Compact pickups and tow ratings
                    and one of the features I'm looking at is towing capability.  I have never towed with my current vehicles, but I have a small tractor that I would like to be able to occasionally trailer.  I would probably be using a 16' car carrier or similar trailer (w/brakes), and all together the tractor,etc. + trailer weight will be around 4000-4500 lb.  I would like to stay with a compact pickup instead of a full-size, but I'm wondering if those 5000 lb tow ratings are overly optimistic.  I just don't seem to hear about people with compact pickups towing those kinds of loads.
Anybody care to comment?
Hope this helps
dave
kip
If I were you, and don't want to spend around 30K for a new full size P/U, I would try and find an older Ford with the Power-stroke diesel and a manual tranny. Avoid any older Chevy or Dodge diesel (unless the dodge has manual tranny too, but I still think the Fords are better). The reason I recommend a used diesel is that diesels really last, usually until at least 250K-300K miles.
kip
kip
However, if you are not going to be towing very often or very far, many compacts will handle it especially if you do things right.
First, make sure the trailer has brakes either way, full size or compact,
Second, for a compact, use an equalizer hitch (weight distributing), this will reduce the amount of wandering around the road,
Third, get a manual tranny, especially for a compact, the auto trannys in compacts won't last long pulling that kind of load.
If you think a compact might still be an option, find a rental with a class III receiver, and try it one day.
I recommend that you have your trailer ready for an equalizer hitch first, to get a real picture.
That will be a $30 rental, and it may save you a bundle.
Just surprised to see the name of the town, since it is a pretty small place if I remember right.
the ranger is rated to tow more than any other compact in its class. i have an '01 brochure here, and it says that it will tow as much as 5600 lbs. i believe that's more than any other compact 'cept for S10. i've read that the toyotas need helper springs if you want to do any heavy duty towing. also, the ranger has a higher gvwr rating. get a good class III hitch, and you're set.
-And no, the Tacoma doesn't need "helper springs" to tow anything.
Interchangeable drivetrain components? Every manufacturer does this to some extent. Why reinvent the wheel everytime you come out with a new model? The fact that the Tundra uses many of the tacoma's drivetrain components is really a testament to the durability of the tacoma.
I see people flying around with small vehicles and big loads but they apparently aren't concerned about liability policy limits. Using the vehicle to tow once in awhile is one thing, but buying a small vehicle knowing you're going to do alot of 5000# towing is asking for trouble. I see alot of trucks/suv's have dumbed down tow ratings just to keep people from doing stupid stuff.
I currently tow a 17 foot 1992 Aljo lite travel trailer. It recently weighed in at 3000 pounds fully loaded. I live in Northern California and try to camp one week a year in Yosemite and 2 to 3 weekend trips to Lake Tahoe. I have NO trouble going up either Hwy 120 to Yosemite which has a 6% grade @ 6 miles in length to climb(Priest Grade) or up Interstate 80 over the Donner Summit (7200 feet. I have trailer brakes (required for anything over 2000 pounds)I recommend having at 1,500 pounds and a load equalizing hitch which takes the weight from the back of the truck and moves it forward to the front wheels. We have a cab high shell and usually carry 200 to 300 pounds of gear, ice chests, wood etc in the bed of the truck. We have never had an overheat problem, and the gas millage with the trailer and gear is around 12 to 14mpg. Due to the length of the trailer, I do not need a sway bar. The trailer is small enough that it does not wag the truck.
To tow anything over 2,500 pounds and especially if there is any height for wind drag, you definetly want a vehicle that has a tow package which should include a larger radiator, transmission cooler, 120 amp alternator to charge the trailer's battery, heavy duty flashers to run the trailer's blinkers, 750 amp battery and trailer wiring. Not sure that these options are available on the Tacoma, S-10 or Ranger, but don't settle for a tow package that includes only a hitch, as it will not do what you want and you will only be endangering the rest of us.
I had the same decision as I didn't want a large truck, but I needed a truck that could tow and I would still feel safe. The extra room in the Dakota cab is also very nice.
Good luck and happy towing!
The 4' X 8' (next smallest) weighs 780, load capacity of 1220, for a total of 2000 #s.
With the weight capacities listed, I am guessing that both include surge brakes.
-Eric
So decide for yourself:
If you want to tow a lot on regular basis, get a midsize or fullsize.
If you are gonna tow only occasionally, get a compact, you'll be happier with one.
And as always, do your research on the truck you want to buy. Read some newsgroups here. carpoint.com and edmunds.com are excellent sources of initial info.
Don't worry about me being influenced by comments about one brand over another. I've got my own opinions about the different makes, and they're probably not going to change much based on what I read here.
kip
BTW if you're gonna tow in soft dirt or up steep inclines you can cut that max tow rating in half or buy 4X4 for the gearing and traction advantage.
As for gas mileage, there's a poll going on over on tundrasolutions.com, and it looks like the people with Tundras average about 16 mpg. I had kind of hoped that I could get at least 18 mpg (maybe a little better) out of the Tacoma V6. From what Kip says, sounds like 18-19 mpg is about right.
Plan C? Buy an Impreza WRX wagon, keep my pickup, and screw the towing. (Just can't picture myself in that car, though. I'm partial to trucks).
kip
About the gas milage: I'm hoping my milage will improve soon. Last fillup I got 15mpg (220 miles for 14 gallons), but that was:
1. 6 hours of offroading over tough terrain.
2. 90 mile drive back to town, 85 all the way, which usually gives me 18mpg.
3. Rest is city driving.
Seeing how I have a magnaflow muffler which reduces gas milage by about 1mpg, I am hoping the new tank will last a little longer. My milage just on freeway going 85 is 18mpg, with the muffler.
It all depends on how you drive. I like to be the first one from the traffic light, so that means revving up to the 3500 rpms, which somewhat justifies my low city gas milage. Hope you don't have a lead foot.
That would get you the mileage, as well as the tow ratings. I don't think I would try and tow 4500#s with a V-6 full size on a regular basis.
-Eric
Either way a compact will be ok for 2-3 times per year as long as you're careful. But I agree that the V6 compacts don't get much better mpg than alot of full-sizes. The other issue is the actual weight of the trailer and tractor. I underestimated the weight of my combo by nearly 1000#. If you have loaded tires that really adds to the weight.
Bob
BTW, I really like my Silverado ExtCab Z-71 5.3L 3.73 for towing - tows this little boat great.
Whatever you decide to get, try to get a limited slip/locking rear if you think you'll ever need to pull a boat from a (slimy) boat ramp.
I've been at the other end of the power spectrum (50 hp diesel VW Jetta) and I'm not going back!
Sounds like your Silverado works great for you. You're right about the fuel costs not being a big deal, I think as long as gas doesn't go up to $2.00/gallon and stay there. I like the looks and features of the Silverado but it seems like there are a lot of problems reported with them too. Sounds like you've made out well with yours, though.
Take care.
My wife works in Solomons (also called Solomons Island to the old-timers & technically, it is an island, having a tiny bridge at the Lore Oyster House. Its gotten tourist-happy & those good restaurants are pricey (ouch).
Have you looked at the Tundra yet? Those 4 door Access Cabs look really practical & rigged right, should do a fine job towing your trailer.
Are all Rangers having the axle problem? No. Only 2500 of them. it's not just towing thats the problem. Read the article carefully:
1. Under heavy load.
2. Taking off too fast.
3. Tire gains traction after spinning.
2 means that you can't gun it from the stoplight.
3 means you can't take the damn thing offroad, which is what it was meant for, apparently.
Where is that problem with water leaking through the firewall? Show me some docs on it. I havent heard anything. I don't have any water leaking through.
Whats that linkage problem?
I don't care for Camry, I really don't.
I write software. Our software relies on the fact that we can interface our device drivers with our mainstream programming software, Labview. If this was FX4, our driver would randomly produce a crash to the user saying "Can you please scan the data slower? Even though my specs say I can go 100Mhz, I really can't do that..." This is what I mean.
Great products come not only from great parts put together, but from the great way those parts are put together. If the Ford engineering did not test/forsee the problem, and QA did not catch it...what does it say about Ford?
