Have you recently leased or purchased a Lexus sedan or SUV? If so, a reporter would like to talk to you. Please reach out to [email protected] by Wednesday, December 19 and the Edmunds PR team may connect you with the journalist.
Have you recently purchased (not leased) a subcompact sedan (such as a Toyota Yaris, Honda Fit, Chevy Sonic or Ford Fiesta)? If so, a reporter would like to talk to you. Please reach out to [email protected] by Wednesday, December 26 and the Edmunds PR team may connect you with the journalist.
Ford Expedition Maintenance and Repair
1464749515263
  • sumerisumeri Posts: 1
    My 03 EB's owners manual says the fuse box is located under the control panal, but there is nothing there?
    Any ideas? My right blinker is fricking out and I think I need to change a fuse.
  • zman3zman3 Posts: 857
    If it is just one blinker it may just be a burned out bulb as opposed to a fuse. If one of the right blinker bulbs is burned out it will flash really fast, where as the left will be normal speed.
  • Thanks for your time, sometimes we just look right past the little things. I went and checked the battery cables, and there was some corrosion on the neg post. I cleaned both post and the cables, I hope the problem was that simple, we shall see, thanks again... Joe
  • bruce23bruce23 Posts: 1
    I have had my 2000 Expedition for over 3 years and now it is chiming whenever it is started. 5 sets of 6 chimes about 20 seconds after it starts. No warning lights just the chimes. The seat belts are secured. I have even followed the manual regarding turning off the chime for the belts but it did not work. Someone said it is because I have hit 80,000 miles. Anyone else have this happen.
  • fundadfundad Posts: 27
    Wow. Just found this sight. Its amazing! Anyway, heres a little background. 2003 4x4 Expy E.B. I have a suspension clunk from the front, drivers side area. This is the 5th expy I have owned and the clunk has always been sway bar endlinks. A simple $20.00 repair. I looked at the sway bar end links on this one and they look fine. Although they look totally different on the newer ones. Anyone have ball joints make clunking sounds on these? How about the shocks? Also, We have a steering wheel shake that starts at 70mph. Had tires balanced to no avail. Has anyone had this issue fixed? It doesnt shake the truck, just the wheel. I can live with it but its just annoying. Thanks, King Craig.
  • Hi everyone! I own a 99 ford exp 2wd and it runs flawlessly except for a "knocking" noise at idle. I have isolated the noise to be coming from one of the parts in within the intake manifold area. I am not familiar with domestics, have had and worked on imports all my life. Could it be the egr valve? Would it knock? By the way thankx for any responses... :confuse:
  • I read and saw on the DVD that when switching from one 4wd to another 4wd, it may make a noise. What about switching from 2wd to the AWD????? There is no light onthe dash for it and no clicking noise to ensure that anything has been switched. I know the 4wd HI and 4wd LO work cause i switched to them to make sure i feel and hear it. . .and YES. . but when switching to 2wd to AWD i hear nothing. The only thing i noticed is that the miles till E went WAY low in only a few miles. . .HAHAHAHA. . .i know AWD can be bad on the gas, and the feel of the truck felt a little stiffer. Dont wanna gun it on a stop to see if i spin out. . .im afraid of breaking something. . . not likely on the new Expy, but just wondered if there was or should be any tell tale noise. :confuse:
  • expymanexpyman Posts: 4
    I have been hitting a lot of blogs trying to get an idea of why my 4wd system stopped working. Your description is very similar to my 99' eb expy. Just before the 4x4 stopped working completly, it became VERY 'finicky'. A couple of times it looked like I would'nt be able to get it out of 4x4. What I'm going to try is: remove the rear cover on the xfer case shift motor. You will need to get tamper-proof torx for this. Clean the contacts, disk and fingers using a pencil eraser. Replace and see what happens. I have seen this several times in these repair blogs. Might work for you. I will probably try this tonight.
    s
  • Does anybody else have any experiences where the AC makes a hissing sound and then stop blowing cold air? I just had my AC serviced, recharged, checked for leaks...the whole nine yards a month ago but still does the same thing.
    That setting is NOT all wheel drive. It is AUTOMATIC 4 wheel drive. That said, it just readies the systym to activate 4 wheel drive when there is rear wheel slippage. When that occures, you whill hear it ingage into 4 wheel drive. A4WD is just a automatic setting so you dont have to keep switching from 2 wheel drive to 4 wheel drive when ever you need to. It does it all by its self.
  • marlonemarlone Posts: 4
    We have two 2003 Foed Exped. One w/ normal idle rpm at 1,000. The other w/ only 500. Engine stops during heavy traffic. We replaced spark plugs but problem still persisted. Anyone who has the trick to correct this problem, guys?
  • gc3184gc3184 Posts: 1
    i have a 2000 eb expedition,when i started the truck this morning it was very rough,when i put it in gear the shaking was so violent i had to shut it off anyone else ever had a problem like this!really feels like the truck is about to stall.... :(
  • mbjbmbjb Posts: 39
    The problem you described is the same one I had a couple years ago. At highway speeds the condenser freezes up and the a/c will blow warm air and hiss. After the condenser thaws, the a/c blows cold again. There is a tsb on this and I don't remeber what they replace. I want to say some kind of valve. Do a search on a/c problems in this thread and you should come across the tsb.
  • goody31goody31 Posts: 2
    it sounds like the air ride suspension is just deflating. I would take it to your local tire and brake dealer and talk with them, most of the time they'll check it out for free.
    I was told that it was just the air ride suspension pump engaging, the guys i my local tire and brake center said that it was normal for them to make that noise. :)
  • yalegradyalegrad Posts: 6
    I have the same noise with my 04 Exp. My nephew also has it in his 03 EB. WE have this noise at the same speeds that you do. It is coming from your axels whether they are engaged or not. There may be some Ford 4x4s that do not make this sound but I do not know of any. It was very annoying at first but I have learned to live with it.
  • Yalegrad,
    Its a misalignment of the gears in the rear differential. You need to get it realigned before you create a more severe problem. Dont let them tell you you need to replace the whole axle because they all have that possible defect. It happens even in the Crown Vics, etc. Just a simple, same day thing that the dealer can fix. Its been an ongoing issue with Ford since 2003 so they know the problem is there.
  • cshaw1cshaw1 Posts: 1
    1998 E.B. that the rear suspension will not air up and the power windows and the interior lights are not working. Has to be a relay of fuse but I cant figure out what one.
    Please Help
  • tottot Posts: 3
    Yes I have had that problem twice with my 99 expedition. I just turned it off and restarted. In addition my engine really rev'd up. Very dangerous but once I restarted it was OK. Kind of like windows. I had to reboot.
    happeded about two years ago and then about a year ago.
  • Thanks for the help. Please let me know if that worked for you. Thanks again I hope it works...
  • We are still having this intermitten problem of the car not starting. We turn the key, all the bells and lights go no, turn the key to start and nothing, not a click or anything. We were told it's related to the anit-theft system, we have had new keys, fobs and a new keyless code, ( we bought the car used wit only 1 key), recently before this started. I have replaced the relays, cleaned the battery terminals, the problem went away for a short while. I live in the Arizona mountians, the problems started when I went to Phoenix at 100 degrees, when I got back to the cool mountians in the 60 degrees, the problems it did not happen, now it's 70 to 80 degrees, it now happing up here. Could the heat be a factor, maybe a hot starter. When it won't start, we let it sit and in about 20 minutes it will start, as if there were never a problem. Any help would be great with this phamtom problem.
    Thanks Highplainsjoe
    Just a heads up on my suspension clunk and steering wheel shake. I removed the sway bar end links and that stopped the clunk. So I guess its off to auto zone for some new ones. I hope the new styles are still about $11.00 per side. Also, the steering wheel shake was the alignment. I never knew it was off. The truck never pulled to either side. I hope this helps anyone with the same issues.
  • megank319megank319 Posts: 1
    I took my 2001 Expedition to the ford deal today.... My overdrive button was flashing "off". They said my pressure control Cilinoid ws closed. If you get the part from Ford its likr $70...I am taking somewhere to get fixed and it is between $210-$350.
  • schiller1schiller1 Posts: 1
    Have 2001 Expedition Eddie Bauer with Leak in windshield on left side.
    An electrical short has developed that has disabled the window / wiper motor and the ignition interlock switch.
    Fuse replacement initially held for 48 hours. Subsequent fuse replacements have shorted upon replacement
    Service technician states it is not the gem module that their is a short within the wiring system
    Any body else have similar problems
  • millerfordmillerford Posts: 10
    I was reading my manual for my 98 Expedition and it was talking about air suspension and I looked at the passanger side kick panel and it said along with Fuel Pump switch Air Sus. or whatever, I looked behind there and I didn't see the switch that was described in the manual does that mean I don't have Air sus? I just don't understand why they would put that kick panel on it that says that... maybe they were just saving money by using that instead of making another one that didn't have that on there.... any comments please reply!!
    Millerford
  • razzmaniacrazzmaniac Posts: 22
    Ok, im asking this question after i brought the truck to the dealer.
    I have a 2003 Eddie Bauer Expy 4x4. When the truck is warmed up and been driven during the day enough, the tranny clunks into 1st gear on the downshift from a slow brake at 20mph. Only happens when its been driven enough and well warmed up. I know its not suppossed to clunk into 1st gear on the downshift but when i brought it to the dealer (in the early morning) of course it didnt do it. And i have a feeling the dealership wont find a problem so i am asking if anyone else has this happened and found what the issue was??
    Thanks guys :confuse:
    I had a 99 4x4 eb that did it from day one (500 miles) still did it when I got rid of it with 160,000 miles. Never a failure with it clunking.
    My Expedition didn't come with rear air but just two little stupid vents on the back of the center console exactly like what the Explorer has. I was wandering if I could possibly get the over head console instaled along with the rear air? Has anyone ever tryed that. I really want rear air and was wondering if it's possible to have that installed????? :confuse: Please help!!!!
  • ephillipsjephillipsj Posts: 1
    Weird, I have a 98 eddie bauer expedition as well, but I do have air suspention. The switch is located on the passenger side right below the glove compartment box. I asked someone this myself and they told me if it is a ford eddie bauer then they all are equipped with air suspension.
  • lucky6p5lucky6p5 Posts: 2
    i have the same problem with my 98 did you ever get it fixed if so what was the problem.
