The interior, especially the center console is horrible.
But that's OK. No need for you to wait in line.
You can buy a Ford.
Sheesh, unless you went to the Detroit show, you haven't even SEEN the Pilot in the flesh, and final production specs and prices won't be available for months.
Besides, it's supposedly Swedish car trivia tonight - you don't want to miss that!
Steve
http://www.canadiandriver.com/news/020107na-7.htm
Click on the thumbnails. Has anyone found a greater selection of more detailed pictures than the 6 they have on canadiandriver?
rsholland, re: The MDX and Pilot share the exact same engine.
They don't use the same engine. The Pilot is to come with the same engine as the 02 Odyssey, which does not require premium fuel to achieve its 240 hp. MDX should get a new engine in 03 to keep it ahead of 03 Pilot.
As for fuel efficiency, keep in mind the 02 Odyssey EX Leather (the heaviest Odyssey) weighs only 2 pounds more than MDX (4376 vs. 4374 lbs). Clearly the Odyssey is the larger vehicle and has much more interior space. I expect the Pilot to weigh in slightly under the MDX so it is conceivable it will also have better gas mileage. Also look at the fuel economy specs for Odyssey vs MDX. The Odyssey is rated at 18/25 mpg and the MDX is 17/23. The new Odyssey engine may be a bit more fuel efficient although I know many other factors come into play such as aero drag, driving through 4 wheels instead of 2 for example. In any case, to me I expect the Pilot to be slightly more fuel efficient than the MDX.
Examples: Acura RSX, 02 CR-V.
So before calling the Pilot "outdated" or anything else, it's only fair that judgement be reserved until you can finally see it in person.
They don't use the same engine. The Pilot is to come with the same engine as the 02 Odyssey, which does not require premium fuel to achieve its 240 hp. MDX should get a new engine in 03 to keep it ahead of 03 Pilot. >>
Whether the '03 MDX gets a different version of the 3.5 remains to be seen. Right now, they—the Odyssey, MDX, and Pilot all use the same 240 HP engine.
Bob
Bob
On the other hand, I talked to a dealer who said there will be no changes for 2003? His motivation is obvious, so I take it with a grain of salt.
If the MDX gets a V8 as an option, I bet the 3.8 will replace the 3.5 in the Odyssey, Pilot, as well as the MDX.
Bob
Since Lexus is bringing out the GX 470 next winter, which comes standard with the 4.7 V8, it would not surprise me if Acura drops the V6 altogether, and makes the V8 standard. Then again, by keeping the V6, Acura could still have a vehicle to compete with the smaller Lexus RX 300, which will also be revised shortly. So, who knows what will happen...
This new Lexus GX 470 is to be the basis of the next 4Runner. You can read about here at Edmunds in their Detroit Auto Show coverage.
Bob
No chance I will ever buy a Ford, my two cars now are Honda products (Integra and Civic). The RSX looks like an Integra with a new front end and better equipped. I loved the CL until I drove one and it is very uncomfortable.
Honda is falling behind in styling. Just my opinion. When you look at the other SUVs in the pipeline, this one is clearly behind in that regard. The MDX is a fine machine, so hopefully the Pilot will indeed prove better in person - but the single dial controls and other oddities of the center dash console area are just plain weird.
It is amazing too, that in the 80's they produced a Civic CRX that got 50 mpg and here we are 20 years later and they are hyping a hybrid Civic which still only gets 50 mpg. At least Honda is trying.
But it seems a critical eye is not a bad thing when it comes to evaluating a much anticipated new product from an industry leader. A cheerleader I am not.
http://www.caranddriver.com/xp/Caranddriver/features/2001/october/200110_preview_hondaodyssey.xml
The MDX has more torque and over a broader range. Remember that engine hp is based on torque times RPM, so given the MDX's extra torque, the Odyssey must achieve its 240 hp at a higher RPM than the MDX does. The specs support this. The 02 Odyssey is rated at 240 hp at 5500 rpm and 242 lb.ft. of torque at 5500 rpm. The MDX is rated at 240 hp at 5300 rpm and 245 lb.ft. of torque over a range of 3000-5000 rpm. The MDX's torque must drop below that of the Odyssey's when it gets to 5500 rpm for them to acheive the same peak hp rating. The MDX would clearly have more low-end pull.
Good look at the tire tread on some of these--unidirectional tires. Anyone recognize the tread pattern? I don't suppose these tires will come on the production version though.
<< To pump more power from the 3.5-liter V-6, Honda borrowed the Acura MDX's larger-diameter, two-stage intake system and freer-flowing exhaust to reduce resistance. The MDX's three-rocker VTEC variable valve timing and lift system extends and enhances the engine's range, and a bigger-bore throttle body, larger-diameter valves, and an increased compression ratio (from 9.4:1 to 10.0:1) do their part to bump horsepower from 210 to 240 at 5500 rpm and boost torque from 229 to 242 pound-feet at 4500 rpm. That's the same power and three fewer pound-feet on regular fuel than the MDX puts out drinking premium. >>
So the advantage of the MDX engine is that it gets 3 more foot-pounds of torque, but uses premium gas. I think I'd rather have the Honda version...
Bob
We are all speculating that the pilot will get the odyssey version of the engine? Maybe it won't?
Bob
On my 99 Odyssey, which gets 210 hp with premium and 205 hp with regular, I run it on regular. I tried premium for a few weeks and couldn't tell the difference. For what it's worth, my vote would be for the 240 hp Odyssey engine in the Pilot so I could avoid the extra 15% cost of fuel. I'd live with the slightly lower performance. I'm happy with the performance of my 99 Odyssey 99% of the time, but there is the odd time when you need power fast and you've got to wait that extra second or 2 for the "whoosh" to kick in for the revs get up closer to 4k.
Perhaps we should do a little survey. If you were buying a Pilot, which engine would you rather see in it, the 02 Odyssey's or the 02 MDX's? Assume it had no influence on the overall price of the vehicle, just on the price of fuel and on performance.
But a column shifter!
I like the steering wheel and gauges, but I hope that there is another interior color besides that awful looking brown (hopefully gray).
We did not discuss pricing. It's irrelevant to me because I figure if the price isn't MSRP or less I'm walking. There are way too many other vehicles to choose from to get suckered into paying more than MSRP. Besides I also have the option of keeping my Accord a little while longer. Hey it's paid for.
The Pilot will cost around the same.
What makes the Pilot so special over the Highlander?
I am kind of partial to Hondas but I am not so sure the Pilot is all that great looking on the inside.
The Auto Show comes to Chicago in a few weeks. I guarantee there is alot more interest over here.
Judging by this message forum, there is alot more interest in other parts of the country as well.
I guess if you are a Honda fan you won't probably go wrong with the Pilot, but after looking at more pictures I am less enthusiastic about it.
by changing the rear a bit, making it wider better access and more space, everywhere i have read that it might be shorter but more interior volume, a minivan purpose with a suv soul. as far as engine, hey my ML320 has around 222 and it has no problems even at 42-4400 lbs. and i can use reg gas. my wife likes all the pictures i have shown her , it will be her decision go or no go.
That dealer, Mark Roberts Honda, now wants $1,000 deposit for thrill of paying MSRP. And they used to brag about doing well on $316 over invoice. Hmmmn.
Great deal, great van,--how did Honda do this? Now we see a clever platform/factory sharing venture that will reach maximum production capacity about 2 years too late. We see some shortcuts but not very noticable ones. Mostly that is. Questionable audio and hard plastics.
Worst thing is we see the personality of our local dealers changing. Acura is now same way for the hot sellers. Had Honda anticipated this better and laid down some standards to dealers a lot of bad feelings would have been averted. I think Honda/Acura and its 1400 dealer network will reap the harvest of these practises 2 or 3 years from now.
MSRP is almost fair for most of these vehicles, Pilot, MDX and Odyssey. However, the mistake was not going to a one price policy officially. One price policy would lead to better dealerships because you would go to the one that treats you better.
So get in line for Pilot if you want one. Watch the dealer attitude. You will get no perks for paying MSRP. Dealership the same or worse. As for me no Pilot.
Why in the name of sense, Honda does not narrow the cost to MSRP margin more is my question. They did narrow it slightly with the new 3% holdback. yes, you pay MSRP and dealer still gets 3% holdback on top of profit. If I were Honda, I would improve the product more, raise invoice to pay for improvements and keep MSRP the same. This way the dealer cannot laugh so hard on the way to the bank.
INKY
The Accord regained its place as the best selling car in America last year. What is innovative about the Accord's styling? Seems Honda has a pretty good handle on what people want in a car, IMO.
For what it's worth, my comments are based upon having over 30 years experience in the graphic design field.
Bob
http://www.autoshow.ca/exhibitors/honda.htm
To those out there who think I am bashing the Pilot, I am not. I'm sure it will be an excellent vehicle. And to those who prefer conservative styling versus pizzaz, I AGREE with you. Conservative, tasteful styling Does hold up better in the long run. Unfortunately the Pilot is NOT tastefully styled to begin with. It's front end is anycar or anySUV styled. The profile is virtually exactly 1997 CRV (by the way, did anyone ever think the original CRV is well styled?) and the rear of the Pilot is again any SUV from 1992 to 1998. My contention is that the PIlot could have been tastefully styled, but no one at Honda wanted to stick their neck out.
The USA isn't the only country where Honda and Acura are differentiated ...
I agree, but then styling didn't stop the CR-V from crushing sales of the more interesting looking RAV4.
