I just took my 1995 automatic car in for an oil-change and was given a list of things I needed to have done for a cost of $1,000 plus tax. It came as a bit of a shock since none of this came up when i had my annual inspection in June (from the same place).
Can anyone advise whether this is a realistic list of maintenance things and if $1000 is a reasonable cost:
Timing belt and water pump. Tune-up, power steering flush, coolant flush, battery service, tire rotation, fuel induction service.
Many thanks.
How do they know the timing belt and water pump are due for replacement? 60k miles is a more normal time for that. Do you know if the car has had the timing belt replaced before? If so, it shouldn't need another one. If not, might not be a bad idea if you plan on keeping the car. I've seen dealers charge ~$400 to replace a timing belt.
What's included in the "tune up"? Doesn't this car have electronic ignition? So what are they going to do, replace the spark plugs or ???
If the car hasn't had a power steering flush or coolant flush before, might be a good idea, especially the coolant flush.
What will they do on the "battery service"? Check it and clean the terminals maybe?
What's "fuel induction service"? Are they going to put some overpriced fuel cleaner in? Is this a "dealer special" or does Toyota's recommended factory service specify it?
All this... and no brake check or other stuff that might actually be useful??
IMO much of this might not be needed, and even if it is, you could probably find a good mechanic who would do the work for a lot less.
So, it sounds like the timing belt and water pump are the most costly things to do. Perhaps I should get an additional quote or two from others.
The belt degrades with time as well as mileage.
Seven years is the usual interval.
I'd also change the brake fluid every 3 years.
Replace the thermostat and radiator cap every other coolant change.
I would skip the fuel induction service if it's running OK.
OTOH I would get the throttle body cleaned every 10 years.
After I took the delivery of car I saw the brake was too soft and the brake wont work until the pedal crosses first half and reaches the floor. Next day I took it to nearest different Toyota dealer for servicing. The dealer informed me that they drove the vehicle and found brake to be hard and ok.
I can clearly see the brake is not working even at low speed of 5 mile until the brake pedal is pressed all the way down. The car is still in warranty. I cannot believe dealers and service department blatant lie that everything is OK. I have driven so many car to know how brake works. This car is too dangerous to drive. Seems both car dealer working in tandem to show that everything is fine.
The Sandman
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
