Interior Maintenance & Repair
Does Crayon come out of cloth upholstery? Had an experience with those do-it-yourself leather repair kits? Post your interior maintenance questions and answers here!
kirstie_h
Roving Host
Edmunds.com
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Curious what people are using to protect their leather interiors and also what are you using on your fabric now that Scotchguard isn't available?
The solution is so simple and inexpensive. I've used it on my husband velour seats in his Z, the bed pillows, hair, and carpeting. RUB IN A DAB OF PEANUT BUTTER. IT WILL DISSOLVE THE GUM AND THEN WASH THE SPOT WITH DISH DETERGENT. PROBLEM SOLVED. GUM GONE. GOOD AS NEW.
kirstie_h
Roving Host
Edmunds.com
Review your vehicle
1) How do I repair?
2) Do leather repair kits work?
The tear is only at the surface. The tear is less than a 1/4" in length.
Thank you,
Alex
I'm starting to think about salvaging some old fabric seats off of another car.
Any advice?
I have used Quick and Brite on the rugs and cloth seats of my mom's Honda Accord. It worked great. She had coffee and grease stains on the rugs and other food-like stains on the seats, but, after I was done with it, the rugs/seats looked like new.
if you REALLY wanted to change those seat covers, you could locate a shop with auto-grade fabric, pull the old covers off after finding and undoing all the tuck sewing and/or strings that hold them on, cut and pull the stitches apart, and use the old vinyl as templates to cut the new fabric. fix up any ratty foam you find along the way with high-density UV-resistant stuff, and have fun sewing that heavy fabric by hand.
I think you'll find out of the $500-odd, you only save between $100-150, and your equivalent labor cost will work out something like $2.50 an hour by doing this yourself as the first job. if you are doing this with a shows-all-flaws material like vinyl or leather, like half of my recliner used the one and only original Naugahyde (tm), all non-machine sewing will be apparent.
use cheap materials and sew while barleyed-up, and the results will reflect that from the first moment the seats are clothed again, and even worse after the first week.
WARNING! if you have side air bags in those seats, like my Explorer has, all bets are off. the panel that covers them has to have specific characteristics so the air bag can burst it correctly and work.
