Good Luck!
I'm curious if Platinum or iridium plugs would be worth the added expense in his car.
Thinking that maybe I need to dump this puppy before it turns into a full blown lemon. Any thoughts?
5 speed
Bought used several days ago. My first car.
I found the idle speed at reverse gear is twice higher than at 1st gear.
Who knows the reason of this?
If you listen to yours, let me know if you hear it...I can't believe the two new cars we looked at had the same problem...Thanks
....for post#90, try oem-car-parts.com which offers discount parts along with exploded parts diagrams.
http://www.altimas.net/tsb/
Altima TSB (Technical Service Bulletins)
down inside the right compartment where the tire jack are stored
during raining day or after car wash (check it any way)
Mine have about 4-5” of water inside!!! I am not even sure
how long the water been accumulate in there because it has been
raining hard this week in Jersey. I am not sure if there are any
wires run between door frame through that compartment, I will bring it
back to the dealer and see what they will say.
I wonder if this is the cause that some time the power lock will
Unlock itself on and off, and the double park signal will go crazy too.
Most of the time I just ignore them and it will fix itself!
This time I better take it back to the dealer.
Stay tune
and fog lights. I knew what to expect as far as
interior material quality and engine noise, but I'm also experiencing the following problems:
1. a creaking or groaning sound from the front
suspension, it happens intermittently during
low speed maneuvers (parking lots etc) and
when accelerating briskly from a stop.
2. a whining or whistling sound from the
engine at rpms above 2600, this could be
normal for this engine.
These sounds usually can't be heard with the
radio playing, so you have to turn it off and
listen carefully. If anyone else is experiencing
similar problems let me know. I have a service
appt on 10/21 and I'll pass along any info.
On the groaning noise - dealers tech re-torqued all suspension fittings and so far the problem seems to be resolved.
As for the engine whining - tech says its normal
for that engine- related to air intake and large
plastic plenum. Maybe thats part of the trade-off for the excellent performance from this 4 cyl.
17 inch low profile.I had to replace them at about 3,700 miles,they were damn near bald.Firestone replaced them with no problem at all until I approached them at about 8,500 miles and they were about bald again.They told me that they were recieving a lot of complaints about the
'02 Altimas & Nissans,that they were wearing tires like crazy.The car is lined up on a regular basis.Has anyone else had this problem & if so,what did you do?
or are they part of a single belt. Thanks in advance.
in drive. I bought the car on 10/10 only have 900 miles on it. I did not notice the rough idle during the test drive but it may have been there.
I also have a slight high pitched whining noise from the engine at rpms above 2700-2800 but dealer claims this normal (see post 59). I think we need to complain loudly to Nissan until these problems are fixed. I will post any new info. Please do the same if you get any news.
