2002 GM oil change interval.
Wife just purchased a 2002 Buick Century. While reading through the manual I found that GM recommends changing the oil within two tanks of fuel from when the "change oil" light comes on. No regular or severe service mileage intervals listed at all. I haven't talked to the dealer service dept about this yet but think I will have the oil changed at 3000 and 6000 miles and then change to synthetic and go 5000 between changes. I read somewhere that all 2002 GM vehicles are the same. Any comments?
Art
Art
So, I basically ignore the indicator with synthetic oil. Oil analysis was fine, analysis after 12,000 was much better then with teh OEM oil at 4,350 but primarily due to the engine breaking in and you get the higher particles of metal and silicon in this period.
Anyway, it appears that with the type of driving I do the indicator would come on between 6000-7,500 miles.
1st change at 1000 miles to get all the break in lube out and change the filter. Change oil every 3-4 k until you hit 12k. Then switch to synth. After you switch to synth. you can let the car tell you when to change the oil, it's pretty accurate for synthetic oil, I wouldn't trust it on regular oil.
This is where all the posts for burning up oil come from. You have to let the rings seat to seal the engine up tight. Synthetic is too slippery for the rings to seat properly causing you to burn the oil. WAIT UNTIL YOU GET 12,000 MILES ON THE MOTOR BEFORE SWITCHING TO SYNTHETIC!!!!!!!!!!!!!!
"You can start using Mobil 1 in new vehicles at any time. In fact, Mobil 1 is the factory fill in all Chevrolet Corvettes, Dodge Vipers and Aston Martins. And all Porsche cars manufactured at their Zuffenhausen plant are lubricated with Mobil 1. So are all Mercedes-Benz AMG vehicles. One of the myths that persists about Mobil 1 is that new engines require a break-in period with conventional oil. Current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design these high-performance cars, Mobil 1 can be used in an engine from the day you drive the car off the showroom floor."
cmack4: If you go over to the Synthetic Oil board you will find a couple thousand of arguments for using (or not using) synthetic oil.
It just seems like false economy to maintain a 15,000 to 75,000 dollar purchase by the flashing of an idiot light.Pardon my lack of trust in these things,and I guess if you lease or trade often they're fine, but I would not trust them. Fun gimmick, though! :-}
cmack4 Probably is not much difference changine conventional at 3K and syn at 5K. Neither of those under most conditions is IMHO warranted-just to short. In addition to the cold weather starts-you have the added insurance of synthetics at elevated temperatures and cooling component failures. So in your case its really just an insurance policy (using syn). Now if you would chose to go the full 7.5K or whatever with syn, it starts to make more sense. To me the once a year syn change with a filter in between is the best of all worlds.
See 'ya.
Art
Miles driven means absolutely nothing to the engine;, the load factor, rpms, run time, and amount of fuel burned are more inportant and better indicators of when the oil needs changed. 3000 miles is the most conservative figure, under severe driving conditions, which 90+% do not operate under. However, I do not blame anyone for changine at 3000 on dino or 5000 on syn. it is cheap insurance, but I just feel an overkill when your engine can tell you when ideal is...
I switched to synthetic when I bought my car in 1984 after the first 3,000 miles. No problem. However, after 30,000 miles, I noticed a fairly abrupt improvement in mileage and to a lesser extent smoothness. It took me a while to realize that the car had finally broken in.
When the oil and car manufacturers say that there is no "break-in" required, they mean that the strict limitations on speed, use and driving habits that prevailed in the old days are no longer required. I don't think that they mean that your car won't drive better after a few thousand miles.
I changed the oil every 6,000 miles. My car finally wrecked at 270,000 miles but didn't burn oil, and ran very smoothly.
My suspicion is that 6,000 miles is quite conservative. The people who change the filter and not the oil are probably optimizing the benefit of synthetic oil, although my feeling is that if you have to jack with the filter (which you do, whether or not you use synthetic) you might as well change the oil too.
