Small trucks: Which one is the best for light duty?
Sure, there are the big Fords, Chevys and Dodges... These monster trucks can be extremely usefull. While I don't want to say that nobody should buy these trucks, What kind of truck would one suggest for lighter duty?
Here's what I'm looking at. I'm putting all my predjudces aside, looking at all the "Compact" pickups avalible today. Ford, Chevy, GMC, Dodge, Nissan, Toyota... Now I must ask for your opinions: Which is the best truck?
Here's what I'm looking for:
Enough power (Light hauling duty only. 6-cyl acceptable, 4-cyl will probably do.)
Good mileage (20mpg highway minimum. The more, the better.)
Low Cost (I'm not going to buy a $30,000 truck. The lower, the Better)
High dependablity (Low maininance and long life are good qualities)
Good Safty (Crash test scores, tip-over ratings, etc.)
I expect a few heated discustions over which truck is the best in this catigory. That's fine. I actualy don't think there's a bad truck to choose from...
Pathway
Pathway
Tacomas are nice but too much money and S-10's are kindy crappy if you ask me. And Dodge... eeek!
Oh well.. my two cents worth.
My two cents.
toyota and nissan say they're american made, but go ask a dealer. they'll tell you the engines and drivetrain are all shipped in. nonetheless, they're both exceptional trucks as well. the toyota is nearly untouchable (meaning you can't buy one easily) due to availability and price. the nissan is a downright bargain, with a 4x4 crew cab XE auto. retailing for just over $21000.
the dodge ive heard bad things about, although i've never owned one.
i had two ZR2 S10's, both were tough, good looking trucks with no trouble. dont be scared of one. the ZR2 may be the best looking 4x4 pkg. offered today. make sure you read its list of factory modifications, it truly is an off-road wonder, and it is all factory off-road stuff, direct from the factory. not aftermarket stuff like the TRD supercharger is.
i have had three rangers, and my dad has had one. his has around 205000 miles on it, and still runs like a top. stock clutch and is even a 2.3 I-4 with 4x4. ford doesn't let a 4x4 go with a 4-banger in it, only V6's now, so you don't have to worry about not having the torque. toyota is the only manufacturer to still offer puny 4-cylinder engines in its small trucks. can you say cheap, but overpriced? that's toyota's philosophy. and now toyota is in a heated debate with its customers because their V6's and I-4's develop a sludge problem and freeze up at 40K, and toyota won't even replace them unless they have actual documentation of a factory oil change at recommended periods. whatever.....
bottom line, you can't go wrong with most of them. toyota guys will tell you their trucks last forever. however, their rusting capabilities equal that of michael jordan's capabilities to score 35 ppg 5 years ago. and their engines still have cheap timing belts on them which need replaced more often than others' timing chains. and now the sludge problem. the dodges are also not known for their bulletproofness. the ranger is proven and outsells everything in its class year in and year out. the nissan will go forever and is cheap but still offers lots of gadgets. the S10 gets the job done, just at the expense of a very old but reliable chassis. good luck.
oh yeah- my '01 ranger s/c had the off-road pkg, 6 cd changer, power everything, step bars, rear slider, keyless, 207 horse 4.0 and auto., and it was barely $19000 with all rebates and dealer negotiations. go drive one. they run hard (the 4.0). one more thing, the new FX4 pkg. has problems with their rear axles (covered under warranty), so you may just want to stick with a regular XLT off-road if you do indeed want a 4x4.
good luck.
Keep up the good work, if you haven't figured it out yet I am being facetious on the good work remark....
Just to refresh your memory Nissan's also have timing belts.
also, how can it be biased when i basically said any would do. the only downplays of other makes i stated are absolutely true. the toyota's are more expensive, and they also are having trouble with sludge buildup. the dodge's i admitted i hadn't owned one, but have read negative comments. the S10's i said were old but still good. please let me know what part of the post was biased, or in other words, the part you didn't like.
you know, re-reading my post i just thought of something after your remarks on it. the ranger, with its cheaper price and outstanding value and standard features, is just too good of a looking truck for you toyota guys. you are jealous cuz a loaded ranger can be had for lots less than any toyota and with more standard stuff, and lets not forget about the more torque and hp with the ranger. how much did it cost you to finally be able to say you have more power than a SOHC'D ranger? $2000-$3000? oh, if i would've opened my tailgate and drove 55, i could've easily gotten 24-25 mpg im sure too.
Hopefully this will assist in your decision.
Toyota Tacoma 0.2
Ford F-series 0.3
Chevy Silverado 0.3
Toyota Tundra 0.6
Ford Ranger 0.7
Nissan Frontier 0.7
Chevy S-10 0.9
Dodge Dakota 1.6
So, let's shake things up a bit. First off, let's get biases out of the way: I'm partial to the import models. Why? My experience with domestic and import _cars_. Cars aren't trucks, but none the less... I've experienced build issues with Fords and Chevys/GM. My import cars have been problem free. Think my bias is wrong? Here's your chance to change it.
Here's another monkey wrench to throw in: What about the new S10 coming out next year? It's being made by Isuzu... does anybody know some details about it?
Now remember, I'm looking for light duty trucks: No 4x4. No hauling. Looking for 20+ highway mileage. Man, with my criteria, why can't they make a truck that's front wheel drive? Sm:)e.
Pathway
ford focus
toyota echo
why would you want a truck if you didn't plan on hauling in it and wanted good mileage? go buy a hatchback.
I need a truck, not a closed vehicle. I'll need something that can move large and ungangly objects, if needed. Ladders, the ocational appliance or couch.
Funny: I make an unbiased post, and I get a lot of good responces... I put my bias in, and all I get back are "Buy an Echo".
Pathway
have fun and enjoy.
The reason he says "2X2" TRUCKS is that there is a small bed welded to the rear fender.
Yeah right...
hmmm interesting
Well - since your Lemonado has spent more than four months on the rack, I would have to say it more than qualifies. In fact - I would say that it is not suited for light duty since a truck has to be out of the shop to be worked. Maybe you could start charging the shop for storage?
Nissan Manual 22 city 25 highway
Nissan Auto 20 city 23 highway
Toyota manual 22 city 25 highway
Toyota auto 21 city 23 highway
Don't know what the Ranger/B2400 gets, but it is probably pretty close.
As for the Isuzu, you probably would not want a first year model. Go over to the Rodeo posts and read about all the problems the Rodeo had when it was redesigned in 98 or 99.
ranger 2.3 for '02 gets 24/28 mpg.
135 horsies and 150 lb/ft of torque i believe.
2x2 truck- you all knew what i meant. 2x2, 4x2, it all means the same imo- 2-wheel drive. or, iow, absolutely useless where i'm from. )
natureboy
Please disagree. I'm trying to follow you but of course your post doesn't say much.
After you build 'em on paper, decide whether you can get the options you want at your price. Alot of the time I couldn't. Then test drive.
I decided on the basic toyota taco extra cab. Yes I know it won't get out of it's own way, but mileage is a factor. 80% of the time it will be empty, and 99% of the time on paved roads. but that 20% will need to carry up to half a ton of "stuff"; tired of dragging the seats out of the van, worried about scraping up the interio and vacuuming the carpet!!.
Everyone says stay away from the S10 and the aincient chassis from 1994.
Stay away from the compact truck with the biggest V6 available. Can you say Torque?
4 wheel ABS and dual airbags are standard and so is power steering. Posi is a great option!
I use my truck much like you would use yours...back and forth to work and fill up the bed on weekends. I get over 20 mpg with @ 42,000 miles on my truck that I bought new.
Forget light duty, the S10 can haul/tow the most as far as compact trucks go, as long as you get the V6.
all those features they list HAVE to be on there, because if not, no one would ever buy one. compared to dakota, ranger, frontier, tacoma, and mazda, they suck.
they sell poorly and look awful unless you get the top of the line 4x4.
i admit though, that i havent driven one much. most of my info is from people who own them. they sure look cheap inside and i dont think i could stomach paying MORE than a ranger for something LESS than a ranger.
As for 4.3L......yeah, it has 30 lbs more torque than my Taco. It's also a great gas hog.
87 blazer 2wd 2.7 V-6 130K no problems sold may of 2000 still on the road
92 S-10 2wd over 105K. 4.3 V-6 great truck
My dads 92 4.3 seems to have more power than my moms 00 4.3 (blazer). I drive these once in awhile and i can tell a difference. The older one is better
