-revver
PS this is a good paint code search sight:
http://www.paintscratch.com/search.htm
Tonite I had some major problems with my Blazer. During the drive home on the open highway she broke down. I was passing a truck at the time of the trouble. As I applied the gas to pass the slower vehicle, the Blazer seemed to hesitate and kind of lose power. It soon regained power and I made it past the truck. Within minutes I could clearly hear one (or more ?) of the push rods tapping loudly. Just as that happened I could smell motor oil and then the oil pressure gauge shot to zero.
Needless to say I quickly shut the Blazer down and pulled over onto the shoulder. I inspected the Blazer and I did not see any fluids leaking from underneath or above. I did not see any physical damage to the engine at all. I checked the fluids and they were all
within reasonable/applicable levels.
As I waited for the tow truck, out of curiousity, I attempted to start the S10 Blazer. She did start and I could clearly hear the push rods tapping very loudly. I turned the Blazer off within a blink of an eye.
I am no mechanic, hence why I am posting here. But I know a little bit...enough to get me in trouble. It is my opinion that the oil pump gave up the ghost. Would you agree with that?
Also, if it is just contained to the oil pump failing, is there possible damage to the rest of the engine? Is it even worth having repaired, keeping in mind that a mechanic would probably have to tear into the engine and inspect it before assessing the cost, considering it is a '92 model with over 225k miles?
Your ideas and opinions are appreciated.
I also will start it sometimes, drive off and the trany won't shift into 1st till about 3000 rpms and again I can turn the truck off and back on, and it will be fine till the next time. I have had to 5 different mechanics, and no one can find the problem, I am going to take to a GMC to see if they can figure it out, I have avoided dealerships because they charge so much, but i do trust these guys. If anyone has an idea of what is going on please let me know, The mechanics I have taken it to have hooked up to a computer and it not register anything, this is mindboggling to me and about to give me a heart attack since it's my only vehicle, and my lifline to my son.
the motor threw a rod through the engine block. Its unfortunate for several reasons. Though I am down to one vehicle it is more distressing to know the old ride has ridden off into the sunset. But it sure was a good automobile for some 225k miles.
I have heard the 2.2L engine is pretty good from people I have talked with. When I bought mine I really wanted the Iron Duke engine (2.5L), but my Tahoe S10 package was a great price with the 2.8L. The 2.5L has got to be one of the best four cylinder engines for longevity ever made.
I own a 95 Chevy S-10 with the 2.2 liter (hamster in a cage) engine. It has 160,000 miles. Recently, it started running rough and loosing power. Occasionally, the truck would run very rough and stall out. Finally it stalled out and would not start again. After about a day, I went out to see if it would start again. I did but only ran for about 30 seconds. Then it died and would not start again. I have no idea what the problem is. I replaced the MAP sensor and the ignition system (coils, wires, ignition module and crank sensor). It still does the same thing-Runs for 30 seconds, sputters out and will not start again. Any idea what the problem is? It is getting fuel and almost seems to stall out because it is flooded. Any help would be appricated.
Should I go on? It's been a royal pain in the behind! If you find out any answers please let me know and I will do the same.thanks
:confuse:
-revver
Ok, while driving home (50 miles), it red lined and out went the antifreeze. So, I called the dealership and they towed it in and fixed it...ha, ha.
Now, with my other long lists of minor repairs (they have an autonation warranty for 2 mos) I took it in yesterday... and again, it over heated.
Now, they are angry because I put this purchase on a credit card. Just yesterday I contacted the credit card company, told them everything and I wanted to give the car back so, they will get involved to resolve everything.
I am now very leary in keeping this car.. GM knows the dex-cool is a major problem. Now, with it overheating, I am afraid I did a lot more damage... head gasket, something..
Any clues out there? One on the over heating, one on a warranty, and about the return of the car...
:-( :confuse:
Tek
Tek
Hope that helps.
Tek
Tek.
Tek
Digga
Ball joints (actually the entire front suspension)
4WD transfer case WILL go bad at somewhere around 80-100K miles
Fuel pump
Very poor mileage for a mid-size SUV/Pick-Up
Minor issues:
Door hinge pins wear out, causing wind noise
Stereo speakers tend to cut out after a while
Vehicle will develop a TON of annoying squeeks after about 50-60K
