Pontiac Grand Prix Problems
I have a 1999 Grand Prix GT that gets very wet on the passenger side front floor when it rains or I go through a car wash. I am told there is a holding tank or something which has a drain hose that empties under the car, and this may be clogged. I can't find it. Any ideas?
Also, possibly related, my blower suddenly stopped working yesterday. I found a blown 30 amp fuse marked HVAC HI that was blown. When I replaced it and got back my blower high speed only. I checked the other fuses marked HVAC, but none are blown. All speeds went out at once. Any thoughts?
Thanks in advance for your help.
Blower, you can have a bad dash switch or a bad relay under the hood.
Best bet to get it figured out right and fast is a trip to the dealer. Is the car still under warranty? If so get it there ASAP.
Let us know what you find out.
This is for Grand Am, but sounds like your problem.
WATERLEAK - FRONT PASSENGER FLOOR (RESEAL PLENUM/COWL #83-11-15
SUBJECT: WATERLEAK - FRONT PASSENGER FLOOR (RESEAL PLENUM/COWL WATER DEFLECTOR)
MODELS: 1997-98 CHEVROLET MALIBU 1997-98 OLDSMOBILE CUTLASS 1999 PONTIAC GRAND AM
BUILT PRIOR TO THE FOLLOWING VIN BREAKPOINTS:
VIN VIN MODEL LOCATION BREAKPOINT DATE ========= ====================== ========== =======
MALIBU OKLAHOMA CITY PLANT 6 W6229091 4/16/98 WILMINGTON PLANT Y WY178047 4/16/98
CUTLASS OKLAHOMA CITY PLANT 6 W6339883 4/16/98
GRAND AM LANSING PLANT M XM726868 4/20/98 LANSING PLANT C XC503367 4/20/98
CONDITION:
SOME CUSTOMERS MAY COMMENT ON THE PASSENGER FRONT FLOOR CARPET BEING WET OR WATER LEAKING FROM THE BOTTOM OF THE INSTRUMENT PANEL AND/OR HVAC MODULE.
CAUSE:
CONDITION MAY BE DUE TO WATER LEAKING INTO THE HVAC MODULE THROUGH THE SEALER BETWEEN THE WATER DEFLECTOR AND THE BOTTOM OF THE PLENUM/COWL.
CORRECTION:
RESEAL THE WATER DEFLECTOR TO THE PLENUM. THE PRODUCTS LISTED IN THIS BULLETIN ARE TAKEN FROM THE TECHNICIANS HANDOUT OF "ADHESIVES, SEALERS AND RELATED ITEMS", JULY 1995 REVISION (ITEM #22009.01-3). FOLLOW THE MANUFACTURERS DIRECTIONS OF EACH PRODUCT FOR APPLICATION AND DRYING TIMES.
PROCEDURE:
1. REMOVE AIR INLET GRILLE, FOLLOWING THE PROCEDURE IN THE SERVICE MANUAL.
2. REMOVE ANY EXCESS FOAM SEALER THAT MAY HAVE OOZED OUT FROM THE PERIMETER OF THE WATER DEFLECTOR AND CLEAN AREA.
3. APPLY ONE OF THE PUMPABLE SEALERS, LISTED LATER IN THIS BULLETIN, TO THE PERIMETER OF THE DEFLECTOR. A FLAT BLADED TOOL OR BRUSH WILL HAVE TO BE USED TO APPLY SEALER TO THE AREA UNDER THE WINDSHIELD.
4. REINSTALL AIR INLET GRILLE, FOLLOWING THE PROCEDURE IN THE SERVICE MANUAL.
5. CHECK CARPET FOR WETNESS OR WICKING OF WATER TO OTHER COMPONENTS AND REPAIR/DRY AS REQUIRED.
PUMPABLE SEAM SEALERS OR EQUIVALENT:
- 3M(R) #08360 OR 61 ULTRA PRO SEAM SEALER - DOMINION SURE SEAL(R) #9005 HIGH TECH SEAM SEALER - KENT(R) #10095, 10130, 10567 HIGH TECH SEAM SEALER
This is for Grand Prix, but if it happens when it rains then I would look elsewhere.
Carpet Wet on Passenger Side of Vehicle (Clean Evaporator Case Drain, If Plugged) #00-01-38-012
Carpet Wet On Passenger Side of Vehicle (Clean Evaporator Case Drain, If Plugged)
1999-2000 Buick Century, Regal
1999-2000 Chevrolet Monte Carlo
2000 Chevrolet Impala
1999-2000 Oldsmobile Intrigue
1999-2000 Pontiac Grand Prix
Condition
Some customers may comment that the carpet on the front passenger side is wet.
Cause
This may be caused by foreign material plugging the evaporator case drain.
Correction
Inspect the evaporator case drain for plugging.
1. Raise the vehicle on a hoist.
2. Remove the rubber elbow from the evaporator case drain tube by pulling the elbow straight off.
3. Insert a 9 mm (11/32 in) drill bit, or any other similar-type instrument, into the evaporator case drain to clean out the material that is blocking the drain. (The distance to the other side of the evaporator case is 130 mm (5 in)).
4. Re-install the evaporator case drain rubber elbow. A small amount of silicone spray on the inside of the rubber tube will allow it to be slipped into place very easily. Be sure that the rubber elbow drain hole is open.
If the evaporator case drain was not plugged, a water leak test will need to be performed using normal water testing procedures.
If no external water leak was found and the vehicle returns for the same type concern, the evaporator case will have to be removed from the vehicle and the foreign material removed from the evaporator case.
Parts Information
No parts are required to perform this procedure.
If the rubber elbow is missing from the vehicle, install a new elbow. The addition of this rubber elbow will result in road and wind noise reduction at highway speeds.
Thanks in advance for your help....
