Pete
I am bringing it to the dealer on Friday
What's the difference between SOHC & DOHC.
I have a 94 Corolla 1.6L. What type of engine does
that have?
Is it Interference fit
A DOHC has a separate camshaft for each set of valves.
Was your battery flat last time? How about the alternator, was it working properly? If the answers are yes in both cases, probably there is a bad ground in your circuit and it is easy to fix. The difficulty is to locate it, and the mechanic has to spend hours and cannot charge you an arm or a leg for the fix. That's why most of them are not eager to do the job.
Another hint, did you have a collision recently (even a minor fender bender)? Good luck.
injectors. 1998 corolla auto. 1.8l eng. Only Dealer in town.. - Captive audience,
Huh?
I have got quoted for 310$ at one dealership and 350$ at another(plus tax). They cover everything you mentioned, besides cleaning injectors. May be you can cut price on refusing a injectors service. You don't really need this..
All U.S. Corollas except the 1988 FX model have had DOHC engines since 1988.
I have the same exact problem with my 95' Corolla. My battery has been replaced, radio connections checked, alternator tested, and the grounds have been checked. No problems have been found. I have not been able to find anyone who can accurately diagnose this problem. Any feedback would be appreciated.
Then, at the dealership, he lifted the car up on the hydraulic lifter, and ran the engine at 70mph. The sound was there. This means that the tyres and wheel alignment is out of question.
The chief technician also could not find any problem in the car. The only reason he could give was that its a 3-gear car and at 70mph the engine would revv. at a very high rpm. I don't necessarily believe that cause i can feel all the four gears change when i drive.
Any suggestions??
-acd
I would suggest you take out that radio, and reconnect the original wires. Make sure the fuse is good while you do that. You can do it yourself also if you are comfortable. Your radio might be short circuiting itself causing other circuits to fail.
If that doesn't work, i suggest you write this to toyota. On toyota website, there's an owner's section. You can become a member by giving the VIN number of your car.
Another issue:
I just passed 53,000 miles. Now here is the newest joy: the seat belt light stays on blinking. Very annoying. I will not take it to the dealer, unless someone will advise me to the contrary. Yes, it is annoying, but the car is rolling just fine with the light blinking. I see from posting others had the same problem.
I wanted to post my message to make all the fellows with the same problem feel better.
The vehicle experienced a no ignition failure while approaching a stop sign about a week later. The vehicle was immediately re-started by putting the car into neutral and turning the ignition key before it could roll to a stop. A weekly later, the car did the same thing. Waiting at a stop light, the ignition failed. The car was re-started by turning the ignition key within two minutes (note it took longer to start the car here than during the last episode) and continued on without further incidence.
Saturday, the vehicle traveled approximately 120 miles. The vehicle was parked in the garage at my residence. A number of hours later the car would not start. The engine cranked, but there appeared to be no spark signal. I verified the following:
1. There was no spark getting to the spark plugs
2. The resistance of the plug wires is low. Spec is 10k ohms - 25k ohms; measured below 10k ohms average.
3.The ignition coil resistance of the primary winding was tested (cold). Spec is 0.36 ohms - 0.55 ohms; measured 0.5 ohms;
4. The ignition coil resistance of the secondary winding was tested (cold). Spec is 9.0k ohms; - 15.7k ohms; measured 11k ohms;
5. The pickup coil resistance G+ to G- terminals was tested (cold). Spec is 185ohms; - 275ohms; Measured 250ohms;
6.The pickup coil resistance NE+ to NE- Spec is 1,630 ohms - 2,740 ohms; I do not understand where are how to measure this value. This vehicle does not appear to have such a value. The NE+ to NE- measurement appears to simply be the primary side of the ignition coil. So again, I did not measure this item.
7. I verified that I had +12v on pins 1 and 3 of the connector going to the ignitor. I have no further documentation on how to test the ignitor itself.
After having done all of these measurements, re assembling the ignition system the vehicle cranked, but did not start. A couple of good yanks on the wiring harness and the car started.
NOTE: The rotor was recently replaced. The rotor cap was not and does show signs of some corrosion and wear.
The car was driven to a short distance and left running Sunday morning. Ten minutes latter it was in my garage. The car sat for approximately three (3) hours in the garage. While driving later that afternoon (about 10 minutes) the car lost its ignition signal. I was unable to start the vehicle with the usual set of tricks, and it was necessary to have the vehicle towed. At this point I am suspecting the ignitor module (external), but this does not explain why/how a good yank on the wiring harness would usually correct the situation.
One last piece to the puzzle. I installed a drain and fill kit about 2 years ago. If you locate the drain and fill kit connection in the heater core hose, you will notice that the wiring harness crosses directly underneath. Furthermore, this spot in the harness has a rubber shield on the underside of the harness presumable to prevent water from splashing up from the underside. When a previous starter was installed, it was discovered that the drain and fill kit had been leaking directly over this rubber shield. This shield was now acting as a diaper and the harness was sitting in a pool of antifreeze. An air hose was stuck in and air was forced in for about fifteen (15) minutes in an attempt to dry out the harness. It was not determined if the antifreeze had penetrated the harness itself, but I mention it here as a possibility. We may have a corrosion situation of some of the wires at this point in the harness.
Anyone have any ideas? How do you test the external ignitor? That part is $360+ !!!
I have a 95 dx, it has 110k miles on it and here are the things I had problems with.
1. 2 years into car Replaced battery
2. 4 years into car replaced battery second time when repair shop told me it was the problem, when my car wouldnt start. Wasnt the problem
Due to misdiagnotic I replaced the starter, when it didnt need to be replaced.
Replaced the alternator problem fixed the problem.
4. 4 years into the car the thermostat went out and car overheated
5. 6 years into the car Radiater was plugged up with rust had to replace it, was told heads didnt warp, and engine was ok.
6. After I had radiator replaced the car now makes a lot of knocking noise when I accelerate, can anyone tell me what this might be.
7. hehe minor problem with right rear light keep burning out I think I finally fixed it.
I put this car through hell on a daily basis so these problems are acceptable.
One reoccuring problem I have been having is the brake pads have worn down a lot and squecked every 1 1/2 years I replace the pads. So far I have replaced the pads 3 times since 1995. The rotor is still ok. I figure theres a problem with the calipers but I dont mind putting lifetime pads on it every 1 1/2 years.
I would like to know if this stuff looks like what you guys might be getting. Also if you guys have any idea why the car would make all kinda tin car sounds when I accelerate. I dont think its the gas, I'm thinking its the ignition or the pressure.
I checked the plugs they look fine, the wires look pretty run down but doubt thats the problem.
95 corolla 110k on it orginal owner and still going.
The signs are usually the car will run but as you push the gas it backfires and slows down sometime even stalls.
I put my car through hell it has 110k on a 1995 dx, so a few problems are acceptable.After replacing the radiator. My car lost power, and now when I excellerate it clanks at first, more then usual.
I'm hoping I didnt damage the engine driving it with a non working radiator for 2 days, I kinda doubt I did.
I figure its the fuel system, ignition, or valves.
Have never replaced the spark plug wires they do look beat up a lot one almost fell apart on me. I checked the plugs they look great no residue and gap looks ok.
I just hope its not an engine problem. Anyone have any ideas.
I have found the following, If you close the vent on the left side you get more coming through the middle vents, also instead of running the ac at full fan speed try it one notch lower or even the middle setting. This seems to have sped up the cooling for me. Then later on you wont be able to stand the full setting when it gets going. Keeping your car in the sun most of the time not running does slow the performance of the ac down a lot.
I have a feeling the ac may be warmer at first because the radiator is hot from the sun being on it. The ac works best when the radiator is cool. Thats why it takes time for the ac to cool you off.
You can always have your cars ac checked for freon if your really sweating.
My Corolla won't start, battery is fully charged.
