Stupid Engineer Tricks - What's Yours
My last Plymouth mini van was the best vehicle I ever owned. It was easy to service and the only repairs in 190,000 miles were due to normal wear and tear. My '99 model is another story. Someone please explain why the fuel filter is located on TOP of the gasoline tank - every 30,000 miles it is recommended to unfasten and lower the tank in order to replace the filter!
Let' s hear some more stories!
P.S. - This is just for fun - I'm trying to ward off cabin fever up here in Michigan!
I was looking through the shop manual for some clues as to what might be wrong. The manual mentioned an in-line "check valve" two or three times, but never pinpointed it's location. I hope, however, that it's not located in line with the "intermediate fuel supply pipe". I assume that's the technical term for the gas line that runs from the fuel filter, which is under the cab, to the back of the engine.
The shop says that step one in replacing that line is, "Remove transmission and transfer case". Yeah, that'll take a half hour or so !!!!!
Years ago, the thermostat housing on my '69 Dart GT, 225 Slant Six, cracked after I put a new thermostat in it. I had tightened the bolts too hard, and broke it. Found on in the junkyard, and put it in myself for about $5.00.
This got me thinking...if I ever need a new thermostat in the Intrepid, is it going to cost me about $125 in labor just to get to it?
they started hiding the darned things in the 1970s.
now with the wookie-wookie retractors at floor level and the belts running halfway up the B pillar, out, then over, isn't it amazing that the retractors still get crummy and won't pay out the belt... but you have to remove half of the car's interior plastic and insulation on that side to get a little compressed air to clear the fuzz, and then a little lube on the retractors?
this is way old already. not as bad as oil pans that can't be removed with the engine in the vehicle, but it's still no fun.
Bubble Gum makes a good temporary adhesive sometimes.
Jim
Sentra
Axle shaft R&R
(90 and newer)
Std Trans
One side.................. 1.2
Both........................ 2.2
Auto Trans
Right side................. 1.3
Left or Both............... 2.4
Add to replace 1 boot.. .7
So, to do the left outer boot would be 3.1 hours @ whatever hourly labour rate plus about $30 for the boot. I'd sure like to know how they can justify $600.
I'll pass your times onto my son and tell him to watch out in future.
To replace the battery:
1. Jack up car.
2. Remove front wheel (drivers side I think)
3. Remove splash guard from wheel well.
To replace the alternator:
1. Jack up car.
2. Remove other front wheel.
Naturally he replaced the battery first and the problem turned out to be the alternator.
Mike
Every FWD car I have ever owned has broken a boot at the 8 year 100k time line then you are into the complicated expensive replacement
