Oil drain intervals
                    I am personaly using Mobil 1 (5w30 or 0w30) in my both cars (97 Passat, 96 Neon) and I am changing oil between 5000 - 8000 miles, depending on driving. It has never been less than 2 changes per year, too.
Krzys
Krzys
On my wife's 1995 Neon, since she used to drive it two miles each way to the Ferry, I used to change it every 6 months (Mobil 1 again), which worked out to every 4,000 miles or so.
Best Regards,
Shipo
By using this low interval, as opposed to a change every 5,000, at the end of the year and/or 12,000 miles, I have squandered $53 per car.
96 Mystique, once a year, filter at 6 months, 8-10,000/miles/yr now at 67,000 miles
97 Izusu Rodeo, oil and filter at 7,500 regardless of time, 73,000 miles
97 Mitsubishi 3000 GT VR-4, 5000 oil & filter miles regardless of time just changed it at one year in Jan, oil analysis was fine. 19,500 total miles
2000 Buick GSE, at 12,000 miles, filter at 6 months. (has indicator light but I simply reset it at 6000 miles and go another 6000 before the oil change). 21,000 total miles.
All use Amsoil 10W30 except the Mystigue which is the 0W30. Change interval depends on the driving done on each car, Buick lots of highway, 3000GT is a twin turbo toy, little mileage but went one year and analysis was great on same oil and filter. Also, live in moderate climate in Ric, VA which makes a huge diff. Went 15,000 on Camry once, didn't like analysis results. IMHO about 12,000 miles on my cars is when the build up of dirt and other wear metals gets too high and a change is needed.
It's not burning or leaking anything yet, and the oil comes out in a smooth stream, no chunks or anything, so hopefully it'll be good for a few more miles ;-)
Until a few years ago I changed every 5,000 using a Fram filter and Havoline oil. After 80k to 90k the cars started using oil (not horrible, but using) and power started to fall off.
I switched to Castrol, better filters (AC, Motorcraft, or Mopar depending on the car) and every 3,000 miles. I never add oil to a car anymore and power remains much closer to new even after 100,000 miles.
I am considering going to synthetic, a premium filter, and 6,000 intervals, but only on one of our cars because my wife drives it 100+ miles per day. I am weary of crawling under it every 6 weeks.
After reviewing many of the posts here and elsewhere, I think either method is sound.
I'll be honest. I don't like dirty oil. And that is about the distance it goes best before getting pretty black.
I will change earlier on conventional if I have exceeded the recommended time element for normal driving. In my case 7.5 months.
If its hot, lot of local driving, ac dusty and what ever else, I go 5 to 7k but usually no more.
Of course alot depends if I'm going to travel.
I find that oil changes can and do vary from driving conditions and driver conditions as well as car engines and types of oils being used.
I definatly wouldn't consider doing this drain intervals with standard conventional oils though.
bob
oh yeah, Dark/dirty looking oil, is a good sign it's working and keeping the engine clean. Not always does that mean your oil is bad.
But I changed my local commuter vehicle at 3000 miles and 7 months. The TBN on the oil analysis showed it had dropped to 3. Blackstone said that it was the right time to change. It was just starting to get really black.
I have a Subaru with Synthetic and 5,500 miles on it. I'm going to take a 1500 mile trip to Sedona AZ and back in a couple of weeks, and then change the oil. It's also a dark brown right now, but I don't feel any grit.
On my street legal VW dunebuggy I change it every 2500 miles (30W valvoline all climate)
on my 83 ford every 3000 miles.(10W30 Valvoline Max life)
On my new Ford F250 every 4000 miles (5w20 Motorcraft semi-synthetic)
I personally would never consider extended drains. Oil is TOO cheap to take a chance.
I feel that everyone should try that in lieu of blindly saying a specific interval and not accepting any other alternatives. Especailly when the Pennzoils of the world have billions to throw at misleading marketing techniques.
A while back I looked at my logs for my cars and I noticed that the mileage on my cars drop off slightly towards the time that I usually change the oil. We're talking maybe .5 to 1 miles per gallon in the last couple of tanks before the oil change. I change oil and filter every 3,000 miles with dino.
Now follow my math here:
I take between one to two gallons of oil out of the car (my TrailBlazer holds 7 quarts, most cars hold 5 quarts), and turn it over to the recycler, where they ship it off to one of the utilities to use in electric generation (once or twice a year they convert a power generating plant in my state and use old oil to generate electricity for a day or two).
If I extend my drain interval to 4,000 miles, in 100,000 miles I've reduced my oil changes by 8 from 33 to 25, and use 8 to 16 gallons less oil.
Assuming in that last 1,000 miles between 3,000 and 4,000 miles I get 19 mpg instead of 20 mpg, here is the petroleum consumption results in 100,000 miles:
3,000 mile drain intervals (33 oil changes), 49.5 gallons of oil (assume 6 quarts per change), 5,000 gallons of fuel (assume 20 mpg): 5049.5 gallons of petroleum used, 49.5 gallons recycled.
4,000 mile drain intervals (25 oil changes), 37.5 gallons of oil (assume 6 quarts per change), 5,065.6 gallons of fuel (20 mpg for 75,000 miles, 19 mpg for 25,000 miles): 5,103 gallons of petroleum used, 37.5 gallons recycled.
Now about the demise of the car because you didn't change the oil often enough: what about all those car parts they can't recycle? Where do they go? In the landfill? If you can extend the life of a car by making it last longer, you can buy fewer cars; maybe one or time in a lifetime. That's good for your wallet, but it's also good for the environment: we use less steel, less rubber, less plastic (they use petroleum to make that), and there is less waste ending up in the landfill, particularly car stuff leaching chemicals into the groundwater.
Some of the Wal-Mart techs are undoubtedly boobs, but you can't convince me that the dealers have the brightest bulbs doing oil changes either. Unlike Jiffy Lube, I haven't found Wal-Mart techs pull the battery out of your car to try to sell you a new one.
My daughter's car is a Mercury Topaz with the real low tech Ford engine and about 150K on the odo. It burns a quart of oil about every 1200 miles. I usually let that go about 5K between changes.
Oil is a scarce and valuable resource. Drive until the oil is gone, and then add more.
if you want maximum life in your car, change more often.
I use Red Line oil which is awfully expensive. I justify this because my Honda Civic uses very little (1 quart in around 6-7,000 miles) and takes only 3.5 - 4.0 quarts at a change.
I also leave it in for 7,000 - 7,500 miles so I only end up changing my oil every 5 months.
I like changing the oil in my car ... but don't want to do it every other month since I put 17,000-18,000 on my car every year. Also, I REALLY don't like taking the oil back, etc ...
My (trip) highway driving at 80+mph and 4,500+ rpms, I think is hard on the oil so I won't go any further than 8,000 miles on this or any other stuff ... although I probably could. I've seen some serioudly abused Hondas that seem to run fine even at 80,000+ miles.
As Nigel ShiftRight said, I like to splurge and blow the extra $20 or so on my car each year.
--- Bror Jace
If this is so, then the less a car is run and the more frequently one changes oil, the greater the engine wear. Hmmm.....
my question to you all, which is more important to you....
longer drains and cleaner oil or
less wear on your engine ?
one of the other, it is obvious you are into both but which is more important out of those two.
Anyway, when I restarted it, it made quite a racket for about 2-3 seconds until the oil got up to the heads. It also gave me a puff of blue smoke out the tailpipe on a car that never burns oil. It also had less than a full load of coolant in the block because I replaced the waterpump, which means no sound insullation from the coolant. No noise from the lower part of the engine before it fired, so the noise was in the heads. I expect one of the valves that remained open while it sat for 6 weeks stuck open until oil got to it.
There is definitely something to be said for a good oil and keeping it clean. But I know now that the oil will definitely find its way to the pan over time. Never had this happen after a 2-week vacation with the car sitting in the garage, but 6 weeks is definitely too long.
1995 BMW 318ti, 69300 miles: Mobil 1 15W-50 + BMW filter every 4K-5K miles, oil consumption 1 qt every 3500 miles. Car sees somewhat frequent track and high rpm use.
1997 BMW 528iA, 68000 miles: Mobil 1 15W-50 + BMW filter every 9000 miles, no oil consumption between changes.
Anyone have any experience with this?
I only use the oil change monitor as a reminder should I forget. Haven't yet with about a dozen cars.
I bet 4ooo would work fine for the us.
My 2 other vehicles are Chevy trucks with 4.3 v6 motors, I change them at 3k miles routinely, but do not notice any real improvement just because of new oil...I use normal petroleum oil and ABF filters (Anything But Fram!!!)
see ya
I also asked about going to Mobil 1 to stretch change intervals (even though Mobil 1 says on their site to change as the manufacturers mauals recommend). The service guys said they have some who are changing with Mobil 1 every 6000 but change the filter every 3000.
If I have to be at the dealers every 3000 I figure I might as well stay with dino oil and just do the whole deal every 3000. They only charge me $17.95 and that includes checking tire pressure, topping fluids etc.
Warranty is based on the oil monitor, there is nothing in the owners manaul about changing oil more frequently then 7500 miles or when the light comes on. Dealer is looking to keep service bays full!.
thats what 3000 is all about
I look at the cost of an oil change vs the cost of a overhaul and the choice becomes easier.
When should I change oil? At 8-9K yearly, 5K for Summer(2 months) 3K Winter(2 months). I'd like to change only twice a year. I've been using Castrol Syntec 5-50(OUCH?) in my '99 Ford E150 4.2 six.(Fla.) After the Summer, the van is stored,except for a few runs.Thanks for the suggestions.
Ron
Even among the folks who do extended oil drains, many of them change the filter halfway in-between.
try a couple short interval changes using thicker oil and extra detergent and seal swell, try to see if you can help the valve seals seal better and the rings clean up in the ring grooves on the piston.
I always use thicker oil on older engines, starting at about 50k actually (I have also taken alot of abuse on this from the synthetics crowd and the "5w/10w30 gets better mileage crowd" )
I have my reasons but I choose better protection over better gas mileage,,,,especially as the engine gets more "mature..."....and just a side note...I check mileage on every tank, and over the years, on all my vehicles, drop in gas mileage has been minimal if even noticeable as I increased the oil viscosity as the engine aged...
Sorry bout that, just got up on my stump for a minute:)
see y'all
Rando
Question for all you oil mavens out there: if you only drive a few thousand miles per year (say 5000-7500), should you wait for the mileage markers to go by to change the oil, in which case you would change it maybe twice a year or less, or do it every three months even tho you have only driven 1500 miles or so?
I would stick to 3K for vehicles with a reputation for sludging (Toyota) even if it was not a common occurrance.
The Monte Carlo is on semi-annual Mobil 1 changes (He's putting about 5k miles on annually, no more heavy loads because of 2 doors vs. 4 drs, hehe.)I'm not sure he's going to fare much better as they are still hard miles.
Who knows?
As far as the camry story, I am sure hard driving had a lot to do with that guy's tranny problems! That series of camrys was pretty tough.
