Steven
Just wondering if anybody else ran across this and what maintenance if any they do on these front drive shaft universal joints.
Dusty
I use Mobil 1 0W-30 full synthetic motor oil, but in all honesty I think synthetics are hard to justify. Their biggest positive feature is viscosity stabilization, ie: high flow rates at a wider temperature range and longer duration. Unfortunately, synthetic oils collect dirt and moisture just like non-synthetics and should be changed because of it. I would not advocate 30, 20, or even 10,000 mile change intervals using synthetic motor oil. However, in the practical duration of the manufacturers recommended change interval, I would say that a synthetic is more reliable through 6-7500 miles.
From a cost perspective alone synthetics are probably not justified.
Best regards,
Dusty
Best regards,
Dusty
I have a question, can anybody tell me where i can get info on changing spark plugs on my 2003 1500 quad cab with the 4.7 engine. I have 63k miles on it and was wondering if changing the plugs might help the terrible fuel mileage (14 mpg).Thanks in advance.
gwp46
Thanks...
Dusty
From what I can tell the 4.7 engine is pretty good on spark plugs. I've talked to folks that have gone more than 75K on the factory Champions. However, I've also talked to a few that thought their 4.7 was running pretty good - no noticeable skips or roughness - yet after a spark plug change said they noticed a difference in smoothness, performance, and fuel mileage.
My personal belief is that most modern engines do seem to run fine when there's high mileage on the spark plugs. Newer designs have more powerful ignition coils and cleaner burning combustion chambers. But fuel quality and driving conditions can impact individual results.
Even though I changed-out my factory Champion RC12MCC4s for Bosch 4418 Platinum+4s, supposedly a much longer lasting plug, I do not intend to try to take then to failure. Spark plugs are relatively inexpensive maintenance items, even the pricey platinums. This seems especially acute now that gasoline prices are $2.61 a gallon!.
Best regards,
Dusty
Now the Dak seems to be running fine, although I think I noticed a very slight lag on transmission kickdown in the last couple of months. I'm still averaging 16.78 MPG with more around town driving with the air conditioning on, the idle is good and there has been no other noticeable performance problems.
I was hoping to change these out at 50K, just for a round number, but the loss of an electrode has me a little concerned. I'm also disappointed in the Bosch Platinum+4s at this mileage, although in all fairness the engine seems to be running fine. I may change them out just to see if there's a difference.
I'll keep everyone posted.
Bests,
Dusty
What can I do to increase my gas mileage? Its pretty clear that my son, with his heavy foot, gets about 2 mpg less than me. However, even when I baby it, I can't seem to get above 16 mpg on the freeway, and with city driving it drops back down to 14.5 or even lower pretty fast.
Which, if any, of the following should I consider?
increase tire pressure
use 89 or 91 octane gas instead of 87
turn off overdrive
use a performance chip
switch to synthetic oil
Also, the trip computer in the overhead console shows average mpg, but not instantaneous mpg. Any way to tweak it so it will show instantaneous mpg? Or, is there an aftermarket add-on that will show instantaneous mpg?
Thanks in advance for any input.
Keith H
Increased octane fuels will not benefit fuel consumption unless the engine is experiencing detonation or in the borderline zone. A performance chip is iffy.
Switching off the overdrive will hurt fuel consumption.
Increasing tire pressure will usually provide some positive impact, but the amount often depends on the tire design. Synthetic lubricant manufacturers claim that their fluids will increase mileage.
For some reason ...probably to reduce the propensity of drivers to watch the numbers and increase the likihood of having an accident...newer Chrysler products have deleted the real time fuel mileage feature from their console computers. It may be possible to fit an older style computer board into the overhead console of your '03. On my Dakota it looks as if the consoles are the same from '01 to '04, and the RAMs and Dakotas got the same computer board.
Dusty
I pulled another plug yesterday and it looks like these 4418s are running in the correct heat range The two plugs I've looked at have a light grey appearance on one half of the plug with a greenish haze on the other. All four ground conductors still have relatively sharp ends. The center insulator tip was just slightly brown or medium tan.
Dusty
Gotta Know,
dodger7
I think your friend either needs a very warm cabin before driving, or his last truck was a '26 REO.
Best regards,
Dusty
Has anyone ever changed Hemi plugs? Any unusual problems/tools required (extra long extensions, etc)? Does anyone know if replacing them with platinum would be a wise idea (is there a real reason for non-platinum, or is this just a reason to get $224.00 off the Hemi owners every 30000 miles instead of just every 100000 miles)?
1. Place a drop pan under the transmission to catch the fluid.
2. Loosen all of the transmission oil pan bolts approximately one-half way out of the transmission housing.
3. Remove all of the bolts except those at each corner of the pan.
NOTE: On that year truck you may have RTV sealant as a gasket material, or a one piece pan gasket.
4. Using a putty knife or other like tool, carefully insert the blade between the oil pan and the oil pan flange on the transmission.
5. Using moderate pressure only, move the putty knife blade along the oil pan mounting surface in order to break the seal. If this is a one piece gasket the seal should break fairly easily. When RTV is installed it may take more pressure to break the seal.
NOTE: In the following step the object will be to break the seal in only one area of the gasket surface to control the flow of the exiting fluid. This will prevent fluid from exiting around the full perimeter of the oil pan and reduce mess.
6. As the pan gasket surface pulls away from transmission fluid will begin to come out. Reposition the drop pan to catch the fluid.
7. Once the fluid has drained remove the remaining bolts and remove the oil pan.
8. Remove the RTV gasket material or the one piece gasket.
9. Using a gasket scraper or putty knife, ensure that the gasket surface on the transmission is clean of any old gasket material.
10. Locate and remove the small round magnet from the inside of the transmission oil pan.
11. Using a suitable non-flammable solvent or strong soapy warm water, clean the oil pan thoroughly. Allow to dry.
12. Locate the transmission oil filter. The filter is a relatively thin black plastic assembly held to the bottom of the valve body by two phillips head screws.
13. Remove the two filter mounting screws and remove the filter.
14. Inspect the filter intake opening and the valve body for a small black "L"-shaped gasket. This gasket must be removed if still attached to the valve body.
NOTE: A new filter gasket should come with a new filter.
15. Using a small amount of Mopar All temperature Black RTV, apply a new filter gasket to the new filter. Allow to cure.
16. Install the new oil filter. The two screws should be torqued no greater than 35 inch pounds.
17. Clean the transmission oil pan and transmission housing gasket surfaces with a non-flammable solvent. The object is to get the surfaces clean of any oil residue.
18. Using RTV or a one piece gasket and the bolts, reinstall the oil pan. If using RTV allow at least 20 minutes to cure at 70 degrees F. Only use enough RTV to provide a thin film across the surface of the gasket. Do not over apply RTV.
19. Add enough Mopar ATF+4 to bring the fluid level to the minimum fill line on the transmission dipstick.
20. Start the engine. Check for leaks.
21. Check the fluid level. If the level is below the minimum fill line, add more ATF+4.
22. Allow the engine to come to operating temperature.
23. Ensure that the parking brake is on. Place your foot on the brake pedal.
24. Starting in Park, move the gear selector to neutral for at least 20 seconds.
25. Sequentially, more the gear selector into each gear for 20-30 seconds. Return to neutral for 20 seconds. Repeat again.
26. Place the transmission in park and recheck the fluid level. Add enough to bring the level to the "HOT" level.
Dusty
Twenty dollars a quart???? WOW!
The retail price is around $6 a quart. I bought some for a friends car a while ago and want to say it was under $6 without the tax. Twenty dollars sounds about right for the one gallon plastic jug, though.
Find another Dodge dealer...quick!
Good luck and best regards,
Dusty
However, my first guess is your city-type driving is taking its toll. Even though you say you "baby it," that can be a subjective description compared to another driver. One way to squeeze out better MPG in city driving is to time traffic lights to avoid having to come to a complete stop, also "eggshell" throttle pressure when taking away from a stop. Obviously, keep speeeds low is key, but you're probably already doing that.
In all honesty, you aren't all that far away from what I hear most are getting with a 4.7 in a full size RAM, which is about 14-15.
Best regards,
Dusty
How do I access the spark plugs on my Dodge 1500 pickup? I have the 4.7L Magnum engine. I don't see the rubber boots anywhere. Just some little boxes with the wires sticking out. Are they hidden underneath something that I have to remove to get to them?
The coils are attached using a single 10mm nut which is located between the coil and the center of the intake maniford. Remove the nut and pull the coil straight upwards. The spark plug can now be accessed.
When reinstalling the coil it is recommended that a small amount of silicon grease be applied to the rubber seal at the end of the coil.
Access to some of the coils and spark plugs will require removal of the air filter housing cover, hose, and some other small engine plumbing tubes that run across the front of the throttlebody.
Dusty
I bought a set of new platinum plugs and I'm going to tackle the job this weekend. I'm also going to flush the radiator and put fresh coolant in for the winter. I might try that pink, non-toxic marine anti-freeze. Now if I can just find the drain plug on the radiator!
I own a 1998 Dodge Ram 1500 extended conversion Van. It has the 5.2L engine.
I know it isn't a truck, but the components are the same:
The last trip to Florida resulted in a serious whine in the rear. I have tracked the problem down to the input bearing on the pinion shaft. I have opened the differential and removed the gears that slip the axles. I am stuck with trying to remove the ring gear so I can remove the pinion and the bearing that is trashed.
Can you offer any help? I have already removed the bearing straps on either side of the ring gear assembly, and it looks like the whole assembly should just fall out.
It isn't..
Thanks in advance
Chris
Dusty
After posting, I got in touch with a certified mechanic who told me where the problem lie:
The ring gear assembly is held in place by two adjusters on either side of the assembly bearings. These 'adjusters' are similar to large, hollow locking nuts that adjust the left-to-right position of the ring gear assembly. They can only be reached from the wheel ends of the axle tubes. A homemade tool was required to remove the adjusters and the whole assembly has come out.
All new bearings and seals; a total of 13 pieces cost me $397 at the dealer. A 10% coupon has taken some of the bite off that price.
Now the fun begins!
Chris
If it is the differential I would find a shop specializing in that type repair. The average shop doesn't usually have the expertise to set the differential up properly.
Just found this info. I was right. just pull on it after you take out the screws.
REMOVAL
Lower the tail gate.
Remove the screws
Disengage the taillamp unit from the body panel.
Disconnect the electrical connector (Tail Lamp Unit).
INSTALLATION
Connect the wiring harness connector.
Position the taillamp unit into the body panel.
Install the screws (Tail Lamp Unit).
Of course, troubleshoot differential noise is driveshaft dependent. The shaft needs to be in place in order to detect pinion bearing problems.
Dusty
You might also try Mobil1.com if you don't mind ordering on-line. There are some links on that site to order from.
