Dodge Ram: Problems & Solutions
For the rough running problem, what service or maintenance have you performed. For that year and engine I think you needed spark plugs at 36,000 miles. A six year old truck typically needs ignition components changed by this time, specifically distributor cap, rotor, and spark plug wires. this could explain the low gas mileage, too.
The Engine and ABS lamps being illuminated could mean a number of things, but yes, this symptom is almost always either the rear wheel sensor and/or the speed sensor. I'd bet on the rear wheel sensor on the differential housing.
Based on my experience...with Dodge or any other make...your six year-old truck is not what I would call a lemon. The engine bearings are definitely an anomaly for a Dodge. The transmission is unfortunate, but it appears to be infant mortality. Your other issues are just so very common in any brand vehicle.
Get a tune-up and see where your at with the engine performance problem. If that doesn't cure it, come on back and we'll try to help you.
Dusty
P.S. Can you do any maintenance or repair work yourself?
Sometimes, if I do not put in more throttle, it will skip shift several times before settleing down in second. I had the band adjustment at 35,000 as per manual. Dodge says they can not duplicate.Temperature not a factor. Does not do this when valve body manually shifted.
Vacum signal is OK, when observed in situ it is normal range with no flux. I suspect the throttle angle cable adjustment may be out of rig with computed shift point.
I am a muscle car builder, but not familiar with this computer assited gear except in theory.
Any ideas?
I have looked the truck over well. I found some loose bolts on the front and top of the right body to fender mounts, and in the front of the right fender where it bolts to the radiator mounting bulkhead. Other than that, no other defects. I do not think that this was allowing for undue body flex.
I am at a loss to explain it. I have thought about thermal differential fracturing with the ac on and a hot truck, but I cannot accept that as a cause just yet.
Anybody else?
Thanks, you got me looking in the right direction, when you said the problems might be related.
Replaced the oil pressure sender, (dodge calls it an oil sensor), it has a three pin connector on it, so I am guessing it sends a signal to the computer. Any way it not only fixed the gauge, but also fixed the engine problem. I have driven it 400 miles since the fix with no problems.
FYI, Dodge wants $214.00 for the sensor, after a few calls I was able to get a wholesale price of $168.00. A little expensive for an oil pressure sender, but it fixed the problem so I am happy.
Thanks again
Bob554
First, look at the transmission on the side where the cooling lines enter the case. Just above and slightly to the front you will see a small stamped metal pivot arm with the throttle valve cable attached. This is the throttle pressure arm. There should be a small return spring attached to that arm. It might be missing or broken.
If that's okay, check for binding by moving the throttle cable at the arm. When released, the return spring should bring the throttle cable all the way back to it's internal stop. If it doesn't the spring might be too weak or there is an abrasion or kink in the cable, or something is restricting the cable's movement at the throttlebody.
Next you can check the throttle valve cable adjustment by observing the cable movement at both the transmission and throttlebody ends. When the throttlebody shaft is moved, there should be instantaneous movement of the cable on the throttle pressure arm on the transmission. If the the throttle lever arm moves ahead of, or lags behind movement of the throttlebody lever, the throttle valve cable is out of adjustment.
Adjustment: This is a little difficult to describe without pictures, but at the throttlebody end there is a bracket that supports the throttle valve cable. On one side of the bracket will be a small black plastic adjustment coupling that has very small rectangular holes. The slack in the cable is adjusted by removing a small plastic clip and repositioning it into another hole until the lag in the cable is eliminated. This may take several tries, but I've found that when the clip is removed and both the throttlebody and throttle pressure arms are at the idle stops there is one hole that the clip will slip into.
Best regards,
Dusty
Have you checked the coil?
Dusty
Thankx, Scott
Dusty
Jim
Can you tell me where to find the resistance specs or voltage readings in circuit?
Jim
I face a curious problem with my RAM 1500 2005. The gearbox lever is completely blocked in the Park position. Pushing reeeeally hard on the brake pedal does not change anything.
Does anyone got an idea on this kind of issue ?
Thanks for your help
Bernie :confuse:
I was smoked by an F150. Granted I had a full load in the bed, but I can't have it happen again.
kcram - Pickups Host
Any Ideas as to what is causing this?? :confuse:
I have a new dodge diesel 2500 with 9000 miles. I was going about 40 mph and hit a small bump in the road. All of a sudden my steering wheel was going back and forth and the truck was vibrating tremendously. I pulled over and looked at the tires and they were OK. I started driving again and everything seemed normal.
Any suggestions?
I have put new....plugs, wires, cap, rotor, and K&N air filter. The truck came with a Flowmaster muffler going thru stock tail pipe. I recently added a 52 millimeter spacer under the throttle body (supposed to improve throttle response and add 1 or 2 miles per gallon) and I put new tires and front end alignment.
PLEASE someone tell me why am I getting only 11 miles per gallon????
I keep my foot out of the accelerator to help but I wanna drive it now and then.
The truck starts and idles and accelerates like brand new and the engine light is not on.....any ideas or is this normal?
The other day my CHECK ENGINE light came on. Later that same day, my transmission wouldnt change gears (stuck in either first or second, Im not sure) A diagnosis at Auto Zone advised my speed sensor was malfunctioning.
Is this somthing I can replace myself? Anyone have any insight into this problem?? Thanks in advance!!!
PROBLEM #1 At 20,000 miles I experienced an intermitting "Door Ajar" bell that would not stop... When it was hot outside, the bell would ring, the door locks would lock, unlock and everytime I took it to the dealership, it would stop. After 4-differnent trips to the dealer, they finally found the resistance in the pink wire of the wiring harness to be too high. They replaced my wiring harness and it was fixed.
Problem #2 At 56,000 miles, I get in my truck and the following doesn't work! Instrument panel, blinkers, horn, windshield wipers, dome light, turn signals, the truck stalled twice on right hand turns on the way to the dealer, low idle... The dealership tells me that it would cost $750 +Tax to replace the instrument panel for starters, then they can't guarantee that it will solve all of my problems....
With rising gas prices and a list of problems.... I'm DONE!!!! :mad:
My truck and several others I checked have a metal piece just below the material that after a short time begins to wear the seat and punch you in the back. I feel that in a accident the metal would hit a person in the hip area, but it is just uncomfortable if you lean over that way also.
Dodge says I am over the 36,000 so they are not interested!
Thanks Don
-Erickson2000
