Toyota Corolla Maintenance and Repair
1272830323376
    carglowcarglow Member Posts: 91
    A small percentage of Corollas are assembled in Japan. Their VIN starts with "J".
    viking3viking3 Member Posts: 1
    PROBLEM #1:
    We purchased our first 2004 Corolla LE in November 2003. A loud clicking noise is coming from the back of the car. It sounded like it was coming from the trunk. So, as my wife drove around, I put down the rear seat and stuck my head in the trunk. Noises seemed to be coming from below the rear panel where the rear speakers are located. Is this common? Will the noises go away as the parts "settle" or does somthing need to be tightened? Noises occur only when the car is moving ... don't have to be going over bumps, either.
    PROBLEM #2:
    We just bought a second 2004 Corolla LE last week. This one is not making the clicking sounds in the back, BUT it has its own distinct "special" noise. This car is making a high-pitched, whistling sound from the front. The noise occurs when we are stopped at a light, in drive (car is automatic), and pushing on the brake. I opened the hood to try and locate the exact location of the sound. It seemed like it could have been coming from the left side of the engine (or the passenger side) near the belts (or black leather bands). Again, is this just a matter of the car needing to be driven for a while ... or a bigger problem that should be checked?
    Suggestions are welcome on either (or both) problems. Thanks for your assistance.
    betongbetong Member Posts: 2
    ARE YOU AWARE ABOUT THE WINDOWS OF THIS CAR WHEN YOU PUT IT HALF WAY OR IN THE MIDDLE, AND HOLD IT WITH BOTH HANDS, AND MOVED IT TO THE LEFT AND RIGHT THERE IS A VERY LOOSE CLEARANCE ON EACH SIDE. QUESTION IS THIS NORMAL...???? THANKS
    corollagoldcorollagold Member Posts: 8
    ROTTEN EGGS ARE ACKNOWLEDGED!! See emails at bottom of this post.
    WHISTLING SOUND - Try this.
    While in Park & after having driven a while to warm up ALL components, open the driver's door to half-way stop and listen.
    Put foot on brake, or firmly engage parking brake.
    Put tranny in R and listen. No change? O.K.
    Now put tranny in D and listen. Whistle starts? Mine does. VERY LIGHTLY press gas pedal to increase RPM slightly (900-1000 vs. 800 @ idle). Whistle stops? Mine does.
    I suspect that the tranny is slipping in 1st gear at idle (clutches or bands not FULLY engaged) until RPM picks up. Added "feature": the 1st-to-2nd gear shift is very sloppy. It sounds like 1st gear disengages, the engine 'waffles' for a moment (rpm is being limited by the computer) and then finally 2nd gear engages. I can force a faster engage if I step on the gas just as soon as I hear 1st gear disengage. Note that my 2-3 and 3-4 gear shifts are quick and firm, as they should be. (FWIW, a firm or harsher shift is easier on an AT than a sloppy, "can't feel the shift at all" shift. Reason is, those sloppy shifts indicate that the trans is slipping into gear, in much the same manner as a person with a MT revving the engine then S-L-O-W-L-Y engaging the clutch. In both cases, the clutch(es) is being prematurely worn due to slippage.)
    Sniff the fluid on your AT tranny's dipstick. It should smell sweet. If it has a burnt smell or hint of it, those are your wearing-out clutch disks creating that burnt odor. If you're not sure of what you're smelling, open a can of tranny fluid and compare scents.
    SUNROOF. We were driving down the road one night when suddenly FLAP FLAP FLAP... The rear support brace had broken away from the glass of the sunroof, so the glass was flapping like a flag in the wind, pivoting on the front attach point. Could your unit be on it's way to the same fate?
    LOOSE WINDOWS. Ask your dealer's salesperson to open several new cars on the lot and compare the slop in those windows to yours. Try to find cars that are assembled in different plants (sticker in the driver's door area) for a full comparison. Mine was assembled in Canada, and has only a little slop.
    OK - here's a copy of several recent emails on the ROTTEN EGG / SULPHUR / H2S that I received. (FWIW, you can go to http://www.google.com and enter the argument rotten egg sulphur smell OR odor or the argument H2S to learn more about what's happening. A Quick explanation can be found about mid-page at http://www.sjmautotechnik.com/TROUBLE_SHOOTING/exhaust.html )
     Date: 2004/06/09 Wed PM 12:31:46 EDT
     Subject: Toyota Sulfur Odor - New TSB & Repair
     Major development on your Toyota Sulfur odor complaint to the Center for Auto Safety website.
     Toyota has just issued a series of TSBs reversing its position that there is nothing they will do about it to fixing it for free. We have posted the bulletins on our website at:
     http://www.autosafety.org/article.php?scid=119&did=934
     Clarence Ditlow
     Executive Director
    Clarence -
     thank you, Thank You, THANK YOU!!!!!
     Every time I had to visit our dealer this problem was my first complaint. Each time I was handed a sheet telling me that Toyota doesn't consider this a problem, and would therefore do nothing to fix it. Naturally, the dealer wasn't willing to exert any effort to counter the home office.
     Maybe enough others gave their dealers the same complaint and Toyota finally said, "Enough!" Maybe it was through your organization that Toyota finally saw the light, and smelled the stink. Whatever the case, thanks for being there.
    My spouse and I love you.
    You & your spouse are welcome. We got your complaint and others. We contacted the US Environmental Protection Agency (EPA) about the complaints.. EPA put a little pressure on Toyota & you should get your fix which happens to be very expensive for Toyota. Undoubtedly that is why Toyota tried to say "What problem?"
    Tell the world about the Center for Auto Safety. We are good but small. And we can't get our job done without the support and complaints from consumers like you. You can become a CAS member for just $20 at http://www.autosafety.org/becomeamember.php.
    Please let me know if you have any problems getting your 2003 Corolla fixed.
    Clarence
    May I suggest to you, the reader, two things.
    1. Write Clarence at <complaints@autosafety.org> and thank him (their group) for putting the pressure on Toyota. Also, pop for the $20 - it's a small price to pay for the fix you'll get.
    2. Complain to the dealer's service dept. that you have a rotten egg odor when your windows are open, or your ventilation system's in FRESH AIR mode, and you come to a stop (light or sign) and you get this horrible stink (sometimes), even when no other cars are around. Tell the service dept. that you're using 87 octane, just like the owner's manual says you can (the '04 manual reads the same, and the '04 Toyotas are included in this non-pub'd fix), and the only thing you can conclude is that it's YOUR CAR that's making the stink. Also tell the service writer that you've tried different brands of gas, but almost always get the same results. (FYI, The problem USUALLY happens after the engine warms up. It' being caused by the engine going too rich during deceleration, such as when you approach a stop sign, light, etc. The rich condition is more than one of the catalytic converters - your car has two - can handle, and thus the stench begins.) EVEN IF YOU NEVER NOTICED THIS PROBLEM, have the fix applied. The re-programming of the computer may rectify the/a potential rich-running condition, which - if it's happening - could increase your overall MPG.
    Hope this helps.
    Another Corolla owner
    ROTTEN EGGS. Found a seemingly decent explanation of what's happening in the catalytic converter to cause the Rotten Egg odor. Try http://www.swri.edu/10light/catalyst.htm which was updated very recently.
    That explanation makes me wonder if MPG will be adversely affected (lower MPG) after the computer is reprogrammed to (perhaps) not run the engine so lean during straight and level driving. I have noticed that the egg odor isn't as strong (after 13,000+ miles) as it was when we first acquired the vehicle, but then again, the reduced odor may be due to our using a higher octane / better refined fuel as "recommended" on the Toyota dealer's "It's not Toyota's problem so we won't work on it" handout. Oh, well, we'll find out after tomorrow.
    WHISTLING SOUND. I've noticed that in very warm weather, the whistling happens for a while after the AT has warmed up some, then disappears after the tranny is REALLY warmed up. During cool weather, when the trans warmed up, the sound was always present during idle after driving a few miles. In both situations, the 1-2 shift is always VERY sloppy, from cold engine to hot.
    The reason you want to partially open the driver's door to listen is that the sound seems to bounce off the pavement, then off the door panel, and you can hear it better this way.
    SUNROOF. With the sunroof in its closed position, open the sliding inner panel and try pushing up on the REAR of the glass while someone watches from the outside. If you can move the glass up and then down (from the outside) any measurable amount, then I'd guess the bond between the rear steel cross-bar and the sunroof glass may be failing (my situation), so you may want to see your dealer for a warranty replacement.
    CG
    hampsterdamhampsterdam Member Posts: 18
    My wife's 5 month-old Corolla LE doesn't seem to cool very well in the Houston heat and humidity. It's mostly driven infrequently or on short hops (it has less than 1000 miles). My 2000 Audi with crapped out AC does a far better job than the Corolla. We realize that Houston is like the ultimate test of automobile AC. But is the Corolla's problem that it is inherently weak? Or does it need some juice in the AC? We'll likely get some window tint film to cut down the heat intake; the good metalized film works great on the Audi. We'd appreciate comments from other owners in regions of high AC demand. Thanks.
    cocottecocotte Member Posts: 6
    anyone else noticing slight vibrations or hesitance when turning w/ the 2004 LE? i sometimes feel it when doing sharper turns.
    mcdawggmcdawgg Member Posts: 1,722
    Take out another Corolla on a test drive to compare? When it gets really hot here (90+ degrees, 70% humidity), it takes the car 10 minutes or more to get cooled down. Note: Put it on recirculate after five minutes and turn the fan speed to three or four. Also, point the vents at your face. I find the Corolla is like any other small economy car - marginal AC.
    chu5chu5 Member Posts: 3
    I have a 99 corolla with 88,000 miles on it. Start last week, the Check Engine Light comes up. Took to dealer, they found one cylinder pressure is lower (110) than normal (125). What they want to do is to tear down the engine and figure out what causes it. The cost will be $450 for tearing down, plus whatever cost for fixing the problem. What choice do I have? Your suggestions please! Thank you.
    carbuff88carbuff88 Member Posts: 1
    get recommendations from friends and coworkers for an independent mechanic, take it there, and get a 2nd opinion.
    lpc68lpc68 Member Posts: 45
    i'm experiencing vibration from my front wheels and steering wheel at about 70 to 80 mph. i got a 4 wheel alignment and got new rotors and pads (when i braked at high speeds the vibration was very strong). the braking vibration has been resolved with the rotor change but i am still getting vibration at 70 to 80 mph when driving normally. the vibration seems to get better when the wheels are straight and seems to worsen when turning slightly. the previous owner replaced the steering rod and i replaced the drivers side cv axle.
    thanks in advance for any advice as to what it may be.
    racrac Member Posts: 1
    After 30K service I found that coolant in reservoir drops on short time and below "LOW" line now. I didn't find any leak in the system, but I found that dealer didn't put Genuine Toyota Antifreeze Coolant, because it is green now. I didn't find any information about coolant in the service report. Any advices ?
    vintagecarvintagecar Member Posts: 2
    Hi-
    I have a 96 toyota corolla, automatic. It currently has 106,000 miles on it and has had virtually no problems. I recently noticed that if I go over 68 miles per hour, the engine is very loud. I had it serviced and had everything flushed/filled but this has not solved the problem. Is this loudness a sign of old age or something else?
    jansjans Member Posts: 1
    For the last few months my Corolla is harder to start. It often takes 2-4 tries to start the engine. I had it in for service twice and of course they tell me there is nothing wrong and it started on the first try. Others have driven it and have the same problem so it isn't me. I called 1-800-TOYOTA and they told me that "maybe try to put the foot on the brake to start it" although they were perplexed that it didn't start without the use of the brake. Tried that with some success but it doesn't seem right? Is there a right way to start this car other than turning the key? Anyone else have this experience?
    grandtotalgrandtotal Member Posts: 1,207
    Try this: turn the key to the on position (all warning lights lit) and wait for three seconds, then turn the key to the start position as usual.
    thickcommishthickcommish Member Posts: 15
    I have a toyota corolla with 80k and have not had any problems thus far, knock on wood. We got almost 70k miles on the factory set of tires and obout 60k on the front brakes, 70k on the rear. Oil changes every 5k and a tranny flush is the only maintenance I have done and it runs great. The weather-stripping around the driver window is a little defunked but is only cosmetic and you cant really tell unless you look closely. You can hear a bit of wind at high speeds. My wife drove the car for her sales job and now has a company car. Anyone got any idea what I can get out of this thing. For somereason I dont believe kbb and nada's figures. It has the moonroof and automatic tranny. Thanks!
    isellhondasisellhondas Member Posts: 20,342
    Go over to the Smart Shoppers forum and scroll down to "Real World Values"
    People there who will help you.
    Those high miles are a killer. They will affect the value even more than the books say they will.
    Just purchased a new impluse red Corolla. Upon washing it I noticed that the bumpers have a different "hue" than the rest of the car.
    Anyone else experience this?
    danielj6danielj6 Member Posts: 285
    You'll be receiving a very detailed Quality Control Survey from Toyota. You can indicate the color difference in detail there.
    I received 2 QCS's since I got my Corolla in the beginning of June. The first one was general and the second asks for details. My suspicious nature tells me that something is up with Toyota quality, so I've decided to hold on to the second survey to see what develops with my car.
    On the other hand, in the first survey I wasn't all too generous in assessing the purchase experience. Perhaps Toyota sent me this second survey as result of the answers I put in the first. I don't know.
    In your case, if I didn't receive the second survey, I'd call and write Toyota directly. Let them correct the problem.
    ejgejg Member Posts: 2
    I'm in NJ and we get some hot days and yes the 2005 Corolla's Air Conditioning is weak on my car too. I was told by the Toyota dealer to basically aways keep the re-circulate button ON for the air conditioning to cool. If you dont have it on re-circulate it dont really get too cool.. I asked the service dept if there maybe a problem with it or maybe it needs some coolent added and if I should have someone look at and basically they told me "No", thats the way it is.
    needsahemineedsahemi Member Posts: 18
    I have a 1999 Corolla which is the worst car I have ever owned. Let me start by saying this car has 30 000 miles on it. After just replacing the radiator at a cost of 700 dollars. I was informed today that the squeaking coming from the front of my car is the tie rod ends need to be replaced. Toyota has a TSB (technical service bulletin) for this problem. Even though they acknowledge they have this problem, they will not pay to fix it. I must fork over the 600 or more bucks to fix this. Well I see I have been duped into this piece of garbage, never again will I buy a Toyota.
    Wow, this is very unusual! I have not ever heard of a Corolla radiator going bad, even after 150k miles (with coolant flushed every 3 years, only Toyota coolant.) The worn tie rod ends are surprising, too. Is it just a squeak, or is it really worn out? Maybe the car hit a BIG pothole?? My '99 has 60,000+ miles, zero problems, just like my other Corollas. Sorry to hear you are having problems - the Corolla is well known to be the most reliable in it's class, and rated by several sources to be extremely reliable too. I suppose you got one of the few bad ones.
    modestmousemodestmouse Member Posts: 53
    I'll cross post this:
    I was wondering about the quality of the new 05 Corolla's manual transmission. Is the gear box tight and responsive or soft and mushy. I've already taken a test drive and I like the car but all they had was AT. I guess MT's are just not popular in this class.
    I've also noticed that no one seems to be getting to the EPA published figures of 40mpg hwy and 32city. One of the chief reasons I am considering this car is because of fuel economy. I know most (all) cars fall short of the numbers, and 33-37mpg is still better than I get in my current car.
    And does anyone know of the 05 catalytic converter suffers the same defect as the 04 with a rotten egg smell. Thats all I need 17,000 dollars gone and rotten eggs.
    I'm ordering my car from Toyota should I check with my dealer what plant it is being manufactured at?
    Is there anyway to buy a car in the corolla's class w/o being disapointed?
    MM
    dave594dave594 Member Posts: 218
    I have an '02 with the 5 speed. It's not exactly tight and responsive as say BMW or Honda, but it does the job. I haven't missed a gear yet, but the shifter requires a longer throw comparing to sports cars. I get 36 MPG consistently on a mixed highway and city traffic commute. If I were to drive long distance highway I will get over 40 MPG.
    lizservolizservo Member Posts: 5
    Has anyone gone and had the work done that is suggested in the TSB to eliminate the sulfur smell? I bought a 2004 Corolla LE in mid-April and I haven't noticed any odd smells, but thought I should have the changes made, just incase. Thoughts?
    Lizzie :)
    riccd2001riccd2001 Member Posts: 12
    According to Toyota the applicable Corolla VIN cut-off #s for "Excessive Sulphur Dioxide Odour" are:
    for Corolla: 2T1BR3#E#4C312392
    for Corolla S and Matrix: 2T1#R3#E#4C836439.
    shopper777shopper777 Member Posts: 3
    I'm considering buying an 05 Corolla and am very interested in the AC system. Anyone had any bad experience with it not cooling well? And also is the gas mileage accurate? Fuel economy is also one of my reasons for considering it.
    I got my Corolla in June, it's an 04 LE, and well equipped. No problems with the A/C so far. The other day I felt that it wasn't cooling all that well after about 15-20 minutes of driving. So I remember something I read in one of these threads about putting it on circulating. It started to cool very quickly, so much so that I have to lower to medium.
    It's really frugal in the gas department. I'm averaging 25 mpg, and being that the engine and components are in the break-in period I'm satisfied with the gas mileage.
    raf1raf1 Member Posts: 3
    I have 94' corolla run 113K. Everything was fine till a week back. My car does not accelerate fast anymore. It looks like it has lost more than 50% of its power. I had changed my timing belt and water pump in Nov'03, but did not use the car much as i was travelling. After the timing belt change, i might have used the car for 2000 miles max. My mechanic is saying it needs a tuning and wants $250/-, but i seriously doubt him now.
    Curious.
    It may need a tune up, but on an older 4cyl you should be able to do most of that yourself. I would say a tune up would include, timing, plugs, PCV valve, EGR valve (if its got one), new oxygen sensor (if its possible to change it), and an oil change with some oil made specifically for older engines. After the oil change I would put some of that "Older Engine Restore" in there and see if that helps. Also if its fuel injected then I would also use some Fuel Injector treatment or something similar that you put in your gas tank.
    I recently put some engine restore in my POS Oldsmobile and had some success it has regained some of its original acceleration. When was the last time you did this or had it done?
    MM
    eleaheleah Member Posts: 1
    It's end of July now and I went through a No Touch Car Wash - When I pulled away water literally began pouring out of the control panel/light fixture on the roof of my car. I have a moon-roof but it was fully closed and water didn't come from that item. This has me somewhat freaked out as a serious problem for (my not yet paid for baby). I called my dealership and the guy there said it was a common problem - I checked and didn't see anything mentioning water leaking inside the car on this site. I have an apt tomorrow morning with the dealership but can anyone give me any advice on this subject? Is it a common a problem? If it is how do I stop it? How do I make sure they fix it properly - visions of the wiring for the light where it is leaking from shorting out and causing lasting electrical issues are making me nervous. I live in Seattle WA if it leaked from a stupid car wash what's going to happen when it starts raining here again?
    I just came to know that my engine oil has turned white, which happens only when the oil is mixed with water. I think the engine gasket is gone. The most probable reason for what happened to my car may be that somehow either the fuel injectors or some sensor has gone bad. Due to this, my engine was missing and now the gasket is gone. Do you have any other explanation.
    rolla03rolla03 Member Posts: 3
    I have 2003 Corolla S and brought it in the dealer for 30,000 mile service ($299.98). the dealer advised me that I need to have brake service wherein brake pads and rotors will be replaced for additional $298.88. My question is, is it normal to replace the rotor every time you replace the brake pads?
    How about throttle cleaning service? I had this service at 15,000 miles and again the dealer was suggesting to have it done but I refused.
    When is the cabin filter need to be replaced?
    I live in Daly City, anybody who lives around who can suggest a better Toyota dealer?
    Curious...pls. advise...thanks
    stinkinrollastinkinrolla Member Posts: 5
    HI,
    Would you be able to tell me the year of your corolla, and why you needed a new cat converter? I have a 2004 corolla, that gets lousy gas mileage, has vibrations, almost stalled once and stinks. I think I might need a new cat. CAn you give me some info on how you got a new cat converter? THanks for your help
    Thanks, many, many thanks! I really needed that TSB on excessive sulfur odor. I have a 2004 corolla s. I have had this problem since the the 2nd week of owning my car. I have taken it to my dealership numerous time, and everytime they told me that it was normal, and that there's nothing they could do about it. I was thinking I must be at fault and going crazy. This is my first new car I have only owned. I will be taking my car and the tsb in to my dealership and I'm sure they will do something about it. Many thanks again for your help!
    Also I have a question, are the canadian built corollas included? Any thing else that I need to know? Anything that I could do for you? Please let me know! I will be more than happy to help!
    Thanks again
    Andrew Cramer
    2004 Corolla Sport
    First thing - don't do the $300 30,000 mile service, or the 15, or 45, or 60, or any of these. At 30, Just ask for trans fluid change (if automatic), coolant change, change air filter, and clean the throttle body every 30,000 miles. You'll save big $$, the rest is just the dealer padding his pockets. Just go by the owner's manual - all this info is listed in the maintenance manual. Just ask for what the manual tells you to do. Replace the cabin air filter - real easy to do, takes <5 minutes.
    Second - it is really unusual for a Corolla to require brake pads at this low mileage, but I suppose it is possible depending on driving conditions. But the Corolla's brakes generally last a long, long time. It is even more unusual to have to replace rotors. Usually just turning them is all that's necessary.
    You need to get away from this "stealer" and try somewhere else. Also, keep reading and learning about your car - it'll save you big $$.
    Finally, you should post questions like this in the Corolla section, not it's own topic.
    # 1532 and 1533 were moved here, hence the reference to another topic on another board.
    thank you
    Mrshiftright
    Host Elsewhere
    jrct9454jrct9454 Member Posts: 2,363
    My guess is that the drains in the sunroof are plugged. Get to a dealer, describe the problem, and let them have a look at it. These cars don't leak - the presence of the sunroof is the clue [I hate these things for a lot of reasons - this is one of them]. If the water is not going where it belongs [down the drains], it will go wherever it wants in the roof area - like the overhead light...
    Anyone else notice that their bumpers were a different shade (hue) than the body of their Corolla?
    erins3204erins3204 Member Posts: 2
    I have a very strange problem with my brand new Corolla S. It's an '05, 3 weeks old and every time I fill up the gas tank, the car won't start! I've taken it to the dealership and they say everything is fine. My check engine light also comes and goes. Of course when I bring the car in when the light is on, it's off by the time they get to it! So they say everything is fine. Obviously it isn't. Has anyone heard of a problem like this or have any suggestions as to what might be wrong? They've told me that when the pump stops, to take out the pump, don't make the dollar amount even because it can sense the extra vapors. Tried that, the car wouldn't start!Please help me!!
    Did you tighten the gas cap after each fillup, letting it click a few times before stopping?
    I've turned the gas cap real tight, I've let the car wait a few minutes. I've done everything and it still does it. I'm STILL waiting for the toyota service dept. to figure it out. No one has ever heard of this?
    aj2aj2 Member Posts: 12
    hi-just curious others opinions on the standard am/fm radio system in the 2005 CE Corolla? I'm disappointed so far with it-I had a much less expensive car before this one-but the quality of the radio at least was much better. :) It seems it fades in and out all the time-is it the antenna system they have the newer Corollas? Anyone else experiencing this-or perhaps is just mine?
    Hi, i have a 94 Corolla run 118K which is missing for a while. It has lost its power to accelerate from zero. It accelerates slowly and once it reaches 45mph, it runs fine reaching upto 70mph on the highway. The problem is it does not have the instant power to accelerate from standing. I have replaced the spark plug, wires and rotor. Also replaced the fuel filter and used some fuel injector cleaner. Checked the pcv valve, it rattles, so i think its fine. There is no check engine sign. I dont know what else could be the problem. Is it possible that the distributor or the computer might not be working properly. How to check them. Has anyone else had this problem before. I would appreciate any help in this matter.
    tjdepere2004tjdepere2004 Member Posts: 40
    have '99 corolla. Headliner coming loose at front windshield. Suggestions of how to handle this problem appreciated. Thanks
    Hey, I'm no car expert, but the above messages caught my eye.
    2005 Corolla Air Conditioning by ejg - The color of your car can make a BIG difference in a/c performance. Most mfgrs don't vary the tonnage (cooling capacity) based on color, but the amount of interior 'heat soak' increases dramatically as the car color shifts from white to black. Too, parking so the sun beats down on the dashboard pumps heat into the interior a/c components (ducts, evaporator, etc.) forcing your unit to work for a while cooling those components down before cooling YOU down. Running in RECIRC mode makes this happen faster because you're not trying to cool down the outside air ONE TIME as it passes through the car and out the exhaust vents buried in the rear fender area (peel the trunk liner back to see these). Keep in mind that when defogging your windshield, you DO WANT TO take in fresh air to rapidly push the excess interior humidity out those exhaust vents. Know also that in partial or total defrost mode, your a/c unit is turned on (even if the dash light doesn't indicate this) to dehumidify the air before blowing it at the windshield.
    '05 cat converter by modestmouse - the changes Toyota is making under the TSB are undoubtedly integrated into the assembly line, so you should not be affected, but re-read my post on page 76 to determine how to test for the problem.
    lizservo & stinkinrolla - Not long ago I had the (approx. 1200 Toyota-paid dollars) job done. The stink seemed to abate for a while, but recently the CHECK ENGINE light turned on and the smell has returned. I'd guess that the computer reprogramming now looks for the problem to happen. I'll be taking it back to the dealer.
     Andrew, my car was built in Canada, per the door jamb sticker (and, you're welcome.) It ticks me off that Toyota provides a fix but won't tell anyone who has complained to a dealer in the past about the fix, so I catch every 2002/3/4 Toyota I can (at traffic lights) and inform them of the problem/'hidden' fix.
     Lizservo, I'd suggest that if your car falls in the range spec'd by the TSB, you have the fix installed. Read my post (page 76) to see how to describe the problem to your dealer. If you don't describe it correctly, they (at least, my dealer) won't consider putting the fix on. You MAY have to go back and complain several times before the dealer agrees to fix it.
    Corolla won't start after filling gas tank by erins3204 - Suggestion: next time you need a fill, go to the dealer and take a service writer or tech with you to the gas station. (Keep a spare gallon in your trunk, just in case you run too low.) Believe me, they'll believe you if they have to sit with you waiting for your car to start. If they won't ride with you, at least arrange to meet them at a (same brand) gas station when you call to say you need a refuel. If they won't cooperate & you want to 'force' the issue, park your car on their lot in plain view of shoppers. Put a big sunshield-looking signboard INSIDE your windshield stating their non-service. "My car won't start and this dealer won't fix it!!" Set the parking brake & lock your car and go sit on their customer's toilet with a crossword, your favorite magazine, whatever. Pick a busy day - Saturday?? Negotiate through the locked restroom door.
    My car has less than 15,000 miles on it. It came with Firestone tires claiming a Wear Rating of 440, per the sidewall info. I keep the tires inflated to 35-36 lb., cold, to 'force' the center of the tire's tread to buldge outward (to increase gas mileage via less rolling resistance, and to push the wear toward the center of the tread). Neither my spouse nor I drive rough, and we both avert potholes, sewer covers et al (to avoid upsetting the steering geometry settings) as best possible. Despite all this, the front tire tread EDGES are already VERY close to the wearbar depth of 2/32" above tread depth. (The outside edge shows more wear than the inside edge.)
    I can't believe that a Wear Rating of 100 equals 4,000 miles (and by extrapolation, a Wear Rating of 440 equals 17,600 miles). Is anyone else seeing heavy wear on their front tires?
    If YES, or even if NO, what BRAND of tires are on your Corolla, and what is the Wear Rating embossed on the tire's sidewall? Sure would appreciate some feedback, especially from one or two unbiased tire experts.
    scyscy Member Posts: 1
    My car has approx 30,500 miles on it. I took it to the dealership for maintenance and I was told that 2 of the rear wheels were bent. I inspected the wheels and they seem to look ok to me so I refused to change them. I'm also careful to avoid potholes most of the time. I'm worried that this is a rip off so I need advice on whether should I get the wheels changed?
    2 of the rear wheels? I was only aware that there were four on a car; 2 front and 2 rear. *giggle, just kidding*
    I would take it to a third party and have them check it out. They really have nothing to gain and you have nothing to loose. Get a second opinion. And really my question is, how do wheels get bent, and what does that mean anyway? Why to be vague dealer man. If they were "bent" how'd they get bent? Maybe you should tell your dealer to "get bent" HAHA.
    MM
    friendly_jacekfriendly_jacek Member Posts: 96
    Hi corollagold,
    Question Re: sulfur smell.
    Have you noticed any MPG changes with your TSB fix.
    I understand that Toyota reprograms ECU to avoid H2S production. The part I don't understand is if they go from lean to rich (to avoid SO3 accomulation in the cat) or from rich to lean (to avoid H2S release from the cat).
    My car has poor MPG as it is now (27/30 city/hwy), I would hate to see it go down (I learned to live with brands lower in sulfur in my area).
