New truck dilemma
                    Hello.  My husband and I are going to buy a new truck.  We've pretty much decided on Ford, but the decision we're bogging down on is, which one?
We have an F250 Power Stroke Diesel. We need the truck for hauling horses on trail rides. This consists of usually parking in someone's pasture for a couple of days and then moving to someone else's pasture. The 3/4 ton doesn't have any trouble actually pulling our trailer (a 3 horse slant load aluminum Sooner with living quarters). Full weight is probably somewhere between 10,000 and 12,000 pounds. The problem is that we keep getting stuck. So, we think we need the 4X4, but do we need the 4X4 dually or the 4X4 single rear wheel? What's the advantage or disadvantage of a dually over the single wheel.I want the crew cab; hubby wants the super cab. I've been told the crew cab is only about 16 inches longer and I like the extra sitting space. We need the 8 foot bed for hauling lumber, etc.
So, what do all you truck people out there think?
The Ford F250 4X4?
The Ford F350 4X4 Single Rear Wheel?
or The Ford F350 4X4 dually?
I'd love to see all of your responses. Thanks!
The Ford F250 4X4?
One last thing. You didn't say whether or not you wanted an automatic or manual. Go with the manual tranny, you'll be happy you did.
X Cab Superduties are pretty big inside, but back seats are not comfortable for long rides except for kids. I've got Crew Cab and it's huge inside. Everybody's happy! I really like the four doors for getting stuff in and out, lot easier than half doors on extended cabs. Lot of Superduty X-Cab folks I've talked to regetted not getting Crew Cab, but not the other way around. One note - Crew Cab w/ 8 ft bed makes for a really long beast - get the Reverse Sensor, it makes backing up in parking lots less of an adventure. (Bad Point - Reverse Sensor detects you trailer. It has to be manually shut off every time you put it in reverse. You learn to hate it when towing, but it's otherwise its a real neck saver.)
Sebring and Mullins already talked about srw vs drw traction/stability, so I'll just add a couple things to think about . As for getting stuck, extra weight of diesel tends to makes the truck front heavy when in the muck. PSD 4x2 has to plow it's way out; at least 4x4 can help that heavy motor pull itself out. I don't use my 4 wheel drive that often, but when I've needed it I never regretted the extra money. (In blizzard last year, neighbor gal went into early labor - my 4x4 ended up being a life saver.) When you need it, it's priceless. If you don't get 4x4 at least consider a limited slip rear end; they shift torque to the wheel that has traction. A lot of hard core off-roaders aren't thrilled with the Ford LS, (I haven't had any complaints with it myself,) but it prevents you from sitting there with one wheel spinning uselessly in the mud. Better yet with 4x4 and LS you'll always have 3 wheels getting traction. Not saying you still won't get stuck some times but at least you'll have a fighting chance of getting out. I always liked phrase - "4wd will only get you stuck farther away from any help."
Good like with your truck shopping.
Something you might look into. Just met a guy with an F-350. Comparing notes, we started talking trannies. This is his first auto too.
His was purchased simply because of his dear wife. She experienced great difficulties pushing a strong clutch. Don't recall what the spring tension is on the Ford, but I guess it takes a strong left leg. You might want to test this for yourself. Would a "Popeye" like clutch be troublesome for you?
Get the F350 with the A/T and maintain it well and maybe an extended warranty.Single rear wheel trucks don't get stuck as easily.
kip
I think manual transmissions are well suited to diesels, and possibly more comfortable to drive than manuals in gassers. Why? Because diesels don't have a throttle butterfly. The intake tract is always fully open to the atmosphere. What this means, is less compression braking on decelleration. When you lift off the throttle, the manual equipped diesel has less of a tendency to throw your forward in your seat than a gasser, due to less compression braking, i.e. less jerky.
Ford upgraded transmission cooling in newer Superduties, and it serves the majority fine. But reading posts on Ford-Diesel.com you see folks adding supplemental transmission coolers, and even transmission fluid filters for added measures of protection. However, some of these same gear heads hop up the Powerstroke's power and torque beyond what stock transmission can reasonably handle and then complain when it breaks.
What else do I need to ask for when I order it? Oh, and how stable are the rotating gooseneck balls? My husband kind of wants one so that we can use the flat bed when we need it, but I'm worried that somehow if it's not welded, it won't be as stable when I'm hauling horses and something might happen. Thanks in advance for all the advice!
Maybe I should have called it a "disappearing" ball. They rotate down under the bed or something. I presume that's what you have. So you've never had any problems with it?
I'm sorry I can't help you with the tranny temp gauges. Any competent shop should be able to install then for you, or you or your husband could do it fairly easily. They are not that difficult.
As for Transmission temperature, I've got an Autometer #2552 Transmission Temp Gauge - it reads from 100°-250°F. Kit came with gauge, sending unit, fittings, etc. (It was a gift - so I don't know the price off hand.) Their web site is http://www.autometer.com. I've seen them in auto parts stores. I guess your dealer could probably install it before you take delivery of new truck.
I don't know how reliable it is - I've only had it in about a year. As far as accuracy: we checked it against a Mercury thermometer in hot water- it seemed to read within a degree or two of the thermometer
My 350 will usually run about 145 degrees running around town, empty. Towing, up long hills it gets up around 170. I've gotten it up to ~195 trying to back trailer up an incline and having to jockey back and forth alot. It went over 200 once, when I got stuck (stupid me, in my own backyard) and tried to rock it out shifting quickly between R and D about 50 times. I let it cool down for about half an hour (while I cleaned off the mud).
I've been told that transmissions can handle brief periods above 200 degrees, but it degrades the fluid. I think there's about 15 quarts in tranny (including torque converter) so there's a lot of heat to get almost 4 gallons of fluid that warm. If average temp is 200, I'm betting there's some areas that are much hotter. I've been told that if it goes over 225 you should change the fluid ASAP - the friction characteristics of the fluid have been ruined and the tranny will begin to devour itself. The fluid change/tranny flush is much cheaper than a new transmission.
The gauge will tell you if you're pushing the limits and help protect your $35-40K investment.
I have a 02 F250 auto, 4x4, V10 on order.
In 02 Ford got rid of the alternator gauge and replaced it with a tranny temp gauge. At least on mine, might be because of towing package though. I', sure your getting towing package.
As for 4x4, without a doubt get it. As silly as it sounds make sure you get the limited slip. Most trucks on the lot have it but if you order the truck don't forget it.
The should have to call them what the are, a 4X3 or a 4x4!!!
Auto tranny, only way IMHO. The SOF option is what you should consider as well.
My '78 Dodge powerwagon's transfer case had a choice between Hi-lock, lo-lock, neutral, hi, and low. In this case you could choose the low range without locking the differential. That sucker would go anywhere!
Not that I'm lazy...my CJ-5 had a 4-spd box, with granny and low range, a Warn OD unit and manual hubs; lots of levers and knobs; and it was great fun too...but I don't have a clue why Ford would want to have an auto/manual feature on the hubs. Do any of you know the why's and wherefore's of this feature?
The worst part I've found is mounting 4 sets of chains in the mud. If only they could automate THAT task...!
