GM's 3800 Series II reliability
How long can the engine last (typically?) with proper maintanance? 250 000kms?
My mechanic said that I needed to replace the seal around the engine oil pan because it was leaking. Is it a common problem for this engine/vehicle?
My coolant level is also low, at the 'COLD' level even though the engine is warmed up (driven for more than 15kms). No signs of leak on the ground. I have to fill it up everytime I change my engine oil.
Any Ideas?
Any Ideas?
Good luck!
I think my alternator is starting to go down south. If I had the rear defroster on, my turn signals would slow down by about 1/2 a second between intervals. It couldn't be he battery because it was replaced about two years ago.
The alternator issues with the old 3.8L GM engines is no longer case. Now it seems the new host of chronic alternator eating is the Olds 3.5L DOHC V6 engine.
Current 3800 Series II V6 engines are ULEV certified since the 2000 model year.
With proper care and maintenance, you should be able to get out 200K+ miles out of your 3800.
It lost its title in 1998 to Oldsmobile's 3.5L DOHC V6 engine found in the current Olds Intrigue and the 2000-2001 Olds Aurora 3.5 sedan.
TB
Who has both a 3.8L GM and the 2.5L HO Duratec
http://www.industryclick.com/microsites/index.asp?srid=10430&pageid=1794&siteid=26&magazineid=50
TB
Short version; great engine. enjoy it.
my mechanic said that for all the trouble it would be, not too, at that mileage, I should change out the timing chain. Did so, and it was on its last legs, did the water pump as well. And yes it would eat the odd alternator like all the GM's and come to rest waiting for the tow truck, anywhere it happened. (usually right at an intersection) Now have the 3.8 Series 2 supercharged engine in a 97 Buick Park Ave Ultra, and it propels that 2 ton of chrome and leather, like a V8! Also gets better mpg's In one of GM's Stupid Engineer Tricks, they buried the power steering pump under so many lines and so deep at the back of the engine bay that you need a map and a flashlight to find it. Then when you do, an extra joint in your arm to get the top off. I pull out the old contaminated P/S fluid with a little pump and change it every other Motor Oil change. For a few bucks worth of fresh P/S fluid it's money in the bank to me. I have had to change out 2 complete P/S systems over the years, because of rack wear, and I have said 'never again'! GM says "just top it up and , don't woory, be happy'....don't believe it....get that dirty oil out of there, and suck out the 8 oz.'s of GM's " special oil" in the supercharger as well and get rid of all the filings from the gear and bearing wear. You will have to buy 2 little 4 oz bottles of new supercharger oil at a GM parts counter every now and then (say 30,000 miles) , but better that than a $2000.00 Eaton Supercharger R&R
In 6.5 years, it's never failed to start, even in sub-zero weather.
Here's the repair sheet so far: at 29,000 miles, water pump and throttle body; fuel filter at 39,000; injector service, PCV valve, alternator, fan belt at 44,000.
These things don't seem out of line to me for almost seven years of service, but I'm no mechanic.
Bottom line: to me, a great engine, strong, quiet, utterly dependable. One of the things, along with the transmission, that GM does right. If only the suspension and steering were more responsive -- that's mainly why I'm in the market for something new.
