Visitor Agreement.
I have found that if I turn off the ignition then restart it, it sometimes helps.
Any ideas would be greatly appreciated.
There is something obviously damaging the PCMs. The PCM design on Dodge trucks have been around for some time and are nearly bulletproof. The manufacturer should be so easily blamed on this one, but maybe the technical crew needs to do a little more homework.
Dusty
I have a 2005 ram 2500 hemi, and it does not matter how you sit or how you try it only comes out of park when it wants to. The dealer has not fiqured it out. Have you fiqured out anything else. I have drove and tryed many new dodges and none of them do that.
Ron
My 2001 Dodge Ram showed the same symtoms today. "No Bus" displayed where the mileage shows and all the gauges dead. Truck still runs fine, just no gauges. I called three different places and got three different stories, from bad cluster, bad BCM, bad wiring between BCM and cluster, etc. Still trying to sort it out.
Please update me on what you have been able to learn.
There are some tests that can be performed, but it would be necessary to get much to wordy in this forum. What you could do is perform the Instrument Cluster test:
1. Switch the ignition off.
2. Press and hold the trip odometer button.
3. Switch the ignition switch to the "on" position. Do not start the engine.
4. Keep the odometer button depressed until "CHEC" is displayed in the odometer window. This should take about 10-15 seconds.
5. Release the odometer button.
6. An instrument cluster fault will be displayed as a three-digit number. There may be more that one set of numbers displayed.
110 = A failure has been identified in the instrument cluster CPU, RAM, or EEPROM.
900 = The PCI data bus is not operational.
920 = The instrument cluster is not receiving a vehicle speed message from the PCM.
921 = The instrument cluster is not receiving a distance pulse message from the PCM.
940 = The instrument cluster is not receiving an airbag lamp-on message from the Airbag Control nModule (ACM).
950 = The instrument cluster is not receiving an ABS lamp-on message from the Anti-lock Brake Controller (CAB).
960 = The instrument cluster is not receiving a PRND21 message from the Transmission Control Module (TCM).
999 = An error has been discovered.
After the instrument cluster fault test is finished, a vacuum fluorescent display, bulb, and analog gauge test will be performed. This is referred to as the "walking test" in Dodge technical parlance. This tests all of the indicator lamps and gauges.
Dusty
Good luck,
Dusty
I have a 99 ram 2500 quad,V-10 4x4 with auto. When I am driving and turn the ac knob to cold it works fine till I either hit a bump in the road or come to a stop in a hurry.Then I hear a door in the dash shut and I get HOT air. Living in Phoenix the air is hot but not as hot as when your ac shuts down in the middle of the day. If when slowing to stop, I keep the rpm's above idle, The ac works fine. If this were 15 years ago I would assume it to be vacum related. Any ideas as to a fix.....besides going back to driving a FORD ????? Thanks in advance.
Dusty
I would suggest checking the electrical connections to the heater control panel. You might have a loose or intermittent connection. At the moment I can't think of anything else to check. I think it's possible the Central Timer Module could influence this. It might have a bad connection or is intermittent.
Dusty
ty
Dusty
The air flow breather that opens and closes with the silver cylinder device that has a rod going into it is attached to a plastic piece that regulates airflow, if you move it from say A/C to defrost it will come off, it looks like the plastic piece is broke, (this is located at the bottom center behind what I believe is the computer for the truck.
I can take a long screwdriver and attach the plastic back to the metal piece but like I said it will not stay if you move from A/C to Defrost to A/C. What I need to know is what that piece is called so I can possibly try to order one and the best way to go about getting underneath there to replace it. Thanks for any and all help.
:confuse:
Yes, they replaced the PCM...but it was something else that was causing the PCM to go bad. The intake valve was clogged and dirty, causing the idle to go to low and consequently die. Sometimes it was so clogged or the heat made it stick, the van could not recover. Other times, we'd wait 10 minutes and it would start up again.
It is a quick fix to replace the PCM...have to get to the source of what is burning it out though. That's what our mechanic indicated.
I'm no expert at all...just sharing what I've learned these past couple of weeks.
Was totally worth calling 5 dealers and "interviewing" the mechanics and service manager via phone before heading in to the dealer. Not all are created equal.
Good luck!
Looks like you keep busy on this site!
The PCM was bad...but it was the fuel intake system that was clogged and causing the idle to go too low and making the van die and burning out the PCM.
Appreciate your insight and knowledge.
Kind regards,
ginac
I first noticed this between 25000 miles and 30000 - I had to replace significant amount (3 quarts) of lost cooling fluid. The shop said I had a bad radiator cap, and replaced it. I have back washed the radiator on several occasions to remove bugs etc. Then I noticed that the vehicle was exhibiting overheating. Returned to shop - new thermostat. The problem was reduced - now approaching 60000 miles and new warmer weather I had the shop replace the thermostat and flush the system. However, the vehicle is still overheating (I notice a bit of bypass fluid at the fill reservoir after any driving and an odd smell on occasion. I have notice a bit of fluid loss. The typical symptoms are:
Running on a relatively flat road the temp gauge is one to two needle widths below center - as the ambient air temperature goes up the gauge moves up - at around 80 the gauge is 2 or 3 needles widths above the center. When going downhill the temp drops below center. If a moderate hill of some length is pulled the temp gauge will run up 1/4 to 1/2 the gauge display to the overheating position. The red check gauges warning light come on at that time. As I back off the run at the top of the hill and run on the flat the temp drops slowly to the more center of the gauge. All of this is with only the driver and no other significant load on the truck.
Any thoughts?
Art
I love the truck, especially the manual transmission.
I would be interested in any knowledgeable opinion regarding using the engine/clutch downshifting in order to slow down when necessary in traffic, versus using the brakes. In the long run, (as far as engine, clutch or brake maintenance is concerned) which would be the best way to slow the vehicle?
Dusty
Okay. I'm not sure how the "fuel intake system" being clogged is defined. However, what I may deduce from this is that something in the intake system was restricting air flow (hence "clogging"). I'm not sure how this would translate to causing a PCM failure, however.
My first thought was that the Idle Air Control Motor was constantly trying to actuate against it's limit and perhaps caused that output circuit op amp to overheat and fail. I don't know, I would think that the outputs are protected from these possibilities.
This is one I'd like to understand better, so if you could supply more detail I'd appreciated.
Glad to hear they got you fixed. That's all that really matters.
Best regards,
Dusty
Keith
If it really is overheating then each coolant component must be checked. A pressure test would indicate the release point of the radiator cap. The shop gauge can be used to check the thermostat.
From what I've read it is possible to get cavitation problems if there is air in the system. You mentioned that you had the system flushed. First, Dodge trucks of that vintage do not use conventional coolant, but one called HOAT. Using ethylene Glygol anti-freeze in a 4.7 will diminish the heat transfer efficiency of the radiator.
Take some shop readings while idling and at road speed.
Dusty
If you ever solve this puzzle (LOL) please let me know.
Did your engine lose power?
What can I do to get tail lights and dash light, How Do I isolate the problem. Please help- I am losing my hair on this one. :sick:
Art
kcram - Pickups Host
The Cummins diesel is far too heavy for the 1500 front suspension, and neithger that nor the rest of the driveline can handle the torque. By the time you upfit all the necessary components on a 1500, you could have trade for a 2500 diesel and had plenty of cash left over.
Ron
