a big problem with the wheels offered on the Type-S either, just stating that for being the up-level version of the RSX, it has essentially the same wheels. Again, as stated before, the 337's were about $22,225 MSRP, about $1,000 less than theType-S MSRP of $23,270, hence the comparison. But, for the price, the 337 has more features and at least definetly looks sportier. The Type-S is pretty bland by comparison.
You compare the output of the engines, yet you don't notice that the specific output is the same for both, 100HP/Liter. Yes, the VW uses a turbo to get that power, but that also allows for a cheap power upgrade. You can get around 240HP out of the 1.8T at about half the cost of getting a turbo onto the Type-S, plus the installation will be much cheaper as well since the turbo is already on the VW. Plus, a good reason fot the increased power int he Type-S engine has to do with the compression ratio. The Type-S has a ration of 11:1, that's pretty high for a street car and not very friendly if you plan to add a turbo. The 1.8T gets by with a less radical 9.5:1 ratio, mainly because of the turbo. If the turbo were removed and the compression ratio increased, the 1.8T would likely still be pretty close to 180 HP. It's just that the 1.8T was built to be a turbo from the get-go and as such has a lower compression ratio to protect the engine.
Yes, the Type-S is slightly faster than the 337. A few tenths of a seconds difference 0-60, but the RSX has a slight weight advantage as well. The 20HP extra doesn't seem to make a huge difference. 20HP should amount to a bit more of an advantage than that. Why are the times so close, the answer is in the powerband. The Type-S's 2.0 has a relatively peaky powerband. The power it makes is up high in the rev range, mostly due to i-VTEC. The HP peaks at 7400 RPM and the torque peaks at 6000 RPM at 142 lb/ft. The 1.8T HP peaks at 5500 RPM and the torque at 1950-5000 RPM at 173 lb/ft. The redline for the Type-S is 7900 RPM, the 1.8T is at 6500 RPM.
So, you can see by the numbers that the the Type-S makes it's power pretty high up in the rev range, whereas the 1.8T has power which is there for 3/4 of the rev range. Not to mention that the torque for the 1.8T is much higher than for the 2.0, this is where the difference in 0-60 times comes from. No matter what you hear about HP, Torque is what does the work, other wise why would truck engines have high torque engines? The torque is what moves the mass and creates the acceleration. Because of the higher torque rating and flat power band of the 1.8T, it is able to keep within a few tenths of a second in acceleration even though the 337 is giving up about 100lbs. to the RSX.
Do a comparison of the 2 on acura's website, www.acura.com, you will see the similarities for yourself. Make sure you choose 2002 for the model year of the 337 because it's not available as a 2003. I feel like I'm making the same points over and over just against different cars. Just seems that in their price class, the GTI's offer many more options than the others and generally have more power as well. Yet again, it all comes down to what you want in a car and which vehicles suits your style better.
And I'm just going to take this space to mention that I am _NEVER_ eating whatever stupid brand of protein bars I've been buying again. They upset my stomach every single time. (they were fine for the first month or two) I am about to go in the bathroom and disembowel myself. Where is the damn Pepto?
From the information I have, the Honda Civic Type-R as it is called in Europe and Japan is powered by a 197 HP version of the 2.0 with an 8000 RPM redline, 6-speed, 17" wheels, and a body package which helps the looks quite a bit. If it is brought to the US, which it probably will, it will likely arrive in this form around 2004 and be called the SiR. I believe this is the most likely case. I doubt Honda would allow itself to sell a Civic with more HP(220) than their own premium sport compact, the RSX Type-S(200). I'm sure there is an RSX Type-R in the pipeline as well that will likely have about 220 HP, but this still puts the SiR at a level below that so as to keep the RSX as the Premium car.
One final thing I've noticed, it seems from the pictures on that website, the RSX with the body kit bears a very striking resemblance to the Civic Coupe, especially in the second pic which doesn't show the distinctive acura front end. This is of course intentional as the RSX is a Honda in the rest of the world, but it gives me a good idea as to what the Civic Si should have been. The same upgrades on this RSX put onto a Civic Coupe with the same 200 HP, 6-speed powertrain would have been a very competitive opponent to the other sport compacts in this class. But then again, our main discussion revolves around the Si and GTI which are both hatchbacks, so this point is mostly moot. Just an observation.
As I said they 'feel' completely different. I agree on that point definitely. If you look at my prior post I stated that the SI was the better handler, AND felt more substantial. But the difference in acceleration is nearly negligable. What's the times 0-60 and 1/4 mile? Probably not much difference. The EX I drove had 14000 miles on it, so the SI needed a little more loosening up at only 1100 miles. But the seat of the pants feel was equal to me. I'm not trying to bash the SI, I think it's a great car for what it is, especially at $16.5K. The i-vtec is great. Smooth as butter, I should know our CRV uses the 2.4L version.
anonymousposts- I don't really appreciate the comments you made against my driving ability. Think about this. MAYBE you should learn how to drive the EX. The SI is faster than the EX, but barely. Nothing like what a GTI is to an SI. Not even close, especially at 6000+ elevation. Unless of course you decide to put NOS in your car. Then to that I say, GREAT! No hard feelings, but I don't believe personal attacks should belong in these discussions. This board was dead for a while, now it's live n' kickin.
inigoco- Go to team honda, that's where I went and they have like 10 or so on the lot.
Just found this, fair comparison since the 2002 SI and 2001 EX(doesn't specify coupe or sedan, but I'm guessing sedan) both tested by Car and Driver. Of course driver, course conditions play in. But at least it's the same mag and testing methods, they take the best times out of multiple runs.
0-60/1320ft times:
http://www.car-stats.com/stats/search/choosemodel.aspx
If you search all her previous posts and read about them, you'll see what I mean. There's no point arguing with her bet. SI <-> GTi or RSX/RSX-S <-> 337 for that matter. And when she took a cheap shot at the Jetta/Golf/GTi implying you can't tell a difference bet. them, that's the whole point of Euro cars! The higher performance version has small clues (a little aggressive body styling, wheels, small badges etc.) to stand out but not overly so in the crowd. This coming from her driving a SI which incidently looks like a Honda Minivan! Or a Focus. Not to mention the RSX looking so plain jane.
But guess what? When I sell my 01 Audi A4 Quattro, I'll be buying a Civic SI. I like the small little car that looks like a minivan but at least I admit what it looks like.
I just checked out the Japanese Honda website. The Civic Type-R has a 215ps (pferdestarke, DIN-hp) 2.0l and 17"ers with 205/45 tires. The Integra Type-R has 220ps and 17"s with 215/45 Z-rated tires. Those cars are equipped so closely I'm amazed Honda bothers to market both.
Mike
But back to the subject...I read in MT that Acura gave Honda the permission to sell a 200hp Civic. This should be a better performing car. It's still a buzz bomb though, i.e. no torque. But should be fun on the flats. Keep it under $20K and it might do well. The reason is that the Neon SR-T will be out soon with a 0-60 time of less than 6 secs and a price tag under $20K. Now, you can brag about Honda reliability and resale value all you want. But I suspect the younger crowds don't care since they're not brand loyal.
The only things I dispute are the 0-60 times and the quarter mile time. 20 HP will not make the car nearly 1 second faster 0-60 and the quarter mile time will likely be high 14's or low 15's with a speed about where he estimated since other cars in this class are have similar quarter-mile times and speeds.
The power rating are what I was more interested in anyway. 220 HP with 152 lb/ft of torque and an 8400 RPM redline seems about right. The gains match up well with the gains from the base RSX to the Type-S power-wise. Anyway, the site is at http://tuneman1.tripod.com/acura-rsx-r.html
if you want to take a look.
And I went to carstats.com and they showed the SI at 8.0 to 60 and the 01 EX at 8.4 to 60. However, 2 other magazines have gotten the SI to 60 in 7.6 seconds. So since we want to take the best times for every car this is what it looks like (in order of fastest to slowest):
RSX: 6.1/14.8
GTI: 6.5/15.3
99 Civic SI: 7.1/15.7
02 SI: 7.6/15.8
01 EX: 8.4/16.7
So as you can see the RSX is faster and the EX is almost a second slower than the 02 SI. 0.8 seconds should make a significant difference in seat of the pants feel. But maybe it was the SI's smoother engine and lower redline that made it feel slower.
That also proves another point that torque doesn't necessarily make a car faster to 60. The 99-00 Civic SI had 160HP and 111 lb. ft. torque but it is faster to 60 than my 02 SI with 160HP and 132lb ft. torque. The 02 SI is producing more torque at around 2000 RPM than the 99-00 produced at it's peak. It would all come down to the driver in the RSX-S vs. the GTI and the 99-00 SI vs. 02. If he takes off from an idle it would probably take a minute for him to catch you and pass you, but eventually he would.
hamproof: To me Honda/Acura/Toyota/Lexus are the best. But I keep it to the Honda/Acura/Toyota/Lexus boards for the most part. And I never said my SI was the best looking car on the planet .. if you have read so many of my posts then you have probably seen me say that I call it my little dust-buster. But I like it whether other people do or not.
pda: What does me being a "she" have to do with anything.
And if you look at the Neon SRT board there is almost NO interest in that car whatsoever because it is still a Neon. A fast Neon but a Neon. They will sell the ones they make without a problem though because of the power. But there's more to a car than that to me or I would drive a Camaro SS.
Supposedly there is a ECU reprogram out there for the RSX already that takes it up to around 220HP. Can't confirm this yet though.
I don't mind the SI's styling at all, it's a contemporary rendition of the hatchback theme. I think it looks better in darker colors. I like the rear end styling a lot. The interior has many nice touches, the seats were great, very supportive and I like the red accent stitching. Lots of room in the back, almost enormous with the rear seat folded. I'm not sure I like the shifter location - no big deal though as it has a nice direct feel to it.
It handled very well in stock form, very tossable - do a few simple suspension tweaks to it with larger wheels/tires and it would be beyond perfect.
As far as performance goes I was suprised how spunky the SI is. I easily got the front tires to chirp in 2nd gear. My modified GTI's performance has totally spoiled me so it's hard for me to be subjective - the GTI (even stock 180 hp)wins hands down, the stock SI's performance is totally acceptable.
Overall the SI is a nice, well designed package, fun to drive, very nice material content, fit/finish and a fantastic value for the $$$.
This is high praise from a VW fanatic.
RSX: 6.1/14.8
GTI: 6.5/15.3
02 SI: 7.6/15.8
01 EX: 8.4/16.7
That also proves another point that torque doesn't necessarily make a car faster to 60. The 99-00 Civic SI had 160HP and 111 lb. ft. torque but it is faster to 60 than my 02 SI with 160HP and 132lb ft. torque. The 02 SI is producing more torque at around 2000 RPM than the 99-00 produced at it's peak. It would all come down to the driver in the RSX-S vs. the GTI and the 99-00 SI vs. 02. If he takes off from an idle it would probably take a minute for him to catch you and pass you, but eventually he would." :End Quote
I prefer to take an average of the times in order to figure the performance of these cars. There are too many variables that can make a difference in the times, not to mention the way different magazines and drivers would launch the vehicles and the fact that some of the test vehicles may be "ringers" which happen to be slightly better than stock or they may be slower ones as well. This also helps us to see how the powertrains of these vehicles make a big difference in how the times come out. Loks at the variance in the times for the RSX and the Si. car-stats.com has a 0-60 time for the RSX Type-S of 6.1s, this is the absolute lowest I've seen for a Type-S, most others I've seen are around 6.5-6.7s. Next, take a look at the 99-00 Si. The times for both, though identical mechanically, are nearly 1 second apart, 7.1s for the '99, 7.9s for the '00. Now, the '02 Si has 0-60 times ranging from 7.6-8s. These are large differences for cars which should be pretty much identical with the exception of the driver. What this shows me is the peakiness of these powerplants. All 3 of these engines utilize some form of VTEC which allows for them to make more power, but it also make it such that the engine makes this power at a high RPM. This comes at the expense of low-end power, the torquiest engine of the 3, the Type-S makes a decent 142 lb/ft at a high 6000 RPM, that doesn't make things any easier for the test driver.
Now, we move onto the GTI 1.8T. car-stats.com has only one time for 0-60, 6.5s, but the car is close enough to the Beetle Turbo S that we can use the 0-60 time from it as well, which is 6.7s. Yes, the Turbo S uses a 6-speed whereas the GTI uses a 5, but for 0-60 it won't make a huge difference and may also explain the two-tenths difference in times as well. Anyway, all the tested times I've seen for the GTI 1.8T have been pretty close, all around 6.5-6.7s. This shows the broad powerband of the 1.8T. This car makes it easy to dive fast, all you do is hit the gas and go, you don't have to worry so much about what revs to start at and all that, you just do it and the car does the hard work for you. This is due to the fact that the 1.8T makes its torque at a very low 1950 RPM all the way up to 5500 RPM. This is why the times for the 1.8T are so much closer than the times for the VTEC powerplants. Any number of test drivers can jump into the GTI and get a fast time, it takes a skilled hand to wring the best out of the VTEC cars. So, now here are the amended 0-60 times for each car, averaged from times that have been kicked around magazines, car-stats.com and on here.
RSX Type-S: 6.4s (6.1-6.7s)
99-00 Si: 7.5s (7.1-7.9s)
'02 Si: 7.8s (7.6-8.0s)
GTI 1.8T: 6.6s (6.5-6.7s)
These averaged times helped me form another conclusion as well. These times are what an average driver can expect to get out of these cars, but it also brings the times of the '02 Si and the '99-'00 Si closer as well. This 3-tenths difference is minor and can be explained by the weight difference between the two models. The '02, though with about 20lb/ft more torque also weighs about 156 lbs more than the old model. This, combined with the likliness of a different test driver for each model tested easily explains the time difference between the old and new models. This also shows the advantage of the high torque of the 1.8T. The time for the 1.8T is two-tenths slower compared to the Type-S, this is not a big difference considering the Type-S has 20 more HP, especially since the GTI weighs more than 150 lbs. more than the Type-S (2767lbs. vs. 2932 lbs.). The only explanation for this is the wide powerband and increased torque of the GTI. So, yes, it does all come down to the driver more than anything, but a car with a wide powerband will make it easier to get fast times.
Base RSX: 160 HP @ 6500 RPM 141 lb/ft @ 4000 RPM
RSX Type-S: 200 HP @ 7400 RPM 142 lb/ft @ 6000 RPM
'99-'01 1.8T: 150 HP @ 5800 RPM 162 lb/ft @ 2200 RPM
'02-current 1.8T: 180 HP @ 5500 RPM 173 lb/ft @ 1950 RPM
Not only did the GTI gain more torque than the RSX did, it also "LOWERED" the revs at which these new gains were achieved.
http://www.vtec.net/articles/view-article?article_id=45231
90% of it's torque from 2000 to 7000 RPM.
The only other explanation for this difference is traced to the transmissions of each car. A lower(numerically-higher) gearing creates faster acceleration and a higher(numerically-lower) gearing creates a higher end speed. Well, Honda does not have the gear ratios for the Si on it's site, but the RSX 5-speed does and for these purposes we'll assume that they use the same transmission and ratios as the Si since they also share the engine. 1st and 2nd gears are the only two used to get to 60mph, so we'll ignore the others. Now, to figure the overall ratio of each, I'll multiply each gear ratio by the final drive ratio in order to get the actual ratio reaching each wheel and putting power to the ground. Remember, a higher number would equal a faster acceleration in a car that was otherwise the same. For example, a car with a 3.88:1 ratio will be slower in acceleration to an equal car with a 4.10:1 ratio. Now, the calculations:
RSX/Si 5-speed: Final Drive - 4.389:1
1st gear - 3.267:1
2nd gear - 1.88:1
1st overall - 4.389 X 3.267 = 14.34:1
2nd overall - 4.389 X 1.88 = 8.25:1
GTI 5-speed: Final Drive - 3.65:1
1st gear - 3.30:1
2nd gear - 1.94:1
1st overall - 3.65 X 3.30 = 12.05:1
2nd overall - 3.65 X 1.94 = 7.08:1
Now, as you can see the Honda 5-speed should be faster than the VW 5-speed due to the ratios I've calculated. The overall ratios for both 1st and 2nd gears are lower(numerically higher) for the Honda 5-speed than those of the GTI, which should relate to a quicker acceleration for the Si especially with the weight difference. Now, the only explanation we have left is the increased torque of the 1.8T. Since we are comparing the 150 HP 1.8T we don't have the HP advantage to use, but the torque advantage is still present. Again, more proof that torque is what accelerates your car.
Compared to the '99-'00 Si engine, I'd say you are right that the newer iVTEC 2.0 in the RSX's and Si is not as peaky an engine, but we are comparing this to the 1.8T as well and in comparison it is still rather peaky. Also, you mention, as I did, that a good driver will be able to get good times out of a peaky engine like the '99-'00 Si engine. This is true, but how many of us are truly great drivers? I have enough no-how to admit that I'm not as good a driver as I could be, better than average perhaps, but there are those better than me. This is likely the case with the large majority of other on this site as well. We "are" average drivers, not great drivers. Because of this, I doubt many of us would find it easy to get the best times out of a peaky engine. This is again where the increased powerband of the 1.8T shines through. Even average drivers such as myself have a very easy time getting good times out of the GTI. I'd much rather have the confidence to know that my car will still be fast even if I make a slight mistake, whereas the driver of car like the '99-'00 Si will have to do everything exactly right just to keep up much less beat the GTI. I prefer the less-stressful quickness of my GTI.
P.S. I had to go to the hondata website to see the dyno sheet you were talking about. Yes, the gains are there, about 20 HP, but only a slight gain in torque, less than 10 lb/ft from what I can tell. Compare those gains to an ECU upgrade for the 1.8T. The 1.8T also gains about 20 HP, but gains about 80-90 lb/ft of torque. APR makes one of the many available and a sample dyno sheet can be seen at http://www.goapr.com/VW/images/dyno_golf_18t_stage_i.gif More info on it is at http://www.goapr.com/VW/products/ecu_upgrade_golf18t.html
With times within a few tenths of a second it's all going to depend on the driver. So let's just call it even. But now that you've admitted you are only an average driver I'll take my chances against you.
And yes if you go by car-stats numbers the 02 SI and the 1.8T with 150HP have identical 0-60 times. But the SI only weights about 80lbs less than the GTI but it has 20 lb ft less torque which you say is the most important factor in acceleration. It's max torque is at 1750 while the SI's is at 5000. And as speed climbs the SI is pulling ahead because it's ahead by .2 at the 1/4 mile.
Like I said, all of this is pointless and could go on for days. It's gonna be up to the driver. Since the VW is "easier" to make go fast according to you all of the bad/average drivers should buy a VW and leave the Honda/Acuras for people that CAN drive.
I drove an the 02 GTI & Si this week. Both very nice. Overall, I liked the feel of the Si better, very tossable and smooth, shifter is very slick & convenient (but then I have owned 6 Hondas still have a 92 Civic Si & Del Sol Si). Yet the GTI has SO MUCH MORE comfort & safety content (adjustable seats, telescoping steering, traction control, more airbags, AM/FM Cassette C/D combo, easy entry rear seats, all controls & switches illuminated, armrest, (I might buy it on that alone), one touch up & down front windows, better warranty... Looks for me are a toss up, I am not crazy about either, but the Si stands out more in a crowd.
Sooner or later I am going to get one of these & it is a difficult choice. My heart says Honda, my head says GTI!
We also have a 00 SI and while it is more fun to drive if you want to race it can be a pain if you have a couple of people in the car and the AC on. But that 1.6 is a dream. The higher the revs go the more fun it is and the better it sounds. But for daily commuting I like the 02 SI. It has more torque but is still immensely smooth and powerful throughout the powerband. And the gearbox can't be beat. Nor can the seats in it's price range.
And the SI can be had new for around $16,000-$16,500 where I live vs. around $20,500 for a GTI 1.8T with the luxury package (gotta have a roof). So for the price and added reliability I can do without the one touch up and down windows (auto down is enough for me) and the other features you mentioned.
On safety, this is actually my second 02 SI. The first one was totalled. A woman coming the opposite direction made a left hand turn and I hit her head-on going 45MPH. I walked away without so much as a bruise or a scratch. It knocked the wheel off of her car, buckled the roof, and crushed the fender. If you look at crash test data the Si withou SAB does just as well as the Jetta with SAB. So if you are going by safety it's equal regardless of the number of airbags.
How can you even lump Honda/Acura in the mix of Toyota/Lexus. Sure you can compare Honda and Toyota. But there's absolutely no way you can compare Acura and Lexus. I'm a big fan of Acura. I believe they are a good value for money. But in no way the luxury part of Acura is comparable to Lexus. A lot of people who buy Lexuses do not cross shop over to Acura. They want the service, prestige and whisper quiet cabin of the Lexus. Acura is value for money and for the competing models, they are cheaper. Acura is for someone who wants a nice car but balk at the prices of BMW and Lexus. Period! When you see the same moonroof switch as well as mirror adjustments in a Civic all the way to the TL and MDX series, you can't call it luxury.
Anyway, I'm surprised you would trade low end torque for higher power RPM. You also claim you drive highway during your commute and you need passing power on the highway. Let me ask you this question. What is your average speed?? If I remember correctly, you said you average maybe 60-65mph daily on the highway, right? At least in one of your post when someone asked you about your mpg. I guess you must live in the boonies where no one drives their car or you go to work or school at insane hours. My current car has a trip computer. I drive 60miles round trip to work daily and I leave for work/home at 6:50am/4:00pm. Even at those times when I drive on the highway (house is 1.5miles away from highway enter ramp and work is 3 miles from the highway exit ramp), my trip computer shows my average speed for the week at 33-35mph! W/o a trip computer I might think I'm driving 80mph average coz' on the highway I'm at 75-80mph and when I pass cars, I'm at 85-90mph. So unless you live in an area where there's harly any cars or you leave at 5am and come home at 1pm or 10pm, there is no way your average speed is 65mph!
Here's why I think you are wrong when you want to trade low end torque for high end HP. When I'm cruising in my A4 (1.8T), at 80mph, it is at 4k rpm. When I pass in 5th. at 85-90mph, it's at 4.5k - 5k. I believe on the SI, it is about the same. 75-80mph is around 4k rpm. Redline is 6.5k. So for you get get to 90mph to pass, it should be still less than redline. So unless you want to spend a night in jail, I suggest if you have to drive more than 90 mph to pass, don't! I would hate to see a little Civic like that hit something at 90-100mph! We'll definitely miss you here I can understand that once in a while you want to downshift to 4th. or 3rd., revved it up a little to feel the sense of speed and pass. There's nothing wrong with that, but the Civic as it is now, will suffice. There's not too many people who want to rev it to say 8k rpm or the insane S2000 9k redline on a DAILY COMMUTE!
Let's just call the Civic what it is. Cheap affordable daily commuter. People who buy VW GTi are usually the ones who have driven cheapo Japanese cars and want something *luxury*. They want nice bolstered seats (02 SI has this somewhat - models prior are just too thin), nice interiors (VW/Audi makes the best interior - there's no point arguing this if you want to. You could but you'll be the minority coz' industries expert says so) and better graded material on the inside. Why do you think the material on the inside of the RSX is much better than the Integra it replaced. With the gen X going for higher priced cars, the gen Y wants something different from what their parents are used to. They have money to spend and most fresh college graduates with their first jobs are not thinking Civics and Corollas. Most want 3 series and IS (Lexus) or GTis and RSXs. Hardly anyone would consider Civics and Corollas anymore.
But guess what? I bought a 95 Altima GLX when I graduated (in 95). Sold it and got a 97 Civic EX in 97. In 2000, I was done w/ cheapo Japanese car and decided to go Euro. With AWD being the criteria (I live in the snow belt), Audi A4 was the obvious choice. But now, I'm selling the A4 and looking to buy the SI. The only reason is because it is a cheap car (sure a Hyundai or Kia is cheaper but I want a car that will last 60k w/o doing anything but oil changes and I can fit 2 golf bags w/ 2 pull cars w/o a problem).
Stop thinking that Civic/RSX are so good. If they are, the annual sales will show it. They are good for what they are. Peace of mind and good value. For the sake of everyone here, give your boyfriend a *treat* and maybe he'll let you near his GS (Lexus) after you wrecked your first SI. Btw, if you think the 00 SI are so great (and I believe you have 2), why did you sell it?? From what you said, they are so rare and dealerships want brand new prices for them and people steal them. If that's the case, why not keep the higher redline 00 SI? Maybe in 5 years, it'll be a classic.
As for my commute .. I leave my house at 8:15 and am at work by 9:00 going a distance of about 20 miles. There are moments where I have to do 45 but mostly I go around 60-65 and sometimes faster if I feel the need. Where I live isn't necessarily the boonies but it's not downtown either. It's a suburban area and I work in a suburban area. When I am on the highway travelling I average about 80MPH or I keep up with the fastest car (which going to FL is usuallly around 85-90MPH. I feel sorry for alot of cars, including the A4, if they were in a wreck going 100MPH.
I've owned a car that had low end in sacrifice for high end power and I hated it. I would rather be in my 00 SI where you shift at 4000RPM during normal driving. If I have a choice between the 2 I'm gonna take high end power. I think the new SI and RSX engines are a good compromise.
The VW may very well have a nicer interior, better seats, etc. but if you don't want it you don't want it. Before I bought the SI there was a red 01 GLX GTI at the dealer where I work .. nice car. The previous owner had it lowered with VW installed springs, tinted windows .. VERY nice car. But I don't know enough people with trouble-free VW's to take that plunge.
I have never said that VW isn't a nice car .. it is .. but until I know that their quality is without glitches I can't see myself paying more for a VW than a Honda/Acura. I coulda leased a 02 3.0 Quattra A4 right about the time I got rid of my old car for the 02 SI but I guess it's just a fear of the unknown that kept me out of it. It was back when they were offering $399 lease deals on them. We were real close to taking the plunge but luckily we didn't.
Why should I stop thinkin the Civic/RSX are so good? To me, and alot of other people, they are. Just as I'm sure the VW/Audi's appear to be so good to you. People are allowed to have preferences. And my boyfriend actually has a LS400 which is a nice car but again something I wouldn't want to drive on a daily basis.
Since you asked, I got rid of my 00 SI because it had been in an accident before I bought it and I didn't know the severity of it. After we bought the second 00 SI I started to notice that my doors didn't close as solidly as the other one that had not been in an accident. This alone wasn't enough to make me get rid of it but when the Honda dealer offered me $12,200 (kbb excellent trade at the time) for a SI with 41,000 miles and offered to sell me the new one for $16,300 .. it was a deal I couldn't refuse.
99-00 SI's are rare on the dealer's lot. Especially one's without serious mods. And some dealers do want brand new prices for a clean SI. Look at www.carmax.com they have one 00 for around $16,598. New MSRP was $17,500. I didn't say people steal them either... I said that the engine is why people usually steal them because it can be used in any other Civic. I've never had one stolen or known anyone who has had one stolen. But I'm sure it happens.
No matter how much you tried to convince "hamproof" that you didn't direct any personal attacks at him (?), the more you failed miserably. And saying things like "....maybe the GTI they tested was broke .. which wouldn't surprise me since it's a VW." is the typical crap that Honda likes to hear people propagate. My sis has a 01 Jetta VR6 with over 30K trouble-free miles on it.
There is no substitute for displacement. The VTEC engines have good power at the top end. But you need a healthy dose of torque to pull. The RSX-R can easily keep up with the 1.8T GTI on the flat as far as 0-60 goes. But as soon as you hit a grade (i.e. going uphill), the 1.8T will start to pull away. Load both cars up with passengers, and the difference will be more pronounced. As stated before, you need torque to pass. With the VTEC, you'll need to down shift. It would take the VTEC more effort to pass. It cannot give you that "pin your back against the seat" feeling.
Hamproof - I disagree with you. The Civic Si is not a cheap car. Remember, this car retailed for over $19K originally (typical Honda arrogance). Only when Honda realized that it was outgunned by the competition that it lowered the price to below $16K. And it's still not selling. If they drop it to below $15K, maybe this "Honda basher" will pick up a copy (and pray that Oscar Jackson comes up with a supercharger
30,000 miles and no problems? Wow, that's great. Now why don't you come back in .. let's say ... 100,000 miles and let us know how it's doing. Honda isn't trying to propagate VW's lack of reliability. Consumer sources like JD Powers and CR do a good enough job for them.
Actually, it's been shown the GTI would be trying to keep up with RSX-S on a flat surface .. not vice versa .. but I digress because that's semantics. And why exactly would the GTI pull away on a grade? That's why they make a thing called a transmission so if you are not in the optimal gear for performance you can downshift .. that's also why the RSX-S has one of the best 6-speed trannys out there. What's the big problem with downshifting? I rather enjoy shifting. Honda/Acura make what are arguable the best manual transmissions on the market so why not take advantage of it?
And let's be honest here .. no 180HP or 200HP is going to give you that "pin your back against the seat feeling". If that could be accomplished with such little HP then the market for 350Z's, S2000's, M3's, etc would be almost nonexistent.
"no 180HP or 200HP is going to give you that "pin your back against the seat feeling""
i thought this "pin your back against the seat feeling" is given to you by torque, not hp.
i used to have a VW NB with the base engine (115hp). but it has more torque and it also comes out earlier. i currently has a 127hp civic which doesn't give the same driving feeling as a 115hp VW NB. i'm sure i know why and don't want to elaborate on what the so-called VTEC means.
i don't have the time to read all the posts before. but i think if you haven't driven a VW or Euro car, you shouldn't make such a comment about "no 180HP or 200HP is going to give you that "pin your back against the seat feeling.""
i testdrove an RSX-S before and i can tell you it won't give you the "pin your back against the seat feeling." like a VW does even the RSX-S has 200hp. of course i'm talking about regular driving and not revving the engine at redline while idling. if you do that, almost every car can give you that "pin your back against the seat feeling." and also if you do that, i don't know how long your engine can last.
but why did i get a honda instead? my VW was relatively problematic. however, if i have a chance, i would like to trade no low end torque/high end power with V8s (larger displacement) or more low end torque because i use it for daily commute and not racing on track which requires an engine with power coming out at high rpm.
especially
"If the GTi will give me trouble free miles for as long as the Civic, who would want to buy the Civic?? We drive the cars we drive because we enjoy driving cars."
"Civic SI is a CHEAP car. Ask any average American walking on the street. What do you think of the Civic or Honda for that matter. It doesn't matter which model which trim. When they hear the Honda/Civic model they assume it is cheap."
and i would like to say when comparing price, try to compare invoice instead of MSRP. MSRP is just a suggested price the manufacturer came out with, not what the car is being traded for. and who's going to pay MSRP for a civic.
"before anyone beats my head w/ a stick for calling the SI a beater. It is to me."
it is to me too. hence that's what i'm using my EX for. a beater.
Case in point; when the S2000's first came out I remember reading the test drive of one in one of the many car magazines I read on a regular basis. In doing the 0-60 testing on the car, they found that in order to get the best times out of it, the had to rev the engine to something like 7000 RPM and side-step the clutch. Not my idea of a good time and likely not the cars' either. They also mentioned that when they tried the 0-60 run in a way that any sane, average driver would they came away with a 0-60 time of about 11 seconds! The only way they were able to wittle the 0-60 time down to 5.2 seconds was to drive the car like they had stolen it. That's what I mean about having to be a great driver in order to be able to drive a VTEC car fast. I would be able to do it, especially in a car that wasn't mine, but for my own car, I prefer to rev my car to about 2000 RPM, just enough to keep the tires from roasting away and then I just let out the clutch and get consistently quick runs. One mistake or too low revs and the VTEC car would be left in the dust. Low-end torque is great!
About the high-end power of the VTEC cars. It was touched on before, but I'll bring it up again. anonymousposts, you mention that the higher your car revs, the faster it is. Well, I agree with that, but VTEC doesn't kick in until about 6000 RPM. I doubt you often find yourself at or above those levels, especially in daily driving. The only times you really need those kinds of revs is for straight-line speed like when you are going for 0-60 times. Even when you're on the highway, unless you're going way above legal speeds or you drive around in a lower gear, your car won't even be using the VTEC advantage. It's mostly a waste unless you plan to rev the crap out of the car every time you take off. Again, this is where the torque of the GTI comes into play. While you're busy fiddling with the shifter, I just plant my foot and go while you go for the VTEC to try to keep up.
About the values of a '99-'00 Si. When looking at the values, I usually check the Kelley Blue Book values rather than a dealer quote because this value will assume a totally stock vehicle, rather than one with a number of mods. This gives a more accurate true value for the car since it's so hard to find one without any mods on it. Anyway, I checked the value of a '00 Si with 60,000 miles and in "Good" condition and came out with a value of $11,810. Not anywhere near the $16,598 you found on carmax.com. This tells me that the car on carmax must have some mods or perhaps much lower milage, either way, it still seems pretty overpriced.
Again on the 150 HP 1.8T vs. an '02 Si. Yes, it will come down to the driver, but you are still missing the point. The heavier car(more than the 80 lbs. you suggested), with 10 less HP, and the gearing less optimised for acceleration was still able to beat the Si. What's you're explanation fro that? The only other variable is the torque which the GTI has more of, so the torque is what accelerates the car and that's why the GTI is faster. You want to look at the 1/4 mile times too, well I can analyze those as well. It looks like you are looking at them wrong or something because I don't see the Si ahead at the 1/4 mile. The times I got from car-stats.com show the GTI doing 15.9@88 mph and the '02 Si doing the 1/4 in 16.2@86 mph. The Si is still behind. Yes, the lead of the GTI may only be 3-tenths at the quarter-mile, but it's also ahead by 2 mph. Now take a look at the 0-100 mph times. The Si gives up 1 whole second to the GTI after the quarter mile is over. The GTI does 0-100 in 21.3s where the Si does it in 22.6.
How do the other cars we've mentioned do in these tests you ask? Well, the RSX Type-S hasa 0-100 time of 16.4s and a quarter-mile of 14.8@95 mph. The 180 HP GTI has a 0-100 time of 17.9s and a 1/4 mile time of 15.3@94 mph. The numbers from the RSX were from the same test that produced the 0-60 time of 6.1s so that explains a lot of the difference. I also happened to find times from the Nov. 2001 issue of Road&Track which have the Type-S running 0-60 in 6.7s and the 1/4 in 15.2@92.7 mph. Even so, we'll look at the faster set. Compare the 1/4 mile speeds for the GTI and the Type-S, 1 mph difference, despite the time difference between the two. That's the higher torque of the GTI talking. Remember that throughout all this, the GTI is the heavier car and it gives up 20 HP to the Type-S.
It just seems that in all these tests and numbers, the VTEC cars can only assume a lead when the competition is at a disadvantage. In all of these tests, the only times the VTEC cars are ahead is when they are against a car with less HP, more weight, worse gearing for acceleration or a combonation of the 3. Though we can't compare them on an equal plane, there is a comparison worth mentioning.
Let's take a look at the Toyota Celica GT-S vs. the GTI 1.8T. Both have 180 HP and the GT-S also utilizes a system very similar to VTEC and has a VTEC-like redline of 7900 RPM. car-stats.com has the stats for an '02 GT-S with the 0-60 time of 7.3s, 0-100 in 19.4s and the 1/4 in 15.6@89 mph. the numbers for an '01 are 0-60 in 7.3s with a 1/4 in 15.5@92 mph. The only close match is the test of a '00 model on car-stats.com. The 0-60 is 6.6s, but the 1/4 is again 15.2s at a still slower than the GTI 93 mph, too bad the 0-100 time was not shown for that test as it would prove the most interesting of the 3. Either way the equal HP GTI beats the GT-S in each test and the Celica is even lighter than the Si and Type-S, it's nearly 400 lbs. lighter than the GTI. The VTEC and VVTLi cars just can't compete with the torque being put out by the 1.8T regardless of HP, the numbers show it.
I said that my preference lies with Honda/Acura/Lexus/Toyota. I never said "Honda/Acura is better but I also like Lexus/Toyota". What I said was that there are some models where Lexus has Acura beat and there are some models where Acura has Lexus beat. Get a grip.
As for my financial future .. you don't know me. And if you did you would know that I am 23 years old with a 401k, a savings account, and 10% of my paycheck going to company stock. The money left over after maxing out my 401k and stocks is free money and I can do whatever I want to with it. And your comment that buying a house is not an investment shows how little you know about financial matters. My boyfriend purchased his house for X amount of dollars .. that house has since appreciated almost 40% of the original purchase price in the 8 years he has owned it. Oh, but I guess that's not an investment. That brings me to another point, with the equity in our house we could go buy a much better car than a A4 with cash and not have to worry about downgrading from it to a "lowly" Civic.
The difference between saying that Civics get stolen alot and saying that if a Civic does get stolen it's probably because the engine can go into almost any Civic from 92+ should be obvious.
If you want to buy a car because all you want is reliable transportation why not buy a Toyota Echo and be done with it. The Civic Si must offer some added benefits or you wouldn't be considering it.
Again, before you make assumptions about what I drive for how long and how many miles let me restate that you don't know me from Billy Bob or Sue Marie on the street. For all you know I won the lottery and am just on here to kill time while my millions accrue interest. On the other hand for all I know you drive a pink Geo Metro with fuzzy dice around the mirror.
As for college grads wanting a Honda .. somebody wants them because the Civic and Accord are the top selling cars in it's class. And last time I checked Hyundai sold more cars than VW so I wouldn't boast about how strong VW's sales are right now.
To those concerned - We realize you may not been aware of this rule. Please check your email for a copy of your message. We invite you to edit your post and copy/paste it back into this discussion. Thanks for your participation.
Revka
Hatchbacks & Wagons Host
From the www.carmax.com website (better check it fast because they usually sell quick)
"'00 Honda Civic Si 2D Coupe $16,998 Black Manual 4 32K "
"'00 Honda Civic Si 2D Coupe $15,998 Black Manual 4 32K"
Why would you check trade values for a 2000 car with 60,000 miles on it? That's 30,000 miles a year. It just shows that you are going to manipulate facts in any possible direction to prove a point.
Where do you get that the 150HP 1.8T was able to beat the 02 SI? Both have 0-60 times of 7.6 (when low-end torque should make the GTI shine) and at the 1/4 mile the 02 SI is ahead by .2 seconds. Another interesting fact is that although the 180HP GTI beats the SI to 60 by 1.1 seconds at the 1/4 mile it's only ahead by .5 second. Again, unless you are a stoplight to stoplight racer the SI would hold it's own. And yet again, with the differences so close together in these cars driver error on either side would be detrimental. But then again, you did say that you are only an "average" driver so I'll take my chances.
The Celica VVT-i is similar to VTEC but not nearly as good. Max power comes on in the Celica right at the rev-limiter. In the 99-00 SI you have a few thousand RPM to work with in VTEC and in the new i-VTEC Honda engines the powerband is way more flexible than previous VTEC variations. I think the VTEC engagement happens around 4200 RPM in my 02 SI on it's way to redline at 6750 RPM.
With one exception. Pretty much even up at 6000ft. Turbos rock at altitude. Don't argue that point unless you've tried it.
The RSX-S puts out torque evenly throughout the powerband until 6000RPM where it increases to provide max torque. Hardly the peaky motor that's being described here. If you look at a dyno for the 99-00 SI you will see that it's torque is also fairly even from 3000RPM up to it's redline of 8000RPM. Here's the dyno for the RSX-S.
http://www.importreview.com/d_2.0.html
Again, on the 150 HP GTI vs. the '02 Si. The numbers I used were the ones listed on car-stats.com which is where they ahave all come from unless specified otherwise. The numbers again from car-stats.com are as follows. The '02 Si has 0-60 in 8s, 0-100 in 22.6s and the 1/4 mile in 16.2@86 mph. The 150 HP 1.8T GTI does 0-60 in 7.3s, 0-100 in 21.3s and the 1/4 mile in 15.9@88 mph. The GTI beats the '02 Si in all of theose comparisons. You stated the '02 Si has a 0-60 of 7.6s, well I found the April 2002 issue of Motor Trend has these stas. They have the '02 Si with a 0-60 of 7.6s, and a 1/4 mile of 15.8@88.1 mph. That's only a gain of 1-tenth of a second in the quarter mile at virtually the same speed. So, yes they are very similar in times from that test, but this again is the 150 HP version, 10 less than the Si and it again weighs about 150 lbs. more than the '02 Si. Now again for the 180 HP GTI, the 0-60 time is 6.5s, 0-100 in 17.9s, and the 1/4 mile in 15.3@94 mph. Those numbers are not as close as you may think. Sure the 1/4 mile time is .5s different, but look at the speeds, the GTI's got 8 mph on the '02 Si, again that's where the torque comes into play. Though the '02 Si doesn't have a 0-100 time, it will surely be longer than the 180 HP GTI since at 15.3s the GTI is already at 94 mph whereas at 15.8s the '02 Si is only at 88.1 mph, it has a lot of time to make up if it plans on beating the GTI to 100 mph.
I will admit that I used a high value for the kbb values, I just wasn't thinking that it was only 2 years old, so I redid them and used 20,000 miles instead and came up with a value of $14,735, still lower than the prices you are finding. i wouldn't buy those cars when the fair value fro them is $1,000-$2,000 lower. By comparison a 2000 GTI 1.8T with 20,000 miles as well has a value of $15,575.
The reason I brought up the S2000 was to show how peaky the VTEC powerplants become when pushed to the limits. I am not denying for a moment tha the S2000 is better than all the other cars we are comparing, but it handles well because of the front-engine rear-drive layout it has. Most any sports car with rear-drive will out-handle these cars, but that's not what we're comparing here is it? You want to see another comparison of note, probably not, but I'll do it anyway.
The S2000 has 240 HP and 153 lb/ft of torque. The performance is again as follows. 0-60 in 5.2s, 0-100 in 13.6s and a 1/4 mile in 13.8@100.5 mph. Now let's find another car with similar stats. Aha, here's a 1999 BMW M Coupe. Similar idea, similar power, similar times? Both cars are front engine, rear drive. Both have 240 HP. The S2000 is about 300 lbs. lighter though(3131lbs vs. 2809 lbs). How are the numbers for the M Coupe. 0-60 in 5.3s, 0-100 in 13.9s, and a 1/4 mile of 13.9@100 mph. Pretty similar numbers and of course respectable for both cars, but again you have to rev the S2000 like crazy to get those times. Here's a quote from the Feb. 2000 issue of Motor Trend magazine regarding the launch technique of the S2000.
"Here's the drill: Push the clutch to the floor, bring the revs up to a hair's breadth below where the rev limiter kicks in (like 8500 RPM), then side-step the clutch and floor the throttle. If you grab each gear a nano-second before the rev limiter hits, you'll be in the realm of our times. Fast, Definetely. Fun, You bet. Hard on your sense of equipment care? Quite Possibly. In fact, my biggest problem with the S2000 is that, to extract even 75 percent of its full performance, you have to (as we wrote in the Sep. '99 issue) "treat it like you hate it." Unfortunately, you have to do just that to really scoot. Remember, there's only 153 pound-feet of torque here and that's at a lofty peak of 7500 RPM. Even the 240 horsepower peak is at 8300 RPM. As a result, there's essentially zero torque under about 3000 RPM, and still not much until about 6500 revs."
Again, not the kind of treatment I'd like to give to my precious car, especially if I paid over $30,000 for it as in the case of the S2000. This is likely the same way a '99-'00 Si would have to be driven in order to get good times as well. If that;s the case, I definetly am not going to be looking for a used '99-'00 Si any time soon if that's the kind of treatment it has had over its lifetime.
Yeah, the torque is pretty consistently between 100 and 125 ft/lbs all the way through it's rev range. Take a look again at the dyno graph from a 1.8T at http://www.goapr.com/VW/images/dyno_golf_18t_stage_i.gif The stock torque is over 125 lb/ft right from about 1750 RPM and it goes up from there to a max of slightly less than 160 ft/lbs read from the sheet. Still way more torque is available from the 1.8T not matter where you are in the rev range.
Outside of the funky hatchback design, I think the current SI lacks personality. The '99 version had an engine with 'personality' (ie, something unique... love it or hate it).
For me, the engine in the GTI is great! The interior is suberb. The chassis... needs help (the 20th Anniv. edition or MkV can't arrive soon enough).
Does anyone remember reading this--
http://www.edmunds.com/reviews/comparison/articles/57200/page003.html
I just re-read it and found that it echoed my thoughts a great deal. (Incidentally, I had a '99 SI for two years... it was stolen from me... and subsequently stripped of EVERYTHING: engine, seats, gauges, tranny, etc. The only upside was that the insurance company paid out almost exactly what I paid for it when it was new).
As for the Celica, while the RPM at which the GT-S and the 99 SI are close the Honda VTEC system allows the power to be more evenly distributed through the rev range. If you read almost any review on the Celica it will affirm this as will a test drive.
I'm not sure what your point is any more. The things being said have been said and you are just trying to find different ways to say them.
To clarify: It's okay to take issue with another participant's comments; we just ask that you please use friendly/civil debate. Feel free to email me if you have any further questions/comments. And now back to the subject of the Honda Civic Si vs. VW GTI.
Thanks for your participation!
Revka
Double standard reversed!
