wd40?
It's blamed cold outside, my old olds won't start. She's got almost full tank of ethanol gas, and since cleaning my carb last fall have not had this problem. Am out of starter fluid, been too confident of my beast to bother getting any. I do, however, never run out of wd40. Will it work for starter fluid spray, or will I end up needing a fire exstinguisher?
You should be careful with starting fluid, don't use too much, as it is also a very effective solvent and will wash your cylinder walls of all oil coating.
Have you thought about bringing your battery indoors in very cold weather?
gas coming down past the piston rings if you flood the engine out will also wash the oil right off, which is why tow-ins around here often find an oil change on the bottom of their rescue bill, and nobody ever seems to be successfully sued despite all the crabbing about the practice.
As for general lubrication use, I've found the solvent-heavy WD-40 to be lacking. Things just don't stay lubricated and the stuff offers almost no corrosion protection.
I use Valvoline Synpower in a spray can and I often use ATF (in small, empty eye-drop bottles) to lubricate things I don't want to spray.
--- Bror Jace
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Kirstie, shame on you:) No wd-40 in locks, please! It messes them up. Use only graphite lock lubricant.
if the lock doesn't settle down within a few days, consider it is misaligned in the door... or the insides are misshapen now, and time for another one.
But, to answer your question, I use it everywhere I can to prevent metal-to-metal contact.
Nigel ShiftRight, I'll have to check a can of WD-40 and see what it says.
--- Bror Jace
OK, is this a trick challenge?
Quote from WD40 can: "Lubricates" (refers to being a "Lubricant") Moving parts, such as Hinges, Wheels, Rollers, Chains, Gears.
Do I get an A?
Frank
Now I have to go look--lol!
Are there two kinds of WD-40? I distinctly remember losing a bar bet over this!!!
I'm not picky about drinks the way I am with oil for my silly little car. Any house chardonnay will do. >;^)
--- Bror Jace
They must make two products, one a lubricant and one not?
All mine says is:
Stops Squeaks
Cleans and Protects
Loosens Rusted Parts
Frees Sticky Mechanisms
Drives Out Moisture
It also says it's flammable and that you shouldn't swallow it. Glad I read that, or I would have had it for lunch.
But nothing NADA about the word "lubricant".
The wording you give is very similar, though not exactly as on the front of my can. The "LUBRICATES" section is on the back of the can along with other uses entitled Directions, Cleans, Protects, Penetrates, and Displaces Moisture. I have used WD40 for at least 45 years. primarily as a lubricant of many uses. It seems strange they would not include that use on some cans.
I have a 15oz can, bought at SAMS within the last 2 years probably (item number 42162) that also does NOT mention "LUBRICATE" anywhere on the can.
It does clean good though and it uses propane as the propellant...never tried it as engine starter.
Maybe they have changed the formula? Maybe they didn't actually want to advertise it as a lube?
I've always known not to use it on guns and expect it to last very long, it cleans them up good, but then you need to use something else before putting them up...I probably would not spray too much in an intake/engine that is not firing....probably wash the cylinders almost like liquid gas would.
Good luck , you can get ether at Agri-supply last I looked.
But if there's a product specifically meant for lock lubricating, guess I'm better off getting that than remaining in a quandry. (ps - my can says "lubricates")
kirstie_h
Roving Host
Edmunds.com
Review your vehicle
WD40 used to make a product called TAL5 which does have lubricant on the can. It is one of those multi synthetic spray products which works great on printers. Unfortunately they stopped making the product. Was priced at a fraction of the other synthetic lubricant sprays on the market.
Thanks to whomever suggested using ATF as a lube. FYI I also use Mobile one as a lube for small electric motors-no problems yet.
http://www.wd40.com/Brands/wd40_faqs.html
What does WD-40 do?
WD-40 fulfills five basic functions:
CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape and excess bonding material.
DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements."
actually nothing like that.
I still can't use it to keep food from sticking to the pan :-D
If I want a lubricant to keep metal things moving and slow corrosion, I'll use Synpower, ATF, etc ...
--- Bror Jace
WD is good for an initial blast into some dirty hinge, good for squeaks, things like that. It does many things competently, but doesn't really excel at anything. For specialized tasks, I use a specialized product is what I'm saying.
