I'd say the average life of a 300 series diesel is about 250,000 with good care and presuming no engine/trans replacements or major restoration (after all, you can keep any car running forever if you pay enough). If you don't think so, go to a wrecking yard and read odometers. What better way to get some good data?
So you are buying a car in the...okay, let's be generous...last third of its life.
What do I think it's REALLY worth? About $6,500. What is the most you should pay? If you really have to have it, and it checks out GREAT, and you haven't seen anything nicer, then maybe up to $7,500. After that, you are over the market and on your own...your call.
Remember---whatever gets you INTO a car cheap at the time you buy will come back to haunt you if you want to unload it. So if you don't like the car in 6 months, it'll have over 200K on it which makes it a hard sell for top dollar.
If this car had 75,000 miles it could bring $8,500 or better, say from a dealer's lot with a financing provision.
It does look clean, though, I'll say that. I don't know about the guy's story though. you could do a CARFAX report and check his mileage claims over the last 4 years. And "highway" miles is a meaningless term in some ways. Miles are miles when it comes to market value.
I changed the fuel filter- replaced the aftermarket with a MB from dealer.
I put a new metal seal between housing and the bolt (that screws into the filter).
Also, put a new rubber seal on the hollow bolt that screws into the filter (this rubber seal is in the stem of the main bolt).
I bled the air by loosening the hollow bolt that goes out of the housing.
(Haven't touched the bolt that comes back into the housing).
Still have fuel leaking from under the top of the main bolt that screws into the fuel filter. after driving 3 miles.
I don't remember seeing any leaks before I changed the fuel filter. And I can see now the difference in the diesel consumption- the gauge needle drops down faster.
Is there anything else I should look at? It was supposed to be a simple fuel filter change!!
Thanks for any help.
Maybe I should run a very fine sand paper on the housing surface where the metal seal sits?
I cannot think of anything else, and I wanted to make sure there wasn't any other "trick" associated with changing the fuel filter. Is there anything else I need to be aware of?
I do get heat ( not that I want it in the summer, but only as a result of natural air flow if the vent is open). No AC, no blower, no defrost.
Anyone have a clue what direction I can take now. The maintainance manual refers to a diagnostic tool that I don't have for trouble shooting the system.
Sam.
http://boostnbenz.1baddsm.com/DIY/
I changed the fuel filters, reprimed it, pulled the glow plugs and checked resistance all about 1 ohm, took the glow plug relay out of the 300SD and popped it in - still won't start. Took a rag and dipped it in gasoline and put it inside the air cleaner (outside of the filter - eventually got it going - it ran great. Next morning it won't start.
The glow plug light comes on for about 3 seconds and goes out normally. There is no smoke at all coming out of the exhaust while it's cranking.
I'm out of ideas. Could the transmission shop have knocked something loose that's causing this problem? Could it be a bad fuel pump, injector pump...? How can I tell? Any help or suggestions will be most welcome.
Ken Sharpe :surprise:
But anyway, good idea to check that...although blowing 80 amps is a kind of scary thought...how did THAT happen?
I have a test you might try but you have to be very careful...you can activate just ONE glow plug with a battery jumper cable and see if the engine kicks off...but you have to be very careful not to ground the battery cable to anything metal except the tip of the plug....tricky...I used to do this test by wrapping very heavy gauge wire around the glow plug and then attaching the jumper cable to that, maybe one foot out of harm's way.
I suppose you could inflate your tires more and carry less fuel and get a 4-wheel alignment---all those things might....MIGHT...gain you 1 mpg.
I did one very very stupid thing recently, though. While changing fuel filters and checking for leaks, I did not latch the hood down tight, and drove in my sub- Well, the wind opened up the hood, and one hinge got twisted a tiny weeny bit, and so now when I close the hood, there is a slight intereference on the passenger side near the windshield side.
Would a body shop be able to set it straight?
As for better MPG, you might also try synthetic oil, although I'm a bit wary recommending synthetic oil on a car that is very old.
Yesterday my driver side window stopped working, Previously, for a rear window it was the fuse- I'll check fuse again for this one also, but do the switches or motor have a tendency to go bad?
1. No one commented on the glow plug resistance. Shouldn't I be able to spot a bad glow plug in this way? I'm wondering if it might be a bad wiring harness also. I'm still wondering if something may have happened at the trans shop. I checked the 80 amp fuse and it's intact.
2. Could clogged injectors or bad fuel pump cause this problem starting, yet allow the engine to run okay once it gets going?
3. Should I use a glow plug reamer when I change the plugs?
Thanks all!!!
Thanks all!!!
Finally, took it in to a dealer- problem was the glow plug module. What was happening was that it was draining power even while driving, when it was not supposed to- i.e. glow plug(s) was/ were always draining power- hence, power consumption was more than the alternator could generate.
I think they also replaced some glow plugs at that time.
If you can get it running by jump starting/ rags/ whatever- check your battery charging. If it seems that it is not charging, problem could in fact be the glow plug module; not battery or alternator.
Good Luck!
As for mysterious power drains... my battery kept discharging over night. One day I'm standing next to the car while it's turned off and I hear the antenna trying to go down. It repeated this evevery minute or two. I disconnected the electical plug to the antenna and the problem was solved.
On a warm engine, compression will be better.
Have the valves ever been adjusted on this car?
John
http://boostnbenz.1baddsm.com/DIY/Climate/
There is nothing when this happens, just a low push of air sound maybe in the front left (sitting in the driver seat).
If it sits a half hour to 45 mins it starts again no problems for a while after that.
Any Ideas?
Any ideas about what would be the problem?
Pistonhead
There is one glow plug for each cylinder. They are a bit awkward to get out...best done with a 3/8" extension, a u-joint and a deep socket...15-30 minute job at most.
