Comparing the a4 cab to the IS250 is sorta misleading and not representative of comparing an IS250 to an A3.
My other friends with A4s' have had smiliar problems from years 03' until 07'.
Go with the IS.
Other folk I know who've had Audi's swear by them - not at them. You've either got a :lemon: or folks who don't know what they're doing with the diagnostics etc.
On the other hand I have a neighbour with a newish Mercedes C-class and he's either having an affaire with the Receptionist at the local Mercedes dealer or the car really is a dog. Just to balance that a near neighbour has one of the old, squarish, M-B S500's...........the one that just needs a big gun on the roof to complete the Main Battle Tank image, (it's even painted dark green metallic), and with 200k miles up it just keeps going but does have a drinking problem which is starting to hurt with gasoline here, (UK), at the equiv of $9+ per US Gallon.
As with all things electro-mechanical there are great examples and not-so-good ones. Isn't that part of the fun ?
Apologies for the long-winded response. Blame old age. Mine.
1 - Audi A3 2.0T 6-Speed -- By far the most enjoyable the three to drive, and has the most rear seat space and the most utility as well given the mini-station wagon configuration.
2 - Acura TSX 6-Speed -- Fun to drive, lots of goodies (that I don't necessarily care about), and reasonable space in the back seat.
3 - Lexus IS250 RWD 6-Speed -- Extremely boring to drive with no "feel" of what's going on with the mechanicals or down on the road. This car also suffers from an anemic engine (at least until you wind it up even higher than the Acura's already high strung mill) and a back seat that is all but laughable. In every respect, this car is a very distant third of the three.
Best Regards,
Shipo
1) Over the decades I've had dozens of cars that were from Asia, North America and Europe, and every one of them has exhibited the same gas gauge characteristics as your car (i.e. the needle is fairly stable for say 100 miles following a fill-up, and then it drops like a rock). This is totally normal as the level of fuel when "full" is typically above the top measurement range of the gauge sensor.
2) IIRC, Infiniti recommends "Premium" gasoline for your 2004 G35 engine (an engine well known for its poor fuel economy by the way), you should check your Owners Manual to be sure. Assuming that's the case, by running regular you are forcing the engine management system to retard the ignition timing to keep the engine from blowing itself to bits because of the low grade fuel you're feeding it. In turn, retarded ignition timing will further reduce the already marginal fuel economy of your engine.
3) Given how modern engine management systems work, it is physically impossible for a K&N filter to improve fuel economy. In fact, there is a fair amount of empirical evidence that suggests this type of a filter can reduce your economy.
4) Based upon the reports of other owners of your car, 15.6 mpg is not too far out of line for "mostly city driving".
Sorry I couldn't be more helpful.
Best Regards,
Shipo
Fuel guage is what it is...I think it was the old BMW where they made the guage for the last 1/4 tank of gas almost 3/4 of the guage. It's rare that it matters how full the tank is when it shows full...but it really does matter when you're down to 1/8 a tank.
High performance plugs and "high efficiency" air cleaners do almost nothing in a modern engine. Actually, most all additives also do nothing, in fact most car makers recommend against using ANY additives in the car.
If you aren't driving aggressively, then about the only thing you can do that will really improve mileage is to turn off the A/C.
I get consistent 22 mpg tank to tank. Why you would use low octane on a higher performance engine is foreign to me.
My car weighs 3,700 lbs and still gets acceptable gas mileage on standard A/S tires because each month I regulate tire pressure and rotate the tires each 5K miles.
Tires last longer, wear even and get the best efficiency as a result.
It doesn't take much to get the specified MPG rating for your car if you are aware of the small details.
OW
The inside of the filler door, the manual, the dealer techs, the salespeople, this board and a few other places have repeatedly explained about the compensation for lower grade fuel that these engines make -- and, of course, the way that it is handled is as you say shipo.
I leave for a few months and then come back for a look see and we're still talking about the same stuff. I find the search facility works just fine -- why would the car require premium fuel, tell you it requires premium fuel and then surprise you when it runs at less than its most efficient?
Wonder if there is a "glossary" somewhere here that would be like an FAQ page for folks -- sort of like:
Fuel requirements Regular, MidGrade & Premium
Oversteer
Understeer
Horsepower vs Torque: What we buy versus what we say we buy
Drive Bias: front, rear, neutral, all
Naturally aspirated, super charged, turbo charged, twin charged
And so on. . .
"Hey doc, it hurts when I do this. . ."
Doc: "Well then, don't do that. . ."
I MAY have had a headlight or tail light burn out LAST CENTURY. I also had brake rotor warping issues in my 2001 A6.
My experience with over 2 dozen Audis is, statistically, probably not significant, but as an anecdote, it bears writing here perhaps to balance the "Audi still has problems. . ." Overall, I have no evidence that Audi still has problems. My '05 A6, soon to be gone, will be missed. In so many ways it is still ahead, by years, of the newest CTS -- if you could test drive these two cars back to back, the content and performance of the C6/A6 vs the CTS demonstrates this point. The amount of trouble with dozens of Audis has NOT been zero. It just has never been electrical as your post suggests.
Another corner heard from.
link title
OW
Doc: "Well then, don't do that. . .that will be $85.00...please make an appointment for next Wednesday for a followup"
THAT is more realistic...:):):):):)
Or, you could substitute the plumber, then say, "that will be $125" (LOL)
Lawyer to me: "Yes I do. That will be $75."
Tires rotated every 6k miles, but original Bridgestones gone at 33k miles, now on Toyo Versados (with Dunlop WinterSports in the, well, winter...). Regular pressure checks.
Yet I still want an XK. But, the Evil Wife wants a three season room. Gee, wonder who'll win. "Whatever Lola wants, Lola gets!:" Name that tune (well, show/movie...).
XKR...Fughedaboudit for now...
OW
Let us know on this or some other board what's been going on, if you're that way inclined.
Going from the longest-post maven to missing-in-action is a jolt to some of us.
Either way, hope you enjoy your new A4. The A3 turned out to be my runner-up to the car I finally ended up with this time, the Acura TSX. I appear to have recovered from my RWD disease.
Good to hear from you.
Well done, Shoeless O!
Yeah, I'm fuhgedinaboutit for now... :sick:
The C will need new chassis pieces to handle this!
Here is the link for more.
link title
OW
Dr. - your X-Ray shows that you need major surgery.
Guy - How much will it cost?
Dr. - $10,000
Guy - I don't have that kind of money.
Dr. - OK, for $1,000 I'll touch up the X-Rays
With as much horsepower as the coupe and 200 less pounds to carry around, a G37 sedan could make a compelling case for itself, especially against it's quicker main rival, the BMW 335i. Bonus's would be, quicker throttle response, smoother operation, and better fuel economy as well with the VVEL system.
Is Infinity loosing weight first???
All without Turbos???
Let's talk!
OW
Every time i switch my lights on the fuse blows,not only that i've noticed that i dont have any brake lights neither.All the bulbs have been checked & changed,& it's now doing my head in.lol.Am new to Beemers so don't know much about them really.Is this a common fault??? Could do with some help solving the problem.
1). On 2000- 2004 models are there regular standard shifts in all models years?
2). On the secuential shift, can it also operate as automatic or dose it always have to work as semi auto? If so how dose BMW expect a valet parking to take the car? the shifter takes time and knowledge to be driven well.
3). On what model year did BMW introduce the secuantial shifter for 3 series
coupes?
4). What dose the "sport" button do on the 2003 secuential shifter 330 coupe?
5). If this transmission (secuential) reliable? Is it delicate.
6). On all BMWs are the F1 series faster than the same engine on luxury trim? Are the F1 engines different?
http://www.sae.org/about/general/history/
Best regards,
Shipo
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
1. Quiet smooth ride. Dampen road noise.
2. Luxury cabin and modern amenities. i.e. soft leather, no cheap materials and someplace to plug my ipod in.
3. Power and performance. Doesnt have to smoke everyone on the road or corner on rails but when I need to pass it should respond impressively.
4. Back seat capable of fitting a car seat and an adult if needed.
5. Drivable in bad weather. I wont say absolutely no rear wheel drive but I have previously owned an Infiniti G-35 coupe and it was nearly useless in even a light snowfall and not good in the rain.
6. Sporty style. This is subjective obviously
So. I am thinking:
2006 BMW 325xi or a 2006 Acura TL
Other candidates are the Audi A4/A6, Volvo S60 or Mercedes C class.
Any input would be welcome including options like leasing or any tips on how to get the most for my money.
A6 or S60 would be my choice..............but I have to declare a bias as an S60 owner, (and a diesel at that). Best seats in the business, nice lines, very well built and typically excellent Swedish safety, (incl child seats). Between the S60 and an A6 would be a hard choice for me but the slightly more distinctive lines of the Volvo would probably win me over - again - after 2 years of enjoyable, comfortable, utterly reliable driving.
$22k would buy you an '07 or possibly '08 S60 SE Lux here in U.K. and enough change for a good weekend away...........ditto for an S80 which is even nicer.
Ah, but the iPod plug-in would be an after-market fit; but hardly a deal breaker.
The BMW seems to fit the bill in terms of fun to drive and status. Light on luxury and amenities, heavy on price tag and a lot of people have one.
The TL sounds like it has a lot of features and luxury, but I'm not sold on the style. Although I have to see one in person to say for sure. Red with Tan interior sounds nice. We will see.
The Volvo is the dark horse. Good value, safe, distinctive, reliable and more affordable. Again though I'm not sold on the look or performance reviews I read. Perhaps again if I see one in person in a color and trim I like and test drive it, that will come out ahead.
And now I'm seeing the TSX is considered luxury as well. Another for my short list?
Pretty much, called right on.
Nice car, but weird looking, kind of a knight in armor without the knight.
A nice looking and safe car but somewhat underpowered with fair interiors and gas mileage.
IMHO
Well I saw a white, late model TL in the parking lot today. I am guessing it was at least an 06 but possibly as new as a 09. Sharp car, not what I would call distinctive or a head turner, but very nice. Really though none of the cars I am looking at are "head turners".
TL makes my short list. BMW does as well. Volvo I will be checking the S60's and S80's.
Audi I am eliminating because of reliability concerns, which may or may not be justified but I've just heard it too much and I need to eliminate something. Too bad too because the A6 is a sharp car. Benz I am eliminating for now, that will be my gift to myself as a next car perhaps in 5-7 years when I can go beyond the C class. Lexus doesnt seem to have anything I like within my price range. Cadillac... not feeling it. Only other car I'll likely check out is the TSX, not sure what the distinction is between that and the TL but it seems to get very good reviews.
It is also true that the best way to buy the used 325i is through a dealer that offers these as CPO?
Thanks all!!
I traded in my 2005 Audi A6 (fully loaded and with the V6) and it had 60k virtually trouble free miles on it. Having said that, I would ONLY acquire one (of any of these mfgr's kids) with the CPO designation.
PS don't think you will use snow tires on an RWD car and enjoy it as much as an AWD car with all seasons, in most places, that is.
