I want to bring the car to the dealer, please advise if they still can computer out the error code in case the CEL does not come out by the time they have the car?
Need advice for the above ASAP, thanks a lot.
Lime
did the dealership provide you with the window sticker from the manufacturer? it should be on there.
for the 2007's the specs are here:
http://www.toyota.com/corolla/specs.html
so if it is the CE model, probably not.
for the 2006, maybe you needed to get the LE to get VSC.
sorry, i don't know.
there also appears to be an ownership link:
http://www.toyotaownersonline.com/?s_van=GM_TN_OWNERSERVICES
maybe if you register, you can determine this by your VIN number.
Thanks for the infos, I am going to bring the car to the dealer, I need to know if the error code will be stored as the CEL (check engine light) is on and off all the time, which means it might appear in the morning and disappear in the afternoon, or appear today and disappear tomorrow, I just afraid the dealer refuses to inspect the car in case the CEL is off by that time. Please give me an expert advice that if the dealer still can find the error code if the CEL is off? Thanks
I would like to replace the spark plugs for my corolla but the two plastic screws on the rear of the engine cover give me problem. I don't know how to unscrew them. Should I pull then straight up, turn counterclock wise??
Any one can share his experience? Thanks. :confuse:
MIDAS tech said $600 for replacing the rear struts. I am not sure if it costs so much. How did you fix your problem?
Thanks!!!
Some Toyotas have transmission issues etc..
There is a new, fully redesigned Corolla only months away. It will probably look better and drive better, but will cost more and may have first year or first few year issues.
Since I can get ABS, VSC and side air bags optionally on a 2007 Corolla and install an aftermaket AUX input in the stereo, I can't think of anything of substance worth waiting for on a 2008. More modern styling and added driving/riding refinement will be nice, but not for a big price premium.
What are the common problems with the current Corolla sedans?
Was that an aftermarket cold air intake or short ram intake? If so, who made it? I haven't seen any aftermarket cold air or short ram air intake systems beyond the 2004 Corolla (last year of cable throttle control).
could be underproofing applied to the underside of the car burning off because it is in contact with part of the exhaust system, or a loose part from the fire wall in contact with the exhaust.
could be oil or coolant burning off a hot part.
could be a hose in contact with a part of the exhaust.
it could be many things and the first sign of something bad.
seems like your dealer can't do the diagnosis properly. if the CAT were bad, you'd be smelling a sulfer type smell, not a plastic type smell in my opinion.
I know many people in this field have 05 Corolla, please let me know when is the 1st time to change or add the fluid in the transmission? Is it depend on the weather of the city you live?
If anyone knows anything about the above, please give me some advice. Thanks....
Most Japanese compact sedans need transmission fluid replacement every 30,000 miles and new spark plugs every 30,000 miles. Oil change every 3750 miles, tire rotation/ balancing every 7500 miles, air filter change every 15000 miles. Other services such as coolant system flush, wheel alignment, etc. - only if needed. I don't think this has anything to do with where you live (I don't know whether southern states add anti-freeze like people in snowbelts do... besides these little quirks, the schedule should be same).
On it's own, a steering wheel adjustable for reach as well as tilt, would be enough for me to change.
Bought an 06 on June 1 with 8400 miles on it. Turns out it was a "rental car" from another dealer that runs a rental company (probably for body work, etc.).
Car was fine, minor issues - the back cloth seat cover was unhooked in back on the passenger seat, and the armrest compartment cover was a bit loose. Did get the extended 6/100k warranty on it.
Heard a dragging about a week ago under the car, turned out it was that plastic covering that goes around in teh inside of the wheelwell. It came off in front, dragged, rubbed away, etc.
Called my local TOyota Dealer (Wilde in MIlwaukee) last week. Told them abotu it, said to bring it in, they'll see if it's under warranty. THey said they had to transfer me to parts to see if the part was in (?? why can't you do it? You're right there!). Parts said it was at an off-site location, they could have in. I had to schedule an appt. have the service advisor make sure to have them order the part. A week ago remind you - so they transferred me back to service, same fella I talked to originally, he scheduled me for a week from that day (yesterday), and that they'd order the part.
Got there yesterday, they took the car back. Came back told me it wasn't under warranty because I damaged the vehicle. OK, well it's a he said/she said situation. I did walk through the car with the gentleman working the deal with me and we saw a bit of grinding on the underside of the ground mouldings (it's an S model), but I didn't get under there to see if there were problems with the underside. The topper? The used car guy was a J-A-- to me about it, said it wasn't his problem, and the service advisor (same guy I talked to last week) said the part hadn't been ordered.
I've called Toyota to file a complaint, they opened one up for me, and I've got an appt. with another local dealer tomorrow to fix the issue. Shoudl I worry about other issues I may find with the car? I did a carfax check and found nothing, no accident reports with that VIN either.
1) I am in New York city, my 05 Toyota corolla is still under warranty, please advise if I have to go to the original car dealer to fix the car or I may go to other Toyota dealer?
2) The original dealer would not not charge me because the car is still under warranty, would the other dealer do the same thing?
Thanks a lot....
If you choose to take your car to the same dealer who has been performing scheduled maintenance (if you had), they know you and your car. A Toyota service department that you never visited before might want to see whether the problem was caused by "owner negligence" and if they decide it was they will charge you.
I also live in NYC and my Corolla was never serviced by the dealer. When something went wrong I had no choice but to bring it to a dealer. It was a hassle, but I got it repaired at no cost.
From what you say is a good idea to go to another dealer. What was/is the problem with your Corolla?
I wish I could have the website and email address of Toyota Japan Headquarter, if anyone knows, please let me know, greatly appreciated !!!
When I turn the key, no noise is made, the car is just dead until the third or fourth quick successive try. I just replaced the battery so I know that is not the problem. Does anyone know what might be wrong with the car?
It seems to get worse when it is raining outside. I am guessing I have a short of some sort in the electrical system, but I am not specifically sure.
Any ideas or thoughts on this problem?
