F-350 Rotors
I have a '00 F-350 SD w/diesel. My front rotors had to be turned at 15k miles, which I think is ridiculously low miles for what is supposed to be a heavy duty pickup. So far, I've only towed for about 150 miles (mostly uphill, so didn't use brakes at all...) It now has 40k on it, and is badly in need of rotors again.
The truck has never been heavily loaded, I don't ride the brakes and don't make panic stops. I've had other vehicles that go more than 100k miles before needing rotors. I've positively babied the thing the last 20k miles.
What's the deal here? Is Ford using substandard parts? Has anyone else had problems like this? Is there an after-market solution?
Only problem I've heard of is squeaking brakes. Apparently some are replacing or turning rotors for this with very low mileage.
The Ford service guys seem to think that replacing rotors at 15-20k miles is perfectly normal. Perhaps it is normal for Ford, but it sure isn't normal for anything else I've owned.
jcave1 mentioned squeaky brakes. I have a left rear brake that squeaks but only when I am applying very light braking pressure.
Do you have the SRW or a DRW truck? I've been following the posts on the "Dodge Dakota Problems" thread. Some mentioned that improper torque on the wheel studs might be the culprit on the Dakotas. If you have the SRW, that could be a possible cause.
You are the first person I know of to mention this problem in an F-350. I do not think this is normal!!!!
Then again at about 28K.
Both times at the dealer. Then I needed new rotors at about 38K.
I bought the NAPA rotors for the front and had the rear turned by the local Dodge dealer (I know, but my sister in-law works there). Now at about 47K the front needs to be turned again.
I totally believe that Ford has not figured out how to make a good brake system that will last.
I just this minute got a call from the Ford service guy who told me that he can turn the rotors again (there's still enough metal) but that I don't need pads yet. I'm still on the original pads, front and rear. Like I said earlier, I've been babying this thing, so I really don't understand why they're warping so easily.
I do however, drive on the hard side. I also tow and/haul sand, rock, firewood, and other stuff quite regulary. I also tow my 7500 lb camper in the North Georgia mountains about once a month.
But still!! I think it is way too soon for brake rotors to warp. I have to believe that the system just allows too much heat to build up, not releasing the pads from the rotors well enough.
I guess NAPA is not any better. There must be something that works somewhere out there. Just have to find it.
We"ll see...
Thanks...
If you come across that article again, I'd sure like to read it... Thanks...
