??Those who tow gooseneck and 5th wheel trailers??
I am planning on purchasing a new truck/trailer combination. I would like to go with a crew cab - short box. The gooseneck trailer tapers down to 6' wide at the nose. To me, it seems like I would have enough room (between the trailer and the back of the cab) for any type of turn; but others have suggested getting a long bed. Those of you with experience on this issue, I would appreciate any advice! Thanks in advance for your help!
Thanks again!
The other side is mpg. Towing, a diesel will only marginally drop mpg where a gasser will seriously drink the fuel. Even empty the diesel will do much better. I was watching the computer on mine this weekend while empty and running 65mph on flat I was getting a steady 24mpg. 70mph dropped it to 22, 75 to 20mpg. When it came up on any type of hill, it would drop about 5mpg to pull the hill, then down the otherside it would gain 5. Overall empty on this particular trip I got 19mpg. This was the first trip in a long time I've been empty for both legs and was able to really get a good empty reading. Overall the computer says I'm averaging 15.5mpg and this truck has a trailer behind it 80% of the time. It's an '01 4X4 Ext. Cab short bed Cummins with automatic and a bit over 60K miles. Based on what I've seen here on gas engines both empty and towing, they aren't even in the same ball-park. Particularly right now when diesel is .10 cheaper per gallon.
Thanks in advance!
As far as waiting on cold mornings, I dunno. I pulled it out this morning and let it idle for maybe 15 minutes but it really didn't warm up. You have to drive them before the engine temps get moving. The power isn't substantial at first, but it's no big deal to start it and drive off. I usually go easy on it for awhile until the temps come up. It would probably be much better if I plugged it in, but normally it might idle for an hour before the truck leaves when we're hauling which is the majority of the time. Usually by the time everything it hooked up and loaded, it's been running quite a long while and is nice and warm. As far as just starting though, it will fire on the first turn regardless of how cold it's been.
I'd do the PSD over the V10 myself. You're already cruising around in a 1-ton regardless of engines so it's not really a performance type vehicle. I know people that tow with V10's and are pleased with them, but they are towing maybe 10% of the time with them. I pulled a buddies boat out of the river this fall because his V10 was having problems. I yanked his 13,000# boat up a very steep ramp and towed it about 40 miles. His comment to me was that I had one helluva truck and he couldn't believe the difference. I've never towed with a V10 so I can't comment beyond that.
Thanks again!
