http://www.autotips101.com/cms/media/engine_performance/dirty_maf_final.jpg
You may need to see one on the shelf at Autozone to be able to identify it.
These "codes" don't really tell you which part is defective, only which SYSTEM is in distress. You could have a bad sensor, or bad wiring.
You have to remove the sensor, get an OHMETER, and measure the resistance between the two terminals of the sensor.
cold --between 1630 and 2740 ohms (between 14F and 122F)
hot -- 2065 -- 3225
If the ohms are outside these parameters, replace the sensor.
This 2003 Echo is actually my first car, so my questions are gonna be newbie-ish:
1) I just passed the 50,000 mile mark; aside from oil changes every 3,000 miles and some kind of maintenance at 30K...what other routine things should I be doing?
2) There's a scheduled major maintenance at 60K, is that right? Does anyone know what the entails and how to avoid getting REAMED at the dealer?
3) My trunk can no longer be opened with the lock (key). I tried looking at the lock assembly...but could not figure out what would need to be lubricated...anyone else seen this?
4) I have a few chips out of the paint on the hood (less than 1 square centimeter of chips...like 5 small spots)...how much would a paint repair cost and where do you recommend this be done? Do non-dealers have the silver paint from a 2003 echo?
1 and 2: Technically, recommended oil service on all Toyotas is 5000 miles or 4 months (I do 5k or 6 months on my '01 Echo and '08 Yaris). The dealer and most oil-change places will write down 3 months/3k miles, but that's b/c they are trying to make money. The exceptions to this are if you drive in very dusty/gritty conditions or tow a trailer (which Canadian Echo's are technically approved to do), and then it's good to change the oil sooner.
As far as "major" maintenance goes, the Echo is very simple. Every 30000 (so 30, 60, 90 etc) miles the only additions to the normal stuff are to replace the engine coolant and replace the spark plugs, both of which can be done at home if you're even slightly mechanically minded.
Beyond that, the Toyota Scheduled Maintenance Guide only says to "inspect" other things such as Transmission and Brake fluid levels and whatnot. Bear in mind, the "Dealer Recommended Service Guide" has all kinds of other stuff added on b/c once again, they are trying to make money.
The Echo has a timing chain and not a belt, so there is no guidance for ever replacing that.
To be completely honest - I've never changed the engine coolant in my Echo. I'm at about 114k, bought it used at 70k 6 years ago and the previous owner had not done the 60k mx, so I'm guessing it hasn't been changed since the 30k mark. I've had bad experiences in the past with "Radiator Flushes". Every car I've ever had it done to, or have a friend who has had it done to has wound up with a coolant leak after the flush and bam - new radiator. My last three cars have never had a flush AND never had a leak and I had them up to 200k miles - coincidence?
I just make sure the coolant fluid level is good. I live in Houston and I've never had an over-heat issue even rocketing around at 85 on the highways in the summer. Of course, this is just my experience - you have to decide what you're comfortable with.
3. That's weird about your trunk lock. You're saying it won't even turn? Did it only recently quit working or did you get it like that? If it's the latter, you may be using the valet key. Those are designed to work the ignition and doors but not the trunk. If you bought it that way and it's the only key you have you might try the dealer. Toyota actually has records of keys for vehicles. A friend of mine used to repo for Toyota and they could actually give him a code to know what kind of key to cut. They might be able to make a new one for you. Beyond that you may be stuck unless you have the lock replaced. As long as you can open it from the inside, I guess it's not that big a deal though. If you bought the car from a dealer, I might hassle them for not giving you the regular key - even if that's all they received, you might be able to talk them in to helping you out.
If it worked before but doesn't any more, you could try some good ol' WD-40. There's also graphite lock lubricant available at most hardware stores, but some don't recommend using that b/c over time it can build up.
4)Most auto-part stores carry generic paint touch-up bottles. It's like a bottle of nail polish, with a little brush attached to the cap. It may not be exact, but should be close. You can most likely buy the exact Toyota color at your dealer, but the thing is it will be "new" silver and probably won't quite match an "old" paint job which will have faded at least some. Still, for the small rock chips - either one is good enough.
Also, you're right to suggest graphite lock lube rather than WD-40. Don't put WD-40 into a lock.
Thanks for the great advice, I appreciate your time.
Regarding the trunk issue, I have been using my non-valet key...it turns a little bit in the lock, but not enough to do anything (actually I broke a cheap key copy once trying to open the lock)...but before that, yeah, graphite didn't really do much...I think the problem is downstream of the lock mechanism proper.
Regarding the paint...I still have the nail polish-style paint bottle that I got with the car....would that be sufficient amount to touch up? I'm looking for an invisible effect.
I'm posting here because I am now officially paranoid about the dealer here....I paid like US$600.00 for my 30K maintenance "check-up" (not to mention getting reamed on tires).
Love the car, though.
For your trunk lock, that's tough. I'm not sure if the lock is in the same place on yours as on mine but the lock is easily visible inside the trunk lid off to the right. I can operate the little lever mechanism from the inside (that is attached by a bar to the trunk latch itself at the middle) with very light pressure from just my pinky. If it's taking you a lot of force to move the lever from the inside then it makes sense your key is having trouble. Maybe lubing up the lock from that point vs actually inside at the tumblers would help?
For the paint, "invisible" is a tough goal. The only way to make it truly invisible would involve sanding, priming and painting. The touch ups do a pretty good job though. My wife's Yaris is the Pacific Blue Metallic and the touch up bottle does a pretty good job. There's no hiding it up close, but it looks better than black chips everywhere.
The key is trying to dab more than brush. Get some on the end of the little brush and just poke that drop into the chip. It will naturally settle out to fill the small divot. If you try and brush it in, you will get far more noticeable brush strokes. Try a couple practice dabs first to get a feel for how the paint reacts - it's typically very thick.
That's a bummer about your dealer. Some are definitely better than others. They should have given you a break down of exactly what they did during that service. With that try calling other Toyota dealers and seeing if it's about the same everywhere (it seems a bit high to me). Then, if you can show that maybe you got gouged a bit, go straight to Toyota and complain about the dealer - they seem to take those issues pretty serious and maybe you'll at least get some free oil changes or something out of it.
1. some Echos (including mine) use 60K-mile plugs, not 30s, (which adds $75 or so to the 60K-mile service - those plugs are pricey) and
2. the dealers no longer carry the exact paint code for touch-up paint for Echos now, as they are too many years in the past and dealers don't keep more than 5 years of paints in stock. HOWEVER, if it is a common color like white or silver, you could get the one for the Yaris which is close and it will be so close you can't tell the difference.
I have had 140K trouble-free miles by doing oil changes every 5K, tire rotations every 10K, changing the air filter myself if it looks dirty before 30K, and doing the 30K and 60K major services when they are due. The Echo isn't a fussy car though. I bet you could get away with extending those intervals some if you are the type to pay attention to changing noises, behaviors, etc of your car.
Edit.....oh, and I have never had a radiator flush, just drains and refills at 30K intervals. Still have my original radiator, knock wood.....
I just bought a 2001 Toyota echo 2 days back.
I notice that when I was parking the car, there is a fan turning on and making a lot of noise. It turns on and off intermittently. Is this normal, it seems I have never heard such a loud fan on other cars.
I should add that I am a complete newbie in this, and this is my first ever car. I apologize for any stupidity in advance.
Fortunately, there are a lot of folks here who know what they're talking about. I'm not one of those... I'm like you... but welcome to the Forums, and hopefully someone will have a bit of advice for you soon.
(no insult intended... *I* have to ask questions about everything more difficult than checking the engine oil level)
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
So the coolant temperature sensor, sensing a rise in temperature, signals the cooling fan to go on, which it is allowed to do even if the car is shut off. Once the cooling fan cools the coolant down, it shuts off. Since the "heat sink" might go on for a bit, it's possible that the cooling fan might have to turn on two or three times to get the coolant temperature down.
The fan should shut off pretty quickly though---if it runs on and on, then the sensor or relay is probably defective.
Just a follow up question on Maintenance now:
The mileage of my car is 39k. What kind of regular check up should I do and maintenance?
Thanks in advance
Edmunds Maintenance Schedules
check sparkplugs change every 30k miles
look in your owners manual for more things to do
Check the coolant level in the overflow bottle. I also think your fan going on is normal.
Good Luck!
and edmunds schedule is guide is really good
Last question for now : I got my car checked and everything. The mechanic told me may need to change my battery in near future.
These are the numbers from the test:
429/500 CCA.
12.38 V
Is this something that I should do it right now, or can it wait?
NY winter is coming in a month, so I dont want to get stranded.
Appreciate all this.
Personally I never change a battery until it goes out. My ECHO battery went more than 7 years and its cold where I live. It easy enough to get one at Pep Boys and install yourself.
The battery is original I think, so 8-9 years old. But I am not sure, not asked the prev. owner if they had changed the battery or not.
Even the guys at midas said that I can change it ( not a must in their opinion). I have been driving the car w/o any problems for the past week.
How much $$$ is all this stuff costing?
Now then, if you look at your car and the alignment of the belts seems satisfactory, with no or very minor deviation from true, then problem solved, or no problem.
Now if it shreds a belt in a few months, then yeah - but six years is not bad.
Once you know that the codes are record them and get back to us.
Good luck!
The blue light went off quickly in the summer but it did not do the same thing recently unless I drove it for about a mile. In fact, I have to warm up the car for 2-3 minutes to remove the frost on the windshields before driving it in the morning. The problem is I need to drive on a 50-mile speed-limit road immediately after I pull out of my driveway while many people are going 60+. How long does it normally take for the blue light to go off in the cold weather so that the tranny can shift into the 4th gear? Thanks.
Neal
