You can email me.
Any ideas?
Jim
Looks like the ask tray light has jogged loose and is laying under the ash tray holder that also holds the cig lighter. Anyone know how to get the unit out to get access to the light? Taking out the ash tray only doesn't get at it. I guess I need to take the whole unit out?
Any ideas? You can email me about this and/or the windshield washer problem posted earlier.
Thanks again.
Jim
Jim in MA
Only reason I know this: Used to work at the Daewoo dealer service department back home. Good luck!
In summary, the problem could be fuel filter, camshaft sensor or fuel injector(s)
Fangs
Fangs
--Jim
Turned out to be the O2 sensor (rear) needed to be replaced
Just curious...?
My predictions are finally coming true. One of 8 cars sold by GM last year was a Daewoo built vehicle. Sooner or later All America will be driving rebadged daewoos. That is if GM does not go belly up very soon
The one around here left years ago. I would guess body and trim pieces would be pretty hard to come by.
I would guess these are dealerships that took on Daewoo as an additional line rather than a free standing store.
They are probably trying to help their onwers by continuing to work on them as much as they can.
Isuzu dealers are fading pretty quickly as well so I know I wouldn't spend a lot of money trying to keep a Daewoo alive. A lot of the mechanical parts aren't the same anyway.
One reason for this availibility seems to be that many owners did not follow the maintence requirements for changing the timing belt-hence many used parts on ebay.
Luckily,in my area,there were many multiple line dealers who sold DAEWOOS.
I own a 2001 Nubira. When the engine begins to heat up the car begins to kind of surge forward and back, kind of like it is rocking. This only happens when the car is in drive and when I am stopped at a red light. As soon as I switch the car to neutral, the surging stops.
I took the car to Firestone and they said that it might be the spark plugs or the spark plug wiring, but I'm not sure.
Any idea of what it might be and what I can do?
email me @ kentalan_@hotmail.com
It "might" be the spark plugs or wires?
That should tell you something!
A good mechanic won't "think" it's a valve cover gasket, they will KNOW what the problem is!
It is a very easy and fast job if you know what you are doing. The mechanics at the dealer usually do it in under 10 minutes.
Just wanted to confirm that the oil Fill plug to a Daewoo lano manual tansaxle is on the right hand side of the transaxle where the drive-shaft exits the gearbox housing.
Once I jacked up the car enough to be able to get completely under it, it was plain to see - if not a pain in the xxx to fill through.
Cheers,
David
Just wanted to let everyone know that deadwoo2's advice did the trick. My husband took the EGR valve off, cleaned it w/carb cleaner, and put the gasket back on. He did this about 3 wks. ago....and I have had no problems at all since then. My car runs great!
Thanks Deadwoo2!
I was going to get the parts from the scrapyard, but as there aren't many Nexias there, and the build is apparently the same as some older vauxhalls, I'd like some advice as to what cars I can grab my parts from. And what years.
Here's what needs seeing to:
Nearside rear Axle Bush
Nearside rear Brake Pipe
Nearside Front to rear brake pipe
Offside Front to rear brake pipe
Coolant Temperature sensor
Cheers
--Jim in Boston :shades:
