As I say, I am going to pay if necessary to have it removed.
1) Take a small flat tool - like a screw driver, but thinner if possible.
2) Carefully pry the sensor up. There are two small retainer clip.
3) Disconnect the connector.
This would remove the twilight feature.
DRL would work the same.
You would need to turn on/off the lights manually.
Disclaimer - I read this somewhere, But have not done it yet.
About 1500 miles so far.
I do not believe I smelled this.
I'm in the NY/NJ area.
Use regular gas.
Sounds like those cars that smells, smell real bad. Otherwise, there is no smell?
Something smells rotten here, and it's not normal.
forum
exterior
Twilight Sentinals...
hint - Show active threads from last "ALL"
note -
So if you damage it, and want a new one, the part is listed at $129.
Standard Disclaimer - You are young at heart, but still an adult. All damages are done by YOU, and you cannot blame anyone.
Good Luck - let us know how'd it go.
Too cold to do this now.
Some have mentioned that all new vehicles are now having this smell, but the 03 Honda Civic I ended buying does not smell, and neither does the 03 Explorer I bought a few months ago (which uses twice as much sulfur gas).
I'm getting a bit worried about the long-term reliability of my Corolla..
Anyone have any similar experiences/thoughts?
I have not had the sulphur smell though, but boy is it buzzy, sluggish, and handles poorly. You can't get a comfortable driving position and not good in the snow with 4 Snows on it. I never had to put snows on my 93.
I am very disappointed in Toyota.
The noise came from speedometer, it seemed the cable turning noise, which might require to lubricate.
if anyone has a fixed for it, please post.
Yesterday it took 1 hr to remove the assembly to access to the speedo cable. I used "Liquid wrench with Teflon" on the cable and forced the lubricant with air compressor. I have to wait the weather to get colder to prove out if it works.
Sometimes, I suspected the noise came from the meter itself, not the cable. So, I am not hurry to replace to cable now.
I live in upstate New York (Very Cold and Snowy).
I have had poor mileage with my 2003 Corolla S (5-spd) since purchase (max 28mpg!! over the summer) now it runs about 25 to 26. If you need any input regarding this you can email me at:
toyotabeck@earthlink.net. (I know I should change my email address name!)
I am really disappointed with this car. If I had not made the mistake in leasing it, I would sell it tomorrow!
So far, I'm okay
2003 Vibe (yeah, I know, this is Corolla's board, but same engine...)
EPA is 28/33 on the automatic tranny.
I get 27 to 28 in mix'ed (a little NYC, and doing 80+mph on the hywy, but no lead feet - slow to start, but will catch up)
89 Corolla still gets about 29mpg.
EPA was 27/30.
No leadfoot either, but love to run the canyons in it, not beetling along like a snail.
Yes, loose gas caps will do this, dirty gas will do this too and then turn off on your next refill with better gas.
But the dealer should be able to read this from the car's ecu when you take it to the shop. Make sure you have all your documentation in case it gets worse. Good luck.
Number 001/5884.
I searched the NHTSA website and cannot find any info from this number, could you please provide more detail?
And also do you have any more info about the Air Flow Meter? Is that the O2 sensor?
If it stores the error code even when the light goes off, then I will go and get it checked from somebody else.
i'm not 100% sure but your dealer may be correct. try phoning diferent dealers and ask.
I am not sure when this was phased in for the rest of the country.
Unfortunately, dealership said they called Toyota but they said it doesn't exist. I guess it was very old information. Sorry.
BTW, seems like new Air Flow Meter helped with
sulfur smell, but did not improve gas milage. It still around 27 on 50/50 driving. I'll wait for now and see what happens. These guys couldn't fix CD rattle for two times. It's not properly mounted into dashboard on the top and rattles as a hell. I will try to bring it to another shop this month.
http://www.obdii.com/obdii.html
Why would be a dealer little reluctant to fix a problem. Don't they get money from Toyota to repair these things?
car over the warranty = BIG $$
so you will notice that once your car is over the warranty period, each time you take your car to the dealer - they find all sorts of problem. if your car is still under warranty, they can't seem to find anything wrong with your car!
cam sensor is a sensor for your camshaft.
in simple terms, it sends info to your ecu (brain/computer) for injector/spark timing.
You mean with the new sensor, the headlights do not come on/off/on/off/on/off as you drive in and out of the shade on a highway on a sunny day?
For me the lights comes on in full sunlight, as the sensor gets block by other car parts as I drive on the highway.
Maybe they have a new spec?
I bought mine Vibe in Nov, 2002.
1. In cold weather (less than 15 degrees F) sensor flickered the lights briefly after i had turned off the engine and removed the key. battery was drained overnight after i had left the car thinking they were off.
2. Lights would go off (but daylight ones stayed on) when i made a right or left turn signal. This would only happen if the sensor had turned the full lights on.
What they did:
1. Replaced relay assembly, part # 82810-02033
2. Replaced switch assembly, part # 84140-02200
Both of these had to be special ordered, I drove around for ~ 1 week before getting the work done while waiting for the parts. luckily the weather warmed up and i wasn't left with a dead battery again.
Another interesting problem poped up last night, the radio would periodically lose sound and change stations on me. Of course they couldn't reproduce this error, but have ordered a new unit anyway.
First time in 4 toyotas that i've had to take a car in for anything other than regular maintenance.
How about gag a rolla for the sedan?
It's the Toyota word for stinks while moving! Pass it on!
I bet we can get custom bumper stickers done! Get them in either swamp gas green or lemon yellow!
Mean me!
Just trying to see if bad smell = bad gas mileage.
dont know if this is the smell you guys are referring to.
