Can't say I ever heard of smelling the oil dip stick for coolant though. Not all blown head gaskets introduce coolant into the crankcase. When it does, the mix turns the oil like chocolate milk and is a dead give away. I can't say I have ever saw a fellow mechanic smell the oil dip stick.
1995 302, CHECK THE TIMING.
the harmonic balancer is the sheeve for making everything turn.
It has a rubber insert, this insert will slip and change timing.
Late timing, more gas, more heat, less power.
More heat is the first noted problem.
Cats for 95 302 non ford about 300 total (HOUSTON).
Replace head gaskets 302 MUSTANG, $3000.
Valve covers 302 F150' $1500.
Where do I get head gaskets fot $300?
BEST WISHES
old100
I'm too grown up to drive a Ranger - what are my options? Is anyone from Ford out there listening?
Feds Alert Ford Owners to Recalls
Thursday February 28, 5:41 pm ET
By Ken Thomas, Associated Press Writer
Government Warns Ford Owners About Recalled Vehicles
WASHINGTON (AP) -- The government on Thursday warned owners of about 4.6 million recalled Ford vehicles to bring their cars and trucks immediately to dealerships to disconnect cruise control switch systems that have been linked to engine fires.
ADVERTISEMENT
The National Highway Traffic Safety Administration issued the consumer advisory to owners of certain unrepaired Ford, Lincoln and Mercury sport utility vehicles, pickup trucks, vans and passenger cars who have not yet responded to past recalls.
The recalls have vexed the Dearborn, Mich.-based automaker, affecting its popular F-Series pickup trucks, prompting hundreds of complaints and dozens of lawsuits over engine fires. Three deaths have been tied to the fires and Ford has struggled to produce enough parts to fix the problem.
About 9.6 million Ford vehicles have been recalled since 1999 and about 5 million have been fixed, raising concerns about the remaining vehicles on the road. NHTSA said they have received about 60 complaints of engine fires in the Ford vehicles since August 2007.
Ford said they supported the action and dealers would soon offer a more permanent fix.
"We absolutely want everybody to come in as soon as they can because we can eliminate the risk of fire for anyone with a vehicle in this recall," said Ford Motor Co. spokesman Wes Sherwood. He said the company would have an "ample supply" of the replacement parts by June.
NHTSA said many dealers will disconnect the cruise control switches as a "drive through" service so owners do not have to leave their vehicles at the dealership or schedule an appointment.
Dealers have installed a fused wiring harness into the speed control electrical system as part of the recall, but replacement parts have not been widely available. Owners can take their vehicle to a dealer to have the cruise control deactivated until the parts arrive.
NHTSA issued a lengthy list of older vehicles covered by the consumer advisory, including 1993-2004 Ford F150 trucks, 1994-2002 F250 through F550 Super Duty trucks with gasoline engines, and 1998-2001 Ford Explorer and Mercury Mountaineer SUVs, all of which were among the best-selling vehicles in the nation during those years.
A complete list was available at http://www.nhtsa.dot.gov/.
The Ford recalls have run into problems. Earlier this month, the automaker recalled about 225,000 vehicles that had already been repaired because some wiring harnesses appeared to be defective.
Ford also faces more than 100 lawsuits nationwide because of fires linked to the cruise control deactivation switch. Many owners have alleged the fires began after the vehicles were turned off and there have been three deaths attributed to that problem in Iowa, Georgia and Arkansas.
Last week, Ford was able to consolidate 77 lawsuits filed in Texas so a single judge can handle pretrial discovery.
Ford has said its internal investigations have found the fires did not cause deaths and injuries.
"In the cases where there was that allegation, we found that the source of the fire was unrelated to the vehicle," said Ford spokeswoman Kristen Kinley.
For additional details, owners can call Ford at (888) 222-2751.
Ford Motor Co.: http://www.ford.com
kcram - Pickups Host
Thanks !!
I have not had any notice from Ford to come in and have my cruise control fixed
Would using the smaller rad make up for the added airflow and cancel out the mileage issue? I plan on doing alot to the motor this year, should I leave it? or tear it out? The extra room would be nice. If it makes a difference I have also purchased an under drive pully set that has not been installed, I was going to do it when I got the ac thing worked out.
Thanks for the advice.
The truck is fine when I am accellerating but every now and then when I am stuck behind someone in traffic that is bound and determined to go 50k and no faster. Third gear has no power when it kicks down or in at a lower rpm, I have to stomp it to get power. If I am stopped and then drive it runs through the gears no problem, it has lots of power cruising at 65k but if I slow down to 50k I have power loss. I get a rattle as well as if something is loose, but only when it kicks down. Otherwise I have no problem. Tranny fluid is good not burnt. Everything else is good. From a stand still it will pull you back in the seat and flies all the way up 160k (thats is fast as I have had it off the line) but if I have to take my foot off around 50k, no dice....
A friend of mine has Bronco, same year, same tranny, same deal.
Do my bands needs adjusting.
May I ask what you found on your truck and approximate $$$$$ involved. Of course, we are not covered under warranty and can only find that we were covered by the powertrain warrantly until 3 years/36,000 miles. The truck is only 4 years old and has less than 49,000 miles on it. This is just sickening.
Thank you for any information you are willing to share with me.
With that said, my '04 F150 2wd had a complete transmission failure at 28,000 miles, 6 days past the 3 year mark! After all my venting, the best I could come up with is 50% off on a trany replacement. My share was $2,200!!
They told me I was lucky to get half.
I don't feel lucky :mad: . I drive the truck :lemon: easy.
I've also had repeated problems with the front brakes warping on me. I'm on my third set of warped rotors.
Note: If you did not replace or machine your rotors, your spungy pedel may be due to the pads not wearing in to the rotor surface. Try pumping the pedel and riding the brakes while driving for short periods of time.
Symptom of needed bleeding is after pumping the pedel about 3 times there isn't as much free play or spungy feeling in the pedel, it feels tight. If your pedel still feels spungy after doing this, most likely the surfaces of the rotor and the new pads need to be wear in.
Looks like I may have to hire a lawyer and go through Lemon Law at this point.
If anyone has an 08 or similar model with power plug under the dash air vent to the right of the radio, get it to a dealer and have it double checked. My truck is at Dealer lot in Willard, Ohio. Still burned up and making payments.
Loyalty will get you no where with Ford. They used to make a good truck, and if they had taken care of this issue right away like they should have, I may have still been a loyal customer. Defects can happen.....Customer satisfaction is what is lacking in this case! :mad: :sick: :lemon:
I have had it to the ford dealer 5 times and they can't find the problem and does not show on the memory.
TPS Throttle Position Sensor
I took my truck to the dealer with the information you gave me about the TPS sensor. They told me they wouldn't do anything untill the engine light came on.I guess I will have to wait .
Thank you again
Bob
in this day and age of big losses and the money running out, i'm guessing Ford has layed off all but one person who can look at your truck. And he probably gets a bonus for pushing back a certain percentage of problems on the buyers back.
nice going ford
I have not owned Ford, but of course you see what seems like thousands on the road everyday. Just looking for some general thoughts, not "homers" for Ford or "anti-Ford" comments.
Overall satisfaction? General reliability, epecially as the truck gets older? Anything else that might be valuable to us?
Appreciate the time from all...
JLC
