Saab 9-3 Sedan
1142143145147148163
  • Hello again -
    Sorry for the multiple emails, but I went to the dealer and they are 100% useless, when I asked them to check the back windows for one-touch they came back to me and told me that it is working as designed and to look at page 132 in the manual which doesn't tell me anything. Anyway, I was wondering if you can put me in touch with location or person who fixed your car so all your windows work with one-touch both up and down.
    Sunny
  • I had my car worked on at Dorschel Saab in Rochester NY I also have a 2003 so that may make a difference. try rapidly cycling the windows up and down and see if that doesn't activate the one touch feature. Also don't be afraid to email Saab through the US website. I had a question 3 years ago that they answered pretty quickly and it was a feature issue.
    Good Luck
  • I bought an '05 9-3 in June 2005. No problems. Not one. I have about 14k miles on it, and it has been a good car. As good as any I have ever had, and better than several. Its comfortable, stylish, gets decent mpg, and is fast enuf for me. I also paid well under $25k for it, and got good treatment on my trade-in from the dealer. All in all, very good so far.
  • I am getting ready to order a 2007 9-3 with premium package, but can not decide on the 16 or 17 inch wheels and tires.
    What are the advantages of 17 wheels and tires, and are they worth a extra $200.00?
    (1) Are the 17 inch wheels better looking?
    (2) Do the 17 inch wheels and tires have better handling?
    (3) Do the 17 inch wheels and wider tires give a better smoother ride?
    (4) Do the 17 inch Wheels and wider tires have less road noise?
    (5) Do the 17 inch wheels and tires give better milage?
    (6) Do the 17 inch wheels and tires have better tread life?
    (7) Finally, are they worth a extra $200.00?
  • Hello ogr81. Nice to hear good new from you too. I have 03' 9-3 Linear too and running very well since 2002 november. some bad experiences for my car were to hit by Buick, a mid size truck and wolf on the front door. But it only make me feel it's the safest car in the world. because the only bigger damage was from the wolf. cost me a new front door becasue the bodyshope couldn't fix the dang on the door. other car accident suprised me all only damage those front and rear bumper. I know it sad to see CR name 03' 9-3 is the worst car SAAB made. But mine is running very well for almost 60k. I definitely will keep this car until 2008 when the onstar is not working on this car more. :)
  • ukjimukjim Posts: 63
    Hi, just a bit of information I learned the hard way. My 2004 ARC Conv(18K Miles). wouldn't start after having run perfectly. AAA couldn't jump start it, Saab roadside assistance came by to tow car, put jumpers on and it started :confuse:
    Put battery on charge overnight, Sun AM it wont start again. Car got towed to dealer, who gave me a new SportCombi loaner off the lot (enterprise rental all closed). Picked up car Mon with new battery. Dealer explanation, all '03' & 04's shipped with a known cheap "2 year batteries" replaced under warranty if it goes bad. New battery is better quality should go 4-5 years.
    Bottom line, SAAB of South Bay :D bent over backwards for me. GM rolls the dice on batteries :mad: , failure is very strange, battery doesn't get weaker, it just fails completely, no dim lights, or slow cranking. To jump the car requires best quality cables and heavy duty battery and alternator, but battery wont hold any charge at all. Also dont believe the status window on the battery, mine showed it to be OK!
    Sorry for long posting but this type of battery failure came as a surprise to me
  • Hi, I,m new to this so bear with me - I have a 1yr Old 9-3 Vector Sport 150 tid Auto. The car is great apart from when you initially put your foot down especially in situations where you need to go quickly - roundabouts,junctions u-tuns etc. there is a noticeable delay in applying the throttle and anything happening. I have had it back to the dealer three times in the last 3 months and even after it's first sevice there is no difference and the dealer maintains they can't find anything wrong - including updating engine management software etc. Away from a standstill there is no shortage of power or acceleration it's just the initial start - unlike a manual car you can't rev it and slip the clutch a bit - even selecting semi auomatic doesn't make any difference - Anybody else got this problem or any solutions ?
    Thanks :confuse:
  • Will some one PLEASE give me some help.
    Don Luce
  • Go to:
    www.tirerack.com
    There may be information to answer your questions about tires and wheels. Hope this helps
    goodstar
  • (1) Maybe
    (2) Yes, greater contact patch
    (3) Maybe
    (4) No, see (2)
    (5) No, more aerodynamic drag
    (6) Maybe
    (7) Yes, if your answer to (1) is yes
  • saablcpsaablcp Posts: 195
    Unfortunately you aren't going to get much help from us on this side of the pond.That engine is stictly European spec.and not available in the U.S.
  • I have a 2006 9-3 and so far it seems OK. Is the interior as tight as I would like NO..., but the engine, suspension and 5 speed manual make the car fun to drive. Most importantly I like the styling. When you buy a car you take a chance, but you buy it because you "like it". You like the way it looks and like the way it drives. You just hope that you get a good one.
    If you read the message boards you find plenty of unhappy customers of all makes.
  • My SID 2001 SAAB 9-3 SE is missing pixels. new pixels disappear every day. sometimes they reappear and dissapper. i have noticed a similar problem starting on the climate control display too.
    What's up with that? Does anybody have any quick fixes for novice car tinkerer? Is this a known problem that is worth fixing?
  • IF the 17" are wider (99%likely)
    then :
    1-better looking
    2-better handling when dry, same to worse handling in the rain
    3-harsher ride
    4-more road noise
    5-increased fuel consumption
    6-shorter thread life
    7-yes for the look and better dry handling, no for everything else.
  • DonluceDonluce Posts: 41
    What size and make are the tires supplied as standard equiptment on the 2007 Saab 9-3 2.0T sedan, and on the Saab 9-3 Aero. Pirelli P215/55R16 P6 Four Seasons on the 2.0T Sedan? Pirelli P235/45R17 P-Zero on the Aereo?
    Don Luce
  • I have a 2002 9-3 SE Conv. The Check Engine light has been on continuously now. Randomly, the temp gauge shuts off and the A/C goes off with it. I have replaced the Coolant Temp Sender and checked those lines. I have flushed the radiator and have no remedy. Anyone have any other thoughts? :confuse:
  • sidvsidv Posts: 64
    Yes, I had this exact same thing happen to me last summer at around 18-20 months on my '04 9-3 Arc. The worst part was that Saab's so-called "roadside assistance program" would only tow the car to the nearest dealer (even though my dealer was probably no farther than third closest) and would not provide a loaner. Since it was a Sunday and I was out of town that meant the car had to be towed so that it was actually further from my home, compounding the inconvenience factor.
    I was very unimpressed by both the benefits of, and the attitude of, Saab's roadside assistance group in this circumstance. Coupled with an 18 month old, 30K plus car stranding us, numerous electrical/SID/alarm phantoms, defective keys (finally recalled), a glove box that no longer opens, defective window pinch protection, dead sunroof and embarrassingly noisy brakes when backing they can't or won't fix I can say Saab won't be getting any repeat business here-you can't sell someone both the most expensive and least reliable car of their lives and expect them to come back for more.
    Sorry to hear about your problems. It sounds as though the roadside assistance and loaner program is dependant upon where you live. I am in Southern CA and have nothing but good things to say about South Bay SAAB. I didn't go into all the details but the dealer even opened up the service lot specially for me for the tow truck to drop the car off (the service facility is 3 m from sales office and normally closed on Sunday), and I didn't even buy the car at this dealer! I will admit however to being dissapointed at the electronics in the SAAB, were they made by Smiths of England? I too have had a few false alarms. But having traded in a Mazda RX8 for the ARC, I am still better off.
  • I have a 2005 Saab 9-3 Aero and it is an electrical nightmare! The car is so unreliable that it makes me sick. I have had the same problems over and over again with the windows and cd player. JMK Saab in Springfield, NJ is absolutely worthless. DO NOT BUY OR LEASE FROM THEM THEY ARE SCAM ARTISTS. "Joe" in the service department is extremely rude and arrogant and I dont think he knows anything about cars. Saab USA is reviewing my current situation and I have asked for them to buy the car back. Ill keep you all posted as soon as I hear from them
  • sock1sock1 Posts: 2
    I'm currently in the market for a new car. My current vehicle...a Honda CRV...has been great...but now that it has reached 100K, I'm beginning to review other options, especially since my daily commute involves roughly 90 miles each day (I don't really like the design of the new CRV). In sum, I'll looking for a quiet, comfortable, fun to drive car with a few luxury touches, which leads me to consider a Saab. I find the car attractive and the pricing, especially for leftover 2006 models, is very competitive.
    But as the bard might say, there's the rub. I have never seen a car with such a polarized group of drivers. You either love the car or hate it immensely. My cousin, for one, an owner of a 9-5, considers his car a complete piece of junk, and says all Saabs contain a congenital defect that can cause the engine to suddenly seize at any speed. It also appears that the 2003 and 2004 9-3s clearly had its share of "teething" pains, which hopefully have been corrected by now.
    I recognize there is no perfect car (I once owned a Pontiac Sunbird, for instance), but I do need something that is at least reliable. Please share with me your thoughts, good or bad, regarding the 9-3, to help me make my decision (I'm also considering a Volvo S60 and maybe a Subaru Outback).
