I also have fuel gauge inaccuracies. Every time I fill up the tank the gauge shows 3/4s full. Nissan had tried to fix the problem last year and now it's re-occuring.
Anyone have similar problems with either the engine whine or fuel gauge? Would appreciate some input/suggestions before i take it in this Friday. Thanks
PS- the kumho tires are performing nicely. Drove from VT to MD through the snow storm that's battering the Northeast right now and nary a slip.
The technician is also recommending me to change the spark plugs and the associated wires which adds another 250 bucks to the bargain.
Can somebody please tell me whether-
1) do the above estimates sound ok,
2) recommend me a web site where I can read about this problem and hence take an eduacted decision.
Other than this the car is fine.
"2002-2003 Altima Engine will not crank in Park, but cranks in Neutral" - the Nissan Technical Bulletin number is NTB02-083. I believe they have to replace the Park/Neutral Position switch. It should be covered under warranty.
Check your distributor for oil inside of it. You'll have to remove the cap, rotor, and inside dust cover which protects the camshaft sensor. If oil is on the metal disc wipe it carefully with a paper towel and blow it out of the openings in the metal disc and sensor assy with canned air(some people use electric parts cleaner).
I had to do this to my sons 95 Alti recently. The cause is a worn oil seal on the engine side of the distributor. It cost about $3 from the dealer if you can find a parts man willing to order it for you. I had to go to two different dealers to find one who would.
This is a well known problem for the 1st and 2nd generation Altimas. The dealers like to sell $400 distributors for this problem.
I haven't had to rescue my son since I did this.
If this is your problem, I'll lookup the Nissan part number for you.
I own a 2003 2.5S with auto. Currently, have abt 15k miles on the car. All have been trouble free. However, I can hear the engine knocking when inside the car and out. The knocking is not obvious when the car first starts up. The problem surfaces after driving the car for a while (30 minutes or so). When the heat is on, the noise is not that bad, but when the heat is turned off, the noise is obvious. Has anyone exp this behavior yet? I'm going to bring it up to the dealer later this week when I go in for my oil change.
- The road noise with the factory Continental tires is bad on rough pavement. They're very quiet on smooth pavement. Kumho makes a quiet tire in this size, or you can go to a plus-zero size for a wider selection.
- My 2002 Altima has had no major repairs at 32,000 miles. I added some Dynamat to help with the road noise, but the main cause is the factory tires.
- If you're considering the 350Z, you would do well to compare it to the Altima 3.5 SE or SL. I highly recommend the optional ABS and side airbags on any Altima.
- You call the Altima's ride bumpy, while I think it could be firmer. If you think the Altima's ride is bumpy, you should probably cross the 350Z off your list. Are the tires in your rental inflated correctly (29 psi front and rear)? This could be the cause of the bumpy ride.
I recently changed the Inginition Distributor on my nissan altima, 94. The car had died in the middle of the road. The mechanic checked the alternator and told me that it was ok.
But the ride is still bumpy in the sense that it tends to stall in the stop and go traffic. It will not turn off, but it seems to be slipping or not picking up speed and sort of bumps when I start it from a rest position.
This starts to happen after I have driven my car for some time, like 10 minutes.
Yesterday a new problem occured, the dashboard light started to go on and off even though the headlights were ok (it was night time).
Can anybody suggest what the problem is and if somebody had similar problems in the past?
http://www.altimas.net/tsb/
For the "No Start" issue:
1. If it happens again, try to start the car when it's in Neutral.
2. Print the "2002-2003 Altima Engine will not crank in Park, but cranks in Neutral" Bulletin from the above link (# NTB02-083) and have Nissan repair it under Warranty.
(:-D
no major problem (yet). just came back from an oil change at Wal-mart. I have put in lots of driving in this car and still love it.
kept a very clean repair records about the maintenance, so far total cost till date - $1600, including (most of them are oil change, 2 radiator flush and 1 trans-oil change at 35k)
4 new tires at 45k miles from Wal-Mart and a brake job, that's it!
Oh! forgot to mention this - all i feed this guy was 89 Oct from day one, no knocking at all (so far).
i turned the key, sucker crank.
yes, the cd/radio panel night light doesn't work,
but some time it just came on by itself- big deal!
seriously looking forward to the 05'Altima
1): the shift switch can shift smooth and quietly as normal.
2): It can start engine at P and N position as normal.
3): When shift to R position, I do NOT feel the engage feeling and the car DOES not move backward. But the back light is on.
4): When shift to 1 position, the car DOES NOT move forward. I am not sure whether the engaging feeling is normal because I can not remember the engaging feeling at 1 position.
5): When shift to D with overdrive ON or OFF, the car drive move smooth as normal, and it accelerate as normal.
6): When shift to 2 position, the car can move forward. I am not sure whether it drives as normal because I can not remember the feeling of driving at 2 position.
7): At P, N, some time at R position, I hear some low whistling sound, But I am not sure it is normal or not.
I have checked the trans fluid and engine oil, both of them have normal smell and level. Trans fluid was changed at 30,000 miles three years ago. The service engine light is OFF. All other gauges are normal too.
While I feel the auto trans is fine, My first doubt is the neutral start switch has broken, and the second doubt is the shift cable is out of alignment. Before I send the car to a garage, does anyone have similar experiment, or any advice to take additional self-check? or know which cause the problem?
Best: 29 MPG
Average: 26 MPG
A/C doesn't seem to affect the mileage significantly.
I was also rather suspicious since the mechanic heavily pushed for an oil change owing to "very dirty oil" - which clearly was not the case since it recently had been changed.
Frank
However, they told me that enough owners complain about this problem, Nissan will take action and post at "Service Bulletin" to help fix the problem.
Therefore, if you are experiencing this problem please either take your car to the dealer, or call Nissan directly, and open a complaint file with them.
We all need to work together to try and remedy this problem.
Yesterday when I was about to start the car, it displayed "SERVICE ENGINE SOON".
After I started the car, the display disappeared. I got this car from a Private Seller
couple of weeks back. The Engine sensor recall fixing for this car is still due.
Did anyone face this issue before?. I am taking it to the Nissan delaer to fix the Recall.
Any other recommendations?. Please advise.
Thanks in advance
Maybe I am just getting used to the poor reception?
Either way, if Nissan does a service bulletin, I want it fixed ASAP.
Just a question about the A/C though, after I turn my ac on it won't shut off until I turn the car off. The light on the dash goes off, but colder air is definitely still coming from the vents. Just wondering if this is another problem with my new 05. Anybody know?
I am thinking of getting my grandfather or uncle involved to see what can be done about it.
It is ruining the overall experience of my car.
Not having issues with the A/C though.
city 27 mpg
highw 29.1
aveg 28.6
Thank you in advance
Hope this helps.
